A Tallysman Accutenna®
TW1421/TW1422 Compact Dual Feed Embedded GPS/GLONASS
TW1421/TW1422 employ Tallysman’s Antenna
patented
The
Accutenna® technology covering the GPS L1, GLONASS G1, and
SBAS (WAAS, EGNOS & MSAS) frequency band (1574 to 1606
MHz). It provides truly circular response over its entire
bandwidth thereby producing superior multipath signal
rejection. It also offers high out of band signal rejection.
The antennas feature a novel 25mm wideband patch element
with dual-feeds that are summed in a 90° Hybrid and input to a
two stage Low Noise Amplifier (LNA) with a mid-section SAW a
second low noise gain stage. This configuration provides
excellent axial ratio and cross-polarization rejection across the
full frequency band.
The TW1422 has a pre-filter which increases the antenna’s
immunity to high amplitude interfering signals, such as LTE and
other cellular signals.
The built-in 35mm circular ground plane should ideally be
augmented with a local system ground plane or reflecting
surface (DC connection not required).
The height of the RF shield (can) will be selected based upon the
connector type. Connectors which require RG174 cable will be
used with the taller can. Connectors which require mico-coax
cable will be used with the shorter can.
OEM antennas are easily detuned by the local environment.
Tallysman offers custom tuning services for optimized
integration into OEM end-user modules.
Applications
High Accuracy GPS & GLONASS
Precision Agriculture, Mining & Construction
Avionics
Law Enforcement & Public Safety
Fleet Management & Asset Tracking
Features
Benefits
Compact Dual Feed Patch Element
1dB bandwidth 1575-1606MHz
Very low noise LNA: 1640MHz:
>60dB
>65dB
很抱歉,暂时无法提供与“33-1421S-08-0200”相匹配的价格&库存,您可以联系我们找货
