ADH-tech
ADH Technology Co. Ltd.
Data Sheet / GP-735
Easy to Use,
Slim,
Ultra High Performance,
GPS
Smart Antenna Module
Version 1.0
www.adh-tech.com.tw
sales@adh-tech.com.tw
ADH-tech
Data Sheet – GP-735
The specifications in this document are subject to change without prior notice. ADH Technology Co. Ltd. assumes
no warranties (either expressed or implied) regarding the accuracy and completeness of this document and shall
in no event be liable for any loss of profit or any other commercial damage, including but not limited to special,
incidental, consequential, or other damages. ADH-tech products are not intended for use in medical, life-support
devices, commercial aircraft or any applications involving potential risk of personal injury, death, or severe
property damage in case of failure of the product.
No part of this document may be reproduced or transmitted in any form by any means without the express written
permission of ADH Technology Co. Ltd.
ii
ADH-tech
Data Sheet – GP-735
Revision History
Ver.
1.0
Date
June. 5th, 2014
Description
Initial draft
iii
ADH-tech
Data Sheet – GP-735
Contents
1
2
3
4
5
INTRODUCTION..................................................................................................................................... 1
1.1
OVERVIEW ................................................................................................................................ 1
1.2
MAIN FEATURES........................................................................................................................ 1
1.3
RECEIVER SPECIFICATIONS ........................................................................................................ 1
1.4
PROTOCOLS............................................................................................................................... 2
HARDWARE INTERFACE ..................................................................................................................... 3
2.1
MODULE DIMENSION ................................................................................................................ 3
2.2
PIN ASSIGNMENT ...................................................................................................................... 4
SOFTWARE INTERFACE ...................................................................................................................... 6
3.1
NMEA OUTPUT MESSAGES ....................................................................................................... 6
3.2
GPGGA - GLOBAL POSITIONING SYSTEM FIX DATA ................................................................... 7
3.3
GPGLL - GEOGRAPHIC POSITION - LATITUDE / LONGITUDE ....................................................... 7
3.4
GPGSA - GNSS DOP AND ACTIVE SATELLITES ......................................................................... 8
3.5
GPGSV - GNSS SATELLITES IN VIEW........................................................................................ 8
3.6
GPRMC - RECOMMENDED MINIMUM SPECIFIC GNSS DATA...................................................... 9
3.7
GPVTG - COURSE OVER GROUND AND GROUND SPEED............................................................. 9
EVALUATION INFORMATION ........................................................................................................... 11
4.1
OVERVIEW .............................................................................................................................. 11
4.2
ORDERING INFORMATION ........................................................................................................ 12
4.3
TIPS IN DESIGNING ................................................................................ 錯誤! 尚未定義書籤。
ELECTRICAL AND ENVIRONMENTAL DATA .............................................................................. 144
iv
ADH-tech
Data Sheet - GP-735
1 Introduction
1.1
Overview
ADH-tech GP-735 is a slim, ultra-high performance, easy to use GPS smart antenna module
designed with u-blox’s latest 7th generation single chip.
This feature rich GPS module not only shortens the design efforts but also provides powerful
functions. The compact design allows fast adoption and high yield production.
The power control feature is very convenient to turn on/off power just via GPIO control pin. It’s
especially useful to turn off power as the GPS function is not needed in the host applications.
1.2
Main Features
Not only handheld but also any other GPS applications can share the following major features
of GP-735.
1.3
Easy adoption with best performance
Built-in narrow patch antenna for dimension demanding application
Models of I-PEX RF connector option available for using external antenna
Built-in backup power pin for faster position fix
USB/UART-TTL interface support
Minimum RF and EMI efforts
Fully implementation of ultra-high performance u-blox7 single chip architecture
High tracking sensitivity of -162 dBm!
Low power consumption of 37mA for average tracking
Hardware power saving control pin allowing power on/off GPS via GPIO
Windows location sensor support
A-GPS support
Receiver Specifications
Features
Specifications!
GPS receiver type
56 channels, L1 frequency, C/A code
1
ADH-tech
Data Sheet - GP-735
Horizontal Position Accuracy
< 2.5m (Autonomous)
< 2.0m (WAAS)
(CEP, 50%, 24hr static, -130dBm)
Velocity Accuracy
很抱歉,暂时无法提供与“GPS-13670”相匹配的价格&库存,您可以联系我们找货
