NJG1507R-TE1
NJG1507R-TE1
    NJR(新日本无线)
    8-TSSOP,8-MSOP
    IC MMIC SWITCH SPDT 8-VSP
NJG1507R-TE1 数据手册
NJG1507R SPDT SWITCH GaAs MMIC nGENERAL DESCRIPTION NJG1507R is a GaAs SPDT switch IC which exhibits low loss and high isolation, and ideally suitable for T/R switch of the digital wireless phone. This switch is operated in the wide frequency range from 50MHz to 3.0GHz at low operating voltage from +2.5V with small VSP8 package. nFEATURES lSingle and low positive supply voltage lLow insertion loss lTransmission power lHigh isolation lLow control current lPackage nPACKAGE OUTLINE NJG1507R +2.5~+5.5V 0.5dB typ. @ f=2GHz, Pin=22dBm 27dBm max. @ f=2GHz, VCTL=3.0V 33dB typ. @ f=2GHz, Pin=22dBm 5uA typ. @ f=0.05~2.5GHz, Pin=22dBm VSP8 (Mount Size: 4.0x2.9x1.2mm) nPIN CONFIGURATION R TYPE (Top View) Pin Connection 1.VCTR2 1 8 2 7 4.GND 3 6 5.PC 2.P2 3.GND 6.GND 4 5 7.P1 8.VCTR1 nTRUTH TABLE “H”=VCTR (H), ”L”=VCTR (L) VCTR1 H L L H VCTR2 L H L H P1-PC OFF ON P2-PC ON OFF Loss =15dB P1 Return Loss =-3dB Loss =15dB P2 Return Loss =-3dB Loss =16dB P1 Return Loss =-2dB Loss =16dB P2 Return Loss =-2dB Note) The values of "Loss” and “Return Loss” are typical values at 2.0GHz. -1- NJG1507R nABSOLUTE MAXIMUM RATINGS (Ta=25°C, Zs=Zl=50Ω) PARAMETER SYMBOL RATINGS UNITS Pin 33 dBm VCTR 6.0 V Power dissipation PD 320 mW Operating Temp. Topr -30~+85 °C Storage Temp. Tstg -40~+150 °C Input power Control voltage nELECTRICAL CHARACTERISTICS (VCTR (L)=0V, VCTR (H)=2.7V, Zs=Zo=50Ω, Ta=25°C) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Control voltage (L) VCTR (L) f=0.05~2.5GHz, Pin=22dBm -0.2 0 0.2 V Control voltage (H) VCTR (H) f=0.05~2.5GHz, Pin=22dBm 2.5 2.7 5.5 V Control current ICTR f=0.05~2.5GHz, Pin=22dBm - 5.0 8.0 uA Insertion loss1 LOSS1 f=1.0GHz, Pin=22dBm - 0.4 0.7 dB Insertion loss2 Isolation 1 LOSS2 f=2.0GHz, Pin=22dBm - 0.5 0.8 dB ISL1 f=1.0GHz, Pin=22dBm 25 31 - dB ISL2 f=2.0GHz, Pin=22dBm 25 33 - dB P-1dB (1) f=2.0GHz 26 28 - dBm P-1dB (2) VCTR (H)=3.0V, f=2.0GHz 27 30 - dBm VSWR f=0.05~2.5GHz, ON STATE - 1.2 1.5 f=0.05~2.5GHz - 15 - (PC-P1, PC-P2, P1-P2) Isolation 2 (PC-P1, PC-P2, P1-P2) Pin at 1dB compression point 1 Pin at 1dB compression point 2 VSWR Switching time -2- TSW ns NJG1507R nTYPICAL CHARACTERISTICS -3- NJG1507R nTYPICAL CHARACTERISTICS -4- NJG1507R nTYPICAL CHARACTERISTICS -5- NJG1507R nTYPICAL CHARACTERISTICS -6- NJG1507R nTYPICAL CHARACTERISTICS -7- NJG1507R nTYPICAL CHARACTERISTICS -8- NJG1507R nTYPICAL CHARACTERISTICS MARKER Ang. (∠o) f(MHz) Mag. 1 50 0.952 -15.9 2 800 0.780 -171.0 3 1500 0.740 117.0 4 2000 0.726 75.8 5 3000 0.698 1.2 f(MHz) Mag. Ang. (∠o) 1 50 0.952 -15.9 2 800 0.780 -171.0 3 1500 0.740 117.0 4 2000 0.726 75.8 5 3000 0.698 1.2 MARKER -9- NJG1507R nTYPICAL CHARACTERISTICS Scattering Parameters: S11 (OFF STATE) (VCTR=0/2.7V, 50ΩSystem) - 10 - NJG1507R nAPPLICATION CIRCUIT 1: Single control signal operation by using C-MOS inverter. [1]Please connect bypass capacitors to the supply terminals of the C-MOS inverter. [2]In order to stabilize input impedance of inverter, please pull down using 510KΩ resister from the input terminal of the C-MOS inverter to the ground plane. nAPPLICATION CIRCUIT 2: Single control signal operation by using a transistor. - 11 - NJG1507R nTEST CIRCUIT nRECOMMENDED PCB DESIGN (TOP VIEW) PCB SIZE=19.5x14.0mm PCB: FR-4, t=0.2mm PC CAPACITOR: size 1005 C1 STRIPLINE WIDTH=0.5mm u C1~C3: 56pF R1 P1 C3 C2 NJG1507R 1 P2 C4, C5: 10pF R1: 510KΩ u: Please short between Pin4 C4 V CTR1 C5 V CTR2 and ground plane directly as close as possible. Precautions [1]External capacitors should be connected to the input and output RF terminals (P1, P2, PC) to block the DC current. The above example is a circuit at 1.9GHz. Please select the capacitor value suitable for actual frequency from 10pF to 1000pF. [2]Decoupling capacitors should be connected to the control terminals (VCTR1, VCTR2) as close as possible. The values of these capacitors should be selected from 5pF to 100pF range. Please consider that these values are very effective to switching time (Larger capacitor gives longer switching time). [3]In order to keep good isolation characteristics, the ground terminals (3, 4, 6pin) should be connected to the ground pattern with wider width as close as possible, and through-hole in the ground plane should also be placed as close as possible. - 12 - NJG1507R nPACKAGE OUTLINE (VSP8) Lead material Lead surface finish Molding material UNIT Weight Cautions on using this product This product contains Gallium-Arsenide (GaAs) which is a harmful material. • Do NOT eat or put into mouth. • Do NOT dispose in fire or break up this product. • Do NOT chemically make gas or powder with this product. • To waste this product, please obey the relating law of your country. : Copper : Solder plating : Epoxy resin : mm : 22mg [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. This product may be damaged with electric static discharge (ESD) or spike voltage. Please handle with care to avoid these damages. - 13 -
NJG1507R-TE1 价格&库存
很抱歉,暂时无法提供与“NJG1507R-TE1”相匹配的价格&库存,您可以联系我们找货
