M310210
M310210
    ETHERTRONICS
    RF ANT BLUETOOTH WIFI 2.4GHZ
M310210 数据手册
PRODUCT DATA SHEET: BLUETOOTH®/WiFi Part No. M310210 SavviTM Embedded Ceramic Bluetooth/WiFi Antennas 2.35, 2.45 & 2.59 GHz KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Savvi series of Isolated Magnetic Dipole™ (IMD) antennas deliver on the key needs of device designers for higher functionality and performance in smaller/thinner designs. These innovative antennas provide compelling advantages for Bluetooth® enabled cell phones, media players and other mobile devices. TECHNOLOGY ADVANTAGES Real-World Performance and Implementation Ceramic antennas may look alike on the outside, but the important difference is inside. Other antennas may contain simple PiFA or monopole designs that interact with their surroundings, complicating layout or changing performance with use position. Ethertronics’ antennas utilize patented IMD technology to deliver a unique size and performance combination. Stays in Tune High RF isolation means IMD antennas resist detuning regardless of usage position. And one standardized part can typically be placed in a variety of locations. Smallest Effective Size IMD antennas require a smaller keep-out area for surrounding components, leading to a smaller effective size. High Performance IMD’s high efficiency and simple design rules lower development risk and speed time-to-market without sacrificing performance. Plus, high RF selectivity eliminates the cost and space for band-pass circuitry. More information is available on our Website at www.ethertronics.com/resources/. Best in Class Performance—Smallest Occupied Volume • Powerful combination of 76% peak efficiency and simple implementation guidelines. • Minimal ground clearance and component “keep out” areas. Very low component height. • High selectivity eliminates the cost for additional filters and frees up board space High Tolerance to Frequency Shifts • IMD’s high RF isolation resists antenna de-tuning that otherwise impair reception. • Single part works for various PCB sizes and layouts. Quicker Time-to-Market • Fewer design modifications required to pass RF test suite. RoHS Compliant • Ethertronics’ antennas comply with the European RoHS Directive 2002/95/EC. END USER ADVANTAGES Superior Range • Greater antenna efficiency means longer range and a better end user experience. Exceptional Coverage • Better coverage delivers more reliable wireless connections for mobile phones, laptops, stereo headsets, cars, media players, audio systems and more. SERVICE AND SUPPORT Extensive RF Experience • Our Savvi ceramic antennas are supported by extensive application notes, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support • Ethertronics’ global operations encompass an integrated network of design centers that provide local customer support. ETHERTRONICS 9605 Scranton Road, Suite 300 | San Diego, CA 92121 - USA | www.ethertronics.com tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Bluetooth® / WiMAX/ZigBee Antenna Ethertronics’ SavviTM Bluetooth/WiFi Embedded Antenna Specifications Ethertronics produces a wide variety of standard and custom antennas to meet user needs. Below are the typical specs for a Bluetooth/ WiFi application. Electrical Specifications BT/WiFi Antenna Typical Characteristics (Inside an enclosure) 2.400—2.480 GHz Peak Gain Average Efficiency VSWR Match Feed Point Impedance Power Handling Polarization Mechanical Specifications Size Mounting -1.3 dBi 75% 1.02:1 max 50 ohms unbalanced 0.5 Watt cw Linear 3.00x1.50x1.08mm Surface mount Tape & Reel Packaging M310210: Minimum Order Quantity of 100,000 pcs. Order multiples of 10,000 pcs. M310210-1K: Minimum Order Quantity of 1,000 pcs. Order multiples of 1,000 pcs. Typical Efficiency, Return Loss Antenna Radiation Patterns 2.440 GHz Band Typical Performance Ethertronics’ Test Board PCB: 40x60mm z (θ=0o) y (Φ=90o) x (Φ=0o) © 2011 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Savvi, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. BT 8/05/11
M310210 价格&库存
很抱歉,暂时无法提供与“M310210”相匹配的价格&库存,您可以联系我们找货
