Specification
Part No.
GLA.02
Model
3dbi 1575Hz GPS Loop Antenna
Description
1575.42MHz
Features
10*3.2*3.9mm
SMT Process Compatible
RoHS
GLA.02 Antenna
GLAD.02 EVB
SPE-12-8-042/C/SS
Page 1 of 17
1. Introduction
Taoglas have developed a unique ceramic miniature loop antenna series for GPS
applications. At 10*3.2*3.9mm, the GLA.02 GPS 1575MHz Loop antenna is a
miniature edge mounted antenna, designed for small space requirements. The
radiation pattern is more omni-directional than traditional patch antennas. The GLA
loop antenna series show at least three times the efficiency of traditional linear
polarized 1575 MHz antennas. Efficiencies of 40% to 90% are achievable. Peak gain of
1dBi places this antenna gain performance within the range of a much larger 15mm to
18mm patch antenna.
Mechanically, this antenna does not need ground removed on the back-side of the PCB
thus allowing other components to be placed there on crowded boards. Based on the
loop effect this antenna works best when placed on the centre of the edge of the board,
but can still work better than traditional linear polarized chip antennas even when
placed at corners as substitute.
The GLA.02 is delivered on tape and reel and now allows M2M customers to use an
omni-directional antenna in devices where orientation of the product is unknown.
Applications
*navigation or position tracking systems
*Hand-held devices when GPS function is needed, e.g., Smart phone. PDA, PND
SPE-12-8-042/C/SS
Page 2 of 17
2. Key Performance Indicators
The antenna performance was measured with the GLA.02 mounted on an evaluation board
(80*40mm ground plane) with SMA(F) connector.
No
Parameter
Specification
1
Center Frequency
1575.422MHz
2
Dimensions
10*3.2*3.9mm
3
VSWR
2 max (depends on the special environment)
4
Polarization
Linear
5
Bandwidth
81MHz Min.(under -10dB return Loss)
6
Gain
Peak 3dBi typ.
7
Efficiency
83% typ.
8
Impedance
50
9
Operating Temperature
-40°C+85°C
Temperature Coefficient
10
(τf)
0 20 ppm @-20ºC to +80ºC
* Center frequency will be offset to working frequency according to the conditions of user’s
Ground plane and radome.
**The data was measured by A Test Lab Techno Corp. (CTIA Authorized Test Lab).
SPE-12-8-042/C/SS
Page 3 of 17
3. Electrical Characteristics
3.1 Return Loss (S11)
SPE-12-8-042/C/SS
Page 4 of 17
3.2 Impedance (Smith Chart)
SPE-12-8-042/C/SS
Page 5 of 17
4. Radiation Pattern (Customize Design)
SPE-12-8-042/C/SS
Page 6 of 17
4.1 3D Radiation Pattern
SPE-12-8-042/C/SS
Page 7 of 17
4.2 Efficiency Table
SPE-12-8-042/C/SS
Page 8 of 17
4.3 Efficiency vs. Frequency
SPE-12-8-042/C/SS
Page 9 of 17
5. Antenna Drawings
5.1 Antenna Main Body
Note:
Silver Area
5.2 Footprint
5.2.1
Footprint Copper Keepout Area
Note:
All pads should be connected to GND
Pad 2 should be connected to a 50ohm transmission line
SPE-12-8-042/C/SS
Page 10 of 17
5.2.2
Solder Paste Area
5.2.3
Solder Mask (Negative)
Note: Black regions are anti-mask
SPE-12-8-042/C/SS
Page 11 of 17
5.2.4
Footprint Composite
SPE-12-8-042/C/SS
Page 12 of 17
5.3 Antenna with EVB
SPE-12-8-042/C/SS
Page 13 of 17
6. Layout Guide
6.1 Solder Land pattern
Land pattern for soldering (grey marked areas) is as shown below. Depending on Customers
requirement, matching circuit as shown below is also recommended. The footprint is
12*5.6mm, this antenna does not need ground removed on the back-side of the PCB thus
6.2 Matching Circuit
The most common matching arrangement is the pi matching as shown below.
SPE-12-8-042/C/SS
Page 14 of 17
6.3 Fine Tuning Element vs. Centre Frequency
SPE-12-8-042/C/SS
Page 15 of 17
7. Packing
(1) Quantity/Reel: 2000pcs/Reel
(2) Plastic Tape
7.1 Tape Dimensions (unit: mm)
Feature
Specifications Tolerances
W
24
±0.30
P
8
±0.10
E
1.75
±0.10
F
11.50
±0.10
P2
2
±0.10
D
1.50
±0.10
Po
4
±0.10
10Po
40
±0.20
7.2 Pocket Dimensions (unit: mm)
Feature
Ao
3.4
±0.10
Bo
10.30
±0.10
Ko
4.25
±0.10
t
0.35
±0.05
SPE-12-8-042/C/SS
Page 16 of 17
8. Recommended Reflow Soldering Profile
SPE-12-8-042/C/SS
Page 17 of 17
很抱歉,暂时无法提供与“GLA.02”相匹配的价格&库存,您可以联系我们找货
