TWC-USB
TWC-USB
    THOMASRESEARCHPRODUCTS
    NAVIGAN COMMISSIONER USB
TWC-USB 数据手册
ZenNet Installation Guide: Technology From: 0-10V Dimming Relay Module TWR-D10 Specifications Wires: Black, White, Red, Grey, Purple Threaded connector and lock nut 1.1” 28mm Power Supply 120V - 277V VAC, 60 Hz Maximum Load General Purpose: 16A @ 120/277VAC Resistive: 16A @ 120/277VAC Orange Antenna (insulated end) Tungsten: 960W @ 120VAC Ballast: 600W @ 120VAC 2.78” 73mm 2.24” 57mm 0-10V output LRN (O) button * For high sinking current and dim values below 10%, the output voltage may exceed the selected output value and reach 1V max. DIM (I) button 1.65” 42mm Package Contents ▪▪ 0-10V Relay Module Tolerances +3%/-4% (1-10V range) Current sinking 35mA*, sourcing 4mA Tools Required Power Consumption 1.1W full load, 500mW quiescent Surge Protection 3kV line to line, exceeding IEC61000-4-5 installation class 4 Inputs/Outputs • Flying-lead style wires • 2 power input wires • 1 switched output wire • 2 output wires for 0-10V control ▪▪ Screwdriver ▪▪ Wire nuts Product Description The LED relay zone controller uses wireless technology to communicate with other self-powered EnOcean based products and provides an amazingly simple solution for dimming control of LED lighting. The compact size enables flexible installation inside of or next to electrical boxes and fixtures so it can be easily wired out of sight using standard wiring practices. Simply link the module to an EnOcean-based motion sensor, light level sensor or rocker switch and experience levels of efficiency and convenience that can only be achieved through wireless controls. Configuration Interface RF Standard Transmission Range EnOcean Equipment Profile Interoperable Products / EEPs (EnOcean Equipment Profiles) It is also possible to link TWR-D10 to a central controller or via a gateway to building automation systems like BACnet. Features Include: Dimensions ▪▪ Enables wireless dimming of a single fixture or a zone of Weight multiple daisy chained LED fixtures (e.g. 20 each 30W or 10 each 60W). Mounting ▪▪ Supports California Title 24 daylight harvesting scenarios, occupancy control and manual dimming with input from self-powered wireless switches and sensors. Implements load shedding initiated by separate Demand Response controllers ▪▪ Installs inside or mounts to electrical box using threaded connector ▪▪ Supports wireless remote commissioning to link devices and set parameters Environment Agency Compliance 2 Buttons, 1 LED for device configuration & manual control EnOcean 902 MHz 80 ft. (25 m) D2-40-00 for remote commissioning with Navigan™ Rocker Pad Switch (F6-02-02) Occupancy Sensor (A5-07-01) Occupancy Sensor (A5-07-02) Occupancy Sensor (A5-07-03) Light Level Sensor (A5-06-02) Light Level Sensor (A6-06-03) Central Controller (A5-38-08) Demand Response (A5-37-01) 2.78” H x 1.65” W x 1.1” D (73mm x 42mm x 28mm) 3.2oz. (90g) • Install inside standard electrical box • Connect to electrical boxes and fixtures using threaded nipple • Indoor use only • 32° to 104° F (0° to 60° C) • 20% to 85% relative humidity (non-condensing) ETL, FCC, IC, UL2043 Plenum Rated 1) Planning Take a moment to plan for the module’s successful operation and optimal communication with other system components. ▪▪ Always use a qualified installer ▪▪ Install in an appropriate location © 2015 Thomas Research Products • www.trpssl.com Page 1 ZenNet Dimming Control Module • Installation Guide ▪▪ Take care not to damage the radio antenna, the orange wire 4. Connect the wires using wire nuts and cap any bare wires. NOTE: After the module is linked and configured, you can secure it in the installed location, see step 8. ▪▪ Consider the construction materials in the space 5. Fold the wires neatly and either place the module in the box or secure the threaded connector with the lock nut. that runs in a groove on the outside of the module that runs in a groove on the outside of the module and obstacles that may interfere with RF signals 2) Installing Read and understand instructions completely before starting. 6. Position the module so that the setup interface and antenna face forward (out). TIP: If the RF reception is poor, use the antenna sleeve provided to extend the antenna. ELECTRICAL SHOCK HAZARD 7. Restore power to the circuit. High Voltage. This device must be installed by a qualified installer or electrician. Follow all applicable electrical codes for installation. 8. Use the setup interface to link devices and configure settings (refer to the “Linking” & “Configuring” sections). 1. Turn off power at the circuit breaker or fuse and test that power is off before wiring the device. Warning: Remove the module from the electrical box to use the setup interface. NOTE: Use a non-metal electrical enclosure for best wireless communication performance. 2. Identify the wiring connection at the installation site to coordinate with the following wiring diagram. NOTE: For display purposes, white wire is shown as yellow. Dimming 0-10V Only - + dark grey purple 3) Device Configuration The LED controller can be configured in two ways: ▪▪ By user input to the local setup interface To Electrical Load This approach is used for basic setup tasks ▪▪ Remotely using the remote commissioning interface This approach is used for advanced configuration tasks Power Input black white red Local Setup Interface The local setup interface has two buttons, LRN (O) and DIM. 120VAC/ 277VAC black Hot Neutral white Neutral 3. Determine which of the two installation methods is most appropriate: A. Installed inside the electrical box. NOTE: For best performance, remove the antenna from its slot and elongate it outside and away from the box and conduit. Install tubular sleeve (included) over antenna and slide into relay housing. B. Installed using the threaded connector: i. Insert the threaded connector through a ½” trade size (⅞” diameter) knockout. ii. Thread the 5 module wires inside the electrical box and through the lock nut. LRN (O) has a corresponding 2-color LED (green, red). This simple interface is used to link and unlink transmitters, to dim up and down manually and to set the minimum dimming value. To use the local setup interface, hold the module so both thumbs can click the buttons without obscuring the LED. LRN (O) button Press short to start or end linking/unlinking mode. Press long (>10s) to delete all linked transmitters. LRN (O) LED The LED will toggle red/green every 2 seconds, while in linking/unlinking mode. After linking (unlinking) a device it will stay green (red) for 4 seconds. The connected load will toggle between 10% and 90% dimming level, respectively. DIM (I) button When the button is pressed shortly (
TWC-USB 价格&库存
很抱歉,暂时无法提供与“TWC-USB”相匹配的价格&库存,您可以联系我们找货
