TW5340/TW5341 Multi-Constellation Smart Antenna
The TW5340 is a multi-constellation GNSS Smart Antenna which provides simultaneous
GPS/GLONASS/SBAS reception. It is designed for use in professional grade applications such as precision
timing, network synchronization, low current applications, and tracking/positioning applications.
The TW5340 GNSS Smart Antenna uses the state-of-the-art ST STA8088 receiver which provides 32 high
sensitivity tracking channels plus 2 fast acquisition channels which can be assigned to acquire and track
GPS, GLONASS, QZSS, and SBAS (WAAS, EGNOS, MSAS) signals simultaneously.
The TW5340 employs Tallysman’s Accutenna™ dual feed antenna patch technology which greatly improves
rejection of multi-path signal interference, across the whole GNSS band, making the TW5340 the most
precise smart antenna in its size across all operating
environments.
The TW5340 accelerates GPS positioning by predicting satellite
ephemeris data based on previous observations, resulting in
extremely fast Time-To-First-Fix.
The TW5340 can be configured to outputs up to three NMEA
0183 message lists with navigation update rates up to 10Hz.
RS232, and CMOS interfaces are available with input voltage
options of 3,3V, 5.0V and 12V to 36V with over voltage
protection.
A standard one pulse-per-second 1PPS synchronized to UTC
time is available as a single ended output or as a differential
output at RS422 levels. NMEA data can also be configured to
output at RS422 levels, however the 1PPS output is disabled
in this mode.
Tallysman’s Windows™ based Configurator enables simple configuration of parameters such as baud rates,
output message rates, constellation, tracking parameters, 1PPS configuration and Standby mode
parameters.
A non-magnetic version is available with Part Number TW5341
Features
Multi-Constellation Receiver/Antenna
32 Channel simultaneous operation
High performance tracking (-162 dBm)
WAAS, EGNOS, & MSAS enabled
3 NMEA 0183 output Lists
Navigation rates 1 to 10 Hz
1 PPS & NMEA configurable RS422 outputs
Low Current Standby Mode
Accutenna™ Technology
Excellent multi-path signal rejection
Industrial grade IP69K enclosure
RoHS, REACH and RED Compliant. CE Marking
Mechanical:
The TW5340/TW5341 is housed in an industrial grade weatherproof IP67 enclosure for 19mm diameter (¾”) thruhole mount or mast mount installations. It is available with low profile radome or with a conical radome. L-brackets
and pipe mount brackets are available as installation options.
Specifications
Frequencies
GPS / GLONASS / QZSS
1 PPS Output
SBAS
WAAS, EGNOS, MSAS
Channels
Antenna / Axial Ratio
Cable Length
Output
Dual Feed / < 1 dB typical.
5m (15m & 25m special order)
RS232, CMOS
3.3V, 5V (+/- 0.5V) and
12 V to 36V (9V min)
120 mA during acquisition
80 mA operating
Standby mode < 1mA
Voltages
Current
Dimensions
66.5 mm (dia) x 21 mm (h)
Weight
135 g
Mounting Method
19 mm dia. (¾”) thru-hole or
mast-mount
Navigation accuracy
GPS+GLO
1.5m (50% CEP)
Environmental:
Operating Temp. Storage Temp.
Weatherproof
Shock
Vibration
Emissions
Immunity
-40̊C to +85̊C
-45̊C to +85̊C
IP69K
Vertical axis 50G, other axis 30G
3 axis sweep – 15 min
10-200 Hz log sweep 3G
EN 55022
EN 61000-4-3, EN 61000-4-4, EN
61000-4-6
Sensitivity
Time to First Fix
Serial Protocol
Single ended & Differential
RS422. +/-50 ns Accuracy
16Kv protection RS422 lines
32 simultaneous plus 2 fast
acquisition
Acquisition: -146 dBm
Tracking: -162 dBm
Cold start: 35 sec
Warm start: 30 sec
Hot start:
很抱歉,暂时无法提供与“33-5340-03-10”相匹配的价格&库存,您可以联系我们找货
