SPECIFICATION
Part No.
MA671.A.CGH.003
Product Name
Spartan Antenna 3in1 MA.671
Low Profile Screw-Mount (Permanent Mount)
Public Safety
3 * MIMO 4.5 ~ 4.9GHz antenna
2 x vertically polarized elements
1 x horizontally polarized element
Feature
IP67 Waterproof
High Efficiency / Peak Gain Outdoor Antenna
Standard 3M CFD-200 RP-SMA(M)
RoHS Compliant
SPE-12-8-112/B/PK
Page 1 of 16
MA671.C305151.G305151.H305151
1. Introduction
The Spartan MA671 Public Safety 3*MIMO antenna is a low profile, heavy-duty,
fully IP67 waterproof external M2M antenna for use in remote monitoring and
public safety applications.
The Spartan 3 x MIMO antenna is unique in the market because it combines
three 4.5~4.9GHz antenna elements in a heavy-duty structure with high
efficiency in a low profile compact format. The antenna screws down
permanently onto a roof or metal panel and can be pole or wall-mounted. Two
of the antenna elements are vertically polarized and one is horizontally
polarized to maximize diversity gain and MIMO throughput.
For industries such as remote monitoring, smart meter systems, construction
equipment, public safety at only 40mm high, the Spartan provides an
unobtrusive, robust, rugged antenna that is durable even in extreme
environments.
SPE-12-8-112/B/PK
Page 2 of 16
2. Specification Table
ELECTRICAL – V-pol. antenna 1
Frequency (GHz)
4.5
4.7
Radiation Efficiency* (%)
45.7
45.2
41.6
Peak Gain* (dBi)
4.1
3.2
3.02
VSWR
2 Max
Polarization
Linear (Vertical)
Impedance
50Ω
4.9
ELECTRICAL – V-pol. antenna 2
Frequency (GHz)
4.5
4.7
4.9
45.5
43.4
37.9
Peak Gain* (dBi)
3.4
3.8
2.43
VSWR
2 Max
Polarization
Linear (Vertical)
Impedance
50Ω
ELECTRICAL – H-pol. antenna
Frequency (GHz)
4.5
4.7
4.9
45.7
45.27
38.8
Peak Gain* (dBi)
3.2
4.4
3.4
VSWR
2 Max
Polarization
Linear (Horizontal)
Impedance
50Ω
MECHANICAL
Antenna Dimensions
Height 50mm x Diameter 150mm
Casing
PC
Base and thread
Nickel Plated Zinc
Waterproof
IP67
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
* all measurements were conducted with 3m CFD200 cable
SPE-12-8-112/B/PK
Page 3 of 16
3. Return Loss
4. Maximum Gain
SPE-12-8-112/B/PK
Page 4 of 16
5. Average Gain
6. Efficiency
SPE-12-8-112/B/PK
Page 5 of 16
7. Antenna Radiation Patterns
Y
Z
X
MA. 671 tested in CTIA approved 3D chamber
XYZ coordinates for reference
SPE-12-8-112/B/PK
Page 6 of 16
7.1 H-pol. antenna
XY Plane
X
Y
XZ Plane
Z
X
SPE-12-8-112/B/PK
Page 7 of 16
7.2 V-pol. 1 antenna
XY Plane
X
Y
XZ Plane
Z
X
SPE-12-8-112/B/PK
Page 8 of 16
7.3 V-pol. 2 antenna
XY Plane
X
Y
XZ Plane
Z
X
SPE-12-8-112/B/PK
Page 9 of 16
8. Cable attenuation
Cable attenuation (dB/ 100M)
GHz
0.5
1
1.5
2
2.5
3
3.5
4
4.5
5
5.5
6
CFD 200
26
39
49
58
66
73
86
98
109
SPE-12-8-112/B/PK
Page 10 of 16
9. Mechanical Drawing
SPE-12-8-112/B/PK
Page 11 of 16
SPE-12-8-112/B/PK
Page 12 of 16
10. Installation
SPE-12-8-112/B/PK
Page 13 of 16
11. Packaging
SPE-12-8-112/B/PK
Page 14 of 16
8 boxes per carton
SPE-12-8-112/B/PK
Page 15 of 16
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-12-8-112/B/PK
Page 16 of 16
很抱歉,暂时无法提供与“MA671.A.CGH.003”相匹配的价格&库存,您可以联系我们找货
