A Tallysman Accutenna®
TW4721/TW4722 Wideband Dual Feed GPS/GLONASS/BeiDou/Galileo Antenna
The TW4721/TW4722 is a compact, wideband GNSS antenna
that provides accurate reception for all upper L- band GPS,
GLONASS, Beidou, and Galileo signals ( L1, G1, B1, B1 BOC,
B1-2, E1) and associated augmentation signals (WAAS,
EGNOS and MSAS SBAS).
This antenna employs
Tallysman’s patented Accutenna technology.
The TW4721/TW4722 features a novel 25mm dual feed
wideband patch element that, in sharp contrast with its
competitors, provides a truly circularly polarized response, with
a typical axial ratio of less than 2dB over the full bandwidth.
This provides a more linear carrier phase response and
substantially improved multipath rejection for higher precision
applications.
The TW4722 is the pre-filtered version of the TW1721. The
pre-filter provides protection from near frequency or strong
harmonic interfering signals.
The TW4721/TW4722 is the smallest, lightest, wideband GNSS
antenna available. It is housing in a compact IP67 magnetic or
adhesive mount enclosure and is available with a wide range of
connector options and custom coax cable lengths.
The antenna can be ordered without the magnet. In such cases,
the magnet is replaced with a plastic plug to provide a smooth
under surface, with the option of ordering it with or without 1.1
mm double-sided VHB tape on the bottom.
Applications
Cost Sensitive Mission Critical Positioning
UAV / UAS
Covert surveillance
Fleet Management & Asset Tracking
Features
Dual feed patch element
Axial ratio: 2 dB typ.
Low noise LNA: 1 dB
High rejection mid-section SAW filter
High gain: 26 dB typ.
Wide voltage input range: 1.8 to 16 VDC
IP67 weather proof housing
Low Power: 10mA typ. over supply range.
Benefits
Greatly enhanced multipath rejection
improved GNSS reliability
Excellent signal to noise ratio
RoHS compliant
Ideal for harsh environments
Excellent out of band signal rejection
Specifications At; Vcc = 3V, over full bandwidth, T=25°C
Antenna
Architecture
2 dB radiated power bandwidth (RHCP)
Antenna Gain (with 100mm ground plane)
Axial Ratio over full bandwidth
Polarization
Electrical
Architecture
Filtered LNA Frequency Bandwidth
Gain (1559 MHz to 1606MHz)
Gain flatness
Out-of-Band Rejection
VSWR (at LNA output)
Noise Figure
Supply Voltage Range (over coaxial cable)
Supply Current
ESD Circuit Protection
Mechanicals & Environmental
Mechanical Size
Cable
Operating Temp. Range
Enclosure
Weight
Attachment Method
Environmental
Shock
Vibration
Warranty
Wideband Dual Feed Patch Element
47 MHz
4.5 dBic @ 1582.5MHz
Hybrid->LNA stage 1 -> SAW filter-> LNA stage 2
1559 to 1606 MHz
TW4721: 25dB min, 29dB max TW4722: 23dB min, 27dB max
+/- 2dB, 1559 MHz to 1606MHz
TW4721
TW4722
40dB
>57dB
45dB
>62dB
>1630MHz
>45dB
>50dB
很抱歉,暂时无法提供与“33-4721NM-00-3000”相匹配的价格&库存,您可以联系我们找货
