Product Brief:
HDG104-WiFi 802.11b/g System in Package
KEY FEATURES INCLUDE:
APPLICATIONS
Smallest Wi-Fi component in the market: 55mm2
Home Automation
Lowest power consumption solution in the
The HDG104 WiFi solution is pre
market for embedded applications.
integrated on the AVR32 MCU
High RF output TX power (+17dBm) and RX
sensitivity
platform and is perfect match
developers that want to enter the
Supports multiple SW features incl 802.11e/i
(Security, Quality of Service)
home automation market such as
External discrets needed: 19 + antenna
AMR, surveillance, entrance
External chips:40MHz (or from system)
control or general home
Pre-calibrated and programmed with MAC adr.
appliances.
No RF trimming needed
32KHz from host CPU
Industry Sensor Networks
HDG104 WiFi in combination
with AVR32 can easily be
installed and used for Industry
The HDG104 is a complete Wireless LAN System inPackage (SiP) with ultra low power consumption
sensors or remote control thanks
and high supply voltage handling, optimized for
to the pre-integration of the EVK
embedded devices such as wireless sensors for
and the availability of WiFi
industrial and home control , AMR for smart and
infrastructure.
green energy control, remote device management
such as location tracking and the growing segment
of equipment and consumer electronic devices such
Media Applications
as Portable Media devices, IP-radio, home security,
In all media applications the
wireless speakers and IP audio devices.
problem of how to access and
The HDG104 SiP format, with its complete system
change the media is easily
functionality, means quicker design cycles, lower risk
solved with WiFi and with the
and simplified manufacturing, all in a very small
high speed and security
package (7,1× 7,7 mm). Lack of external components
functions of 802.11, media such
simplifies assembly test and reduces yield loss. The
as mp3, IP-radio or video are
• Data Rates: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48,
and 54Mbps
• Modulation: QPSK, 16QAM, 64QAM DBPSK,
DQPSK, CCK, OFDM with BPSK
• WEP and AES hardware encryption accelerator up
to 128 bit.
• On-chip RF filter for the ISM band 2.4GHz
• An internal 32 kHz oscillator maintains real time in
power save mode, allows the high frequency clock to
be turned off.
• Extensive DMA hardware support for data flow to
reduce CPU load.
• Low cost and low power consumption by use of Ultra
Low Power (ULP) technology
• On-board 160 kB SRAM and 1 kB EEPROM
eliminates need for external memory for firmware
• Internal Boot-ROM. This allows firmware to be
downloaded into SRAM from the host
• Advanced power management for optimum power
consumption at varying load.
• External interfaces SDIO and SPI
• Supply voltage 2.75-3.6 V
• RoHS Compliant
HDG104 SiP delivers a complete and fully tested and
trimmed implementation of 802.11b/g functionality.
transferred fast and secure.
The HDG104 is fully FCC and CE compliant, and is
internally tested to meet FCC/CE and a FCC/CE
approval. The HDG104 solution is Pre- tested,
calibrated and certified resulting in lowest possible
production and system cost
“What do you want to connect?”
Product brief HDG104 WLAN 802.11b/g System in Package (SiP), page 1(2)
HDG104 is prepared, fully Tested, Pre-certified
Pre-Integrated on AVR32 MCU platform
TECHNICAL SW/HW
SUPPORT
H&D Wireless provide a unique
SW API (o)WL © - a complete
programming interface for
embedded Wi-Fi applications .
SW API (o)WL©details in H&D
Wireless SW
product brief
Support for the SW drivers,
installation and SW development
is provided by Atmel application
support at www.atmel.com/avr32
Most of ”things” to be connected to Internet use Microcontrollers.
The H&D WiFi solution supported on Atmel MCU platforms will enable
PERFORMANCE OF Wi -Fi
The WiFi solution HDG104 is
New applications with low design costs and quick TTM for Customers!
AVAILABLE
The HDG104 Solution + Atmel AVR 32BIT MCU offers:
best in class and market leader
Pre-tested
in terms of solution size, power
Pre-calibrated
consumption in all modes,
Pre-certified (FCC,ETSI,WiFI)
Pre-integrated onto Atmel MCU’s
transmit/receive range, data
transfer speed and cost.
TURNKEY SOLUTIONS
SERVICES
Technical Support
Software and Setup
Hardware Support
Application Support
Customer application -
HDG104 WLAN 802.11b/g Performance data
development
H&D Wireless AB
Norgegatan 1
164 32 Kista
The reference designs provided
are turnkey solutions that will
work first time and can be
Sweden
Phone +46 (0)8 55 11 84 60
Fax +46 (0)8 750 99 77
modified and used for customers
own products.
ORDER INFORMATION
Part No#: HDG104
For more information on any of
VCC: 2,7-3,6V
our products or services please
Package: Tape&Reel
“What
you
visit do
us on
thewant
Webto
at:connect?”
www.atmel.com/AVR32
www.hd-wireless.se
Rev. C
Product brief HDG104 WLAN 802.11b/g System in Package (SiP), page 2(2)
