TW4020/TW4022 Wideband GPS Antenna
The TW4020/TW4022 is a commercial grade
wideband GNSS antenna covering the GPS L1,
frequency band. It features a small patch
element with 40% wider bandwidth than
typical GPS L1 antennas.
The TW4020/TW4022 features a high
performance custom tuned ceramic patch
element, 15 KV ESD circuit protection, a high
gain two-stage low noise amplifier (LNA) with a
mid-section high rejection SAW filter. It covers
the GPS L1 and SBAS (WAAS/EGNOS/MSAS)
frequency band (1572.5 to 1578 MHz), and it
offers great circular polarized signal reception.
The TW4022 includes a pre-filter designed to
mitigate strong intermodulated or near
frequency signals.
Even with the wider bandwidth, the
TW4020/TW4022 antenna is among the
smallest high performance antenna available. It
is housed in a compact IP67 magnetic mount
enclosure.
Applications
Cost Sensitive Positioning
Fleet Management & Asset Tracking
Covert surveillance
Features
40% wider bandwidth, small footprint
Axial ratio: 1dB typ (GPS )
Low noise LNA: 1 dB
High rejection SAW filter
High gain: 28 dB typ.
Wide voltage input range: 2.5 to 16 VDC
IP67 weather proof housing
Low Power: 9mA typ. at 2.3Vcc min.
Benefits
Increased system accuracy
Excellent signal to noise ratio
RoHS compliant
Ideal for harsh environments
Excellent out of band signal rejection
Specifications
Antenna
Architecture
1 dB Bandwidth
Antenna Gain (with 100mm ground plane)
Axial Ratio over Bandwidth (over full bandwidth)
Electrical
Architecture
Polarization
Gain
Gain flatness
Out-of-Band Rejection (typ)
VSWR (at LNA output)
Noise Figure
Supply Voltage Range (over coaxial cable)
Supply Current
ESD Circuit Protection
Mechanicals & Environmental
Mechanical Size
Cable
Operating Temp. Range
Enclosure
Weight
Attachment Method
Environmental
Shock
Vibration
Wideband Single Feed Patch
31 MHz
4.5 dBic
SAW filter-> LNA stage 2 (TW4020)
SAW filter LNA stage 1 -> SAW filter-> LNA stage 2 (TW4022)
Filtered LNA Frequency Bandwidth 1565 to 1585 MHz
RHCP
TW4020: 26dB min., TW4022: 25dB min,
+/- 2 dB, 1575 to 1606 MHz
TW4020
TW4022
70dB
65dB
>1640 MHz
-40dB
->60dB
很抱歉,暂时无法提供与“33-4022-10-0290”相匹配的价格&库存,您可以联系我们找货
