MTC-H5-B03-KIT
MTC-H5-B03-KIT
    MULTI-TECHSYSTEMS
    MODEM HSPA+ USB USB ACCY KIT
MTC-H5-B03-KIT 数据手册
MultiConnect® Cell 100 Series Cellular Modems BENEFITS The MultiConnect® Cell 100 Series cellular modem is a compact • Quick deployments to shorten communications platform that provides cellular capabilities for fixed and time to market mobile applications. It is intended for use in settings demanding reliable • Long and stable lifecycles performance under rugged conditions, low power and long range such as • Certified and carrier approved remotely monitoring solar micro-inverters, power generators, tanks, pipelines, meters, pumps and valves in any energy, utility, or industrial application. The MultiConnect Cell 100 Series family has also been successfully deployed by professionals in emergency services, vending, remote patient monitoring, FEATURES • 4G-LTE Cat 4 and Cat M1 models • SSL/TLS support • Models with USB or RS-232 serial interfaces renewable energy systems, End-of-Train system management and process • Configured using AT commands automation. MultiConnect Cell 100 Series modems are fully certified for • FCC, PTCRB, Industry Canada, deployment in multiple geographies around the world, so you can get to market extremely fast. Designed specifically for M2M applications, they provide a long, stable lifecycle and are durable, reliable and easy to deploy. Connecting Your Devices Your Devices & Data and RED certified • Rugged, military and SAE tested • Two-year warranty, upgradable to five years Insight + Action + Control Digital Signage Energy Alerts ATM/POS Financial / Retail Real-Time Management Vending Machines Healthcare Kiosks Wireless Service Provider Asset Management Platform Reports www.multitech.com/cell100 SPECIFICATIONS Models MTC-MNA1 Performance LTE Cat M1 Frequency Band (MHz) Packet Data* Diversity/MIMO SMS MTC-LNA4 MTC-LEU4 LTE Cat 4 AT&T: 3GPP Rel. 13 B2 (1900MHz), B4 (AWS1700MHz), B12 (700MHz 3GPP Rel. 13 4G:700(B12/B13)/ 850(B5)/AWS1700(B4) 1900(B2) Verizon: B4 (AWS1700MHz), B13 (700MHz) 3G AT&T only: 850(B5)/1900(B2) 3GPP Rel. 13 4G: B1 (2100)/B3 (1800)/ B7 (2600)/B8 (900)/ B20 (700) 3G: B1 (2100)/B8 (900) 2G: B3 (1800)/B8 (900) Up to 300 Kbps downlink, up to 375 Kbps uplink 3GPP Up to 150 Mbps downlink/ Up to 50 Mbps uplink (Category 4) N/A Rx Diversity and MIMO DL 2x2 Point-to-Point Messaging, Mobile-Terminated SMS, Mobile-Originated SMS (for SMS solutions when using the Verizon cellular network, contact a MultiTech sales representative) Power Requirements Voltage USB Models: USB powered – 5V RS-232 Models: 7 - 32VDC USB powered – 5V Connectors RF Antenna External 50 ohm SMA (female connector) SIM Mini SIM (2FF); 1.8 and 3V USB Type B mini USB RS-232 DE-9 (female connector) Power RS-232 Models: 2.5 mm miniature (screw-on) Physical Description Dimensions (L x W x H) 3.17" x 2.45" x 1.16" (8.05 cm x 6.22 cm x 2.95 cm) Weight 0.65 lbs (0.295 Kg) Chassis Type Aluminum Environmental Operating Temperature† -40° to +185° F (-40° to +85° C) Storage Temperature -40° to +185° F (-40° to +85° C) Humidity Relative humidity 15% to 93% noncondensing Certifications Regulatory FCC Class B (US) IC (Canada) FCC Class B (US) IC (Canada) RED (EU Economic Area) Safety UL60950-1 (US) UL 60950-1 (US) cUL 60950-1 (Canada) IEC60950-1 (EU Economic Area) PTCRB, AT&T, Verizon PTCRB, AT&T, Verizon N/A Network Quality MIL-STD-810G: High Temp, Low Temp, Cold Dwell, Random Vibration and Sine Vibration SAE J1455: Random Vibration and Sine Vibration * Actual performance speeds may be affected by a variety of attributes such as cell tower distance, data loads, packet sizes, etc. † Device has been tested up to +85° C. UL Recognized @ 40° C, limited by AC power supply. UL Recognized @ 60° C when used with the fused DC power cable, part number FPC-532-DC. Note: The radio’s performance may be affected at the temperature extremes. This is considered normal. There is no single cause for this function. Rather, it is the result of an interaction of several factors, such as the ambient temperature, the operating mode and the transmit power. HIGHLIGHTS Applications Services & Warranty The MultiConnect® Cell 100 Series cellular modems are ideal for automated machine-to-machine applications such as remote diagnostics and remote monitoring which periodically need to send or receive data over a wireless network. MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs.These services are aimed ORDERING INFORMATION at protecting your investment, LTE Products extending the life of your solution Model MTC-LNA4-B01-xx Description LTE Cat 4 Modem, RS-232 interface (AT&T - Verizon Dual mode cell) MTC-LNA4-B03 LTE Cat 4 Modem, USB interface without Accessories (AT&T - Verizon Dual mode cell) MTC-LNA4-B03-KIT LTE Cat 4 Modem, USB interface with USB Accessory Kit (AT&T - Verizon Dual mode cell) MTC-LEU4-B01-xx LTE Cat 4 Modem, RS-232 interface with EU/UK Accessory Kit MTC-LEU4-B03 LTE Cat 4 Modem, USB interface without Accessories MTC-LEU4-B03-KIT LTE Cat 4 Modem, USB interface with USB Accessory Kit MTC-MNA1-B01-xx LTE Cat M1 Modem (RS-232 interface) - AT&T/Verizon MTC-MNA1-B03 LTE Cat M1 Modem (USB interface) includes USB cable - AT&T/Verizon MTC-MNA1-B03-KIT LTE Cat M1 Modem (USB interface) with USB Accessory Kit - AT&T/Verizon Bundle Available Region Yes US/Can US/Can or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, Included US/Can Yes Euro/GB Euro/GB Included Euro/GB Yes Included Includes US style power supply, antenna(s) and RS-232 cable -EU-GB Includes EU & UK style power supply, antenna(s) and RS-232 cable -KIT Includes antenna and USB cable (USB models only, USB powered) installations, troubleshoot issues and help you with configurations. Technical Support Services US At MultiTech, we’re committed US to providing you personalized US attention and quality service while -xx Ordering Codes for MTC-LTE Models Blank Device only, no accessories -US can walk you through smooth providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well Use ordering codes for specific build options. Go to www.multitech.com for detailed product model numbers. as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Email: sales@multitech.com www.multitech.com Produced in the U.S. of U.S. and non-U.S. components. Features and specifications are subject to change without notice. Trademarks and Registered Trademarks: MultiTech and the MultiTech logo, MultiConnect: Multi-Tech Systems, Inc. All other products and technologies are the trademarks or registered trademarks of their respective holders. 2022-10 • 86002164 • © 2022 Multi-Tech Systems, Inc. All rights reserved.
MTC-H5-B03-KIT 价格&库存
很抱歉,暂时无法提供与“MTC-H5-B03-KIT”相匹配的价格&库存,您可以联系我们找货
