S8240B
S8240B
    LAIRD(莱尔德)
    ANT 824-896MHZ 2DBI N FEMALE
S8240B 数据手册
Laird Technologies - Item # S8240B, 800/900 MHz. Omnidirectional Antennas for Data ... Page 1 of 2 Laird Technologies Web site: www.LairdTech.com All Categories > Antennas & Reception Solutions > In-Building, CPE, Access Point, and Mobile Client Antennas > CPE Antennas (WiMAX, 3G/4G, LTE, Cellular, BWA) > Cellular (CELL) Antennas > Laird Technologies Dual Feed, Linear & Circular Panel Antennas (CELL) > 800/900 MHz. Omnidirectional Antennas for Data Communications > Item # S8240B Item # S8240B, 800/900 MHz. Omnidirectional Antennas for Data Communications 800/900 MHz. Omnidirectional Antennas Omnidirectional antennas are the right choice for situations where you need to be in contact with sources that are in two directions or if you do not know what direction the signals will be coming from. Receiving signals from two wellheads that are in different directions is an example of the former. An example of the latter would be a warehouse environment where a worker with a handheld terminal is moving about the area while sending and receiving data. larger image Data Transmission Omnis Standard Data Transmission Omnis are fully decoupled antennas built on a copper laminate and housed in 0.100 inch wall fiberglass housings. They may be mounted right side-up or tipped upside down depending upon the desired pattern. They also feature a very versatile clamp mounting system that will fit most every situation you will encounter. Specifications Frequency 824 to 896 MHz Gain 0 dBD Nominal VSWR 1.5:1 Bandwidth 62 MHz 3dB Beamwidth, E Plane 75 º RF Connector N (Female) Height 17 1/2 in 44.5 cm Weight 0.56 lbs 0.25 kg Wind Surface Area 0.083 m2 0.009 ft2 Wind Survival 125 mph 200 kph http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/z-omnidirectional-antennas-f... 8/8/2012 Laird Technologies - Item # S8240B, 800/900 MHz. Omnidirectional Antennas for Data ... Pigtail 17 cm Element Material Plated Copper Laminate Enclosure Material Fiberglass Mounting Style Tube end Max. Mast Diameter 2 in 5.1 cm Page 2 of 2 http://lairdtech.thomasnet.com/printitem/cellular-cell-antennas/z-omnidirectional-antennas-f... 8/8/2012
S8240B 价格&库存
很抱歉,暂时无法提供与“S8240B”相匹配的价格&库存,您可以联系我们找货
