A Tallysman Accutenna®
TW1600 Dual Feed Iridium® Antenna
The TW1600 employs Tallysman’s unique
Accutenna™ technology in a low cost OEM dual feed,
passive Right Hand Circularly Polarized antenna
(RHCP) for the 1616MHz to 1626MHz frequency
band, specifically designed to enhance the signal to
noise ratio of communications over the Iridium™
satellite communications network.
The wideband dual feed patch element in the
TW1600 has an excellent axial ratio across the entire
Iridium™ bandwidth. Unlike single feed antennas, the
TW1600 provides excellent multipath rejection and a
truly circular transmission response across the
Iridium™ band.
Dimensions (mm)
The TW1600 includes a built-in 35mm circular
ground plane but best performance is obtained with
this augmented with a local system ground plane or
reflecting surface equivalent to 100mm diameter (DC
connection not required).
OEM antennas are easily detuned by the local
environment. Tallysman offers custom tuning services
for optimized integration into OEM end-user modules.
Applications
Micro-Coax cable
Higher C/No values for Iridium™ communications
Sea & Land Container Tracking
Military & Security
Fleet Management & Asset Tracking
Marine & Avionics Systems
Law Enforcement & Public Safety
RG174
Features
Benefits
dual-feed, wide band patch
Axial ratio, Hybrid 90° Combiner
RHCP
20MHz
Mechanicals & Environmental
Mechanical Size
Cable
Operating Temp. Range
Weight
Attachment Method
Environmental
Shock
Vibration
Warranty
57 mm dia. x 10 mm (micro-coax cable) 11mm (RG174)
RG174
-40°C to +85°C
30g
Magnet, Adhesive or M2 screw mount
RoHS compliant, IP67
Vertical axis: 50G, other axes: 30G
3 axis, sweep = 15 min, 10 to 200Hz sweep: 3G
One year – parts and labour
Ordering Information
TW1600 – Dual Feed GPS Iridium antenna
Where xx = connector type and yyyy = cable length in mm
33-1600-xx-yyyy
Please refer to the Ordering Guide ( http://www.tallysman.com/wp-content/uploads/Current-Ordering-Guide.pdf) for
the current and complete list of available connectors.
Tallysman Wireless Inc
36 Steacie Drive
Ottawa ON K2K 2A9 Canada
Tel: +1 613 591 3131
sales@tallysman.com
Fax 613 591 3121
The information provided herein is intended as a guide only and is subject to change without notice. This document is not to be
regarded as a guarantee of performance. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind. ©
2016 Tallysman Wireless Inc. All rights reserved.
Rev 1.2
很抱歉,暂时无法提供与“33-1600-09-0180”相匹配的价格&库存,您可以联系我们找货
