XTP9B-DPS-001
XTP9B-DPS-001
    DIGIINTERNATIONAL
    模块
    9XTENDREPLACEMENT,P2MP,RPSMA,
XTP9B-DPS-001 数据手册
XTend vB Radio Frequency (RF) Module User Guide Revision history—90001478 Revision Date Description A December 2015 Baseline release of the document. B May 2016 Added information on the Australian variant. Updated cyclic sleep numbers. Added the HS command. C May 2018 Added note on range estimation. Changed IC to ISED. D June 2019 Added FCC publication 996369 related information. Changes for 2x06 firmware release. E July 2021 Added safety instructions. Trademarks and copyright Digi, Digi International, and the Digi logo are trademarks or registered trademarks in the United States and other countries worldwide. All other trademarks mentioned in this document are the property of their respective owners. © 2021 Digi International Inc. All rights reserved. Disclaimers Information in this document is subject to change without notice and does not represent a commitment on the part of Digi International. Digi provides this document “as is,” without warranty of any kind, expressed or implied, including, but not limited to, the implied warranties of fitness or merchantability for a particular purpose. Digi may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. Warranty To view product warranty information, go to the following website: www.digi.com/howtobuy/terms Customer support Gather support information: Before contacting Digi technical support for help, gather the following information:    Product name and model    Product serial number (s)    Firmware version    Operating system/browser (if applicable)    Logs (from time of reported issue)    Trace (if possible) XTend vB RF Module User Guide 2    Description of issue    Steps to reproduce Contact Digi technical support: Digi offers multiple technical support plans and service packages. Contact us at +1 952.912.3444 or visit us at www.digi.com/support. Feedback To provide feedback on this document, email your comments to techcomm@digi.com Include the document title and part number (XTend vB RF Module User Guide, 90001478 E) in the subject line of your email. XTend vB RF Module User Guide 3 Contents XTend vB RF Module User Guide Applicable firmware and hardware XTend replacement numbers Certification overview Safety instructions XBee modules 10 10 10 10 10 Technical specifications General specifications Performance specifications Networking specifications Power requirements Cyclic sleep current (mA, average) Regulatory conformity summary 13 13 14 14 14 15 Hardware Connect the hardware Mechanical drawings Pin signals DC characteristics (Vcc=2.8-5.5 VDC) Outputs Inputs 17 18 18 21 21 21 Modes Transparent and API operating modes Transparent operating mode API operating mode Additional modes Command mode Binary Command mode Idle mode Receive mode Sleep modes Shutdown mode Transmit mode Enter Command mode XTend vB RF Module User Guide 23 23 23 23 23 23 24 24 24 24 24 24 4 Send AT commands Exit Command mode Enter Binary Command mode Exit Binary Command mode Binary Command mode FAQs Sleep modes Pin Sleep (SM = 1) Serial Port Sleep (SM = 2) Cyclic Sleep Mode (SM = 4 - 8) 25 25 26 26 26 27 28 28 28 Operation Serial interface UART data flow Serial data Flow control Data In (DIN) buffer and flow control Data Out (DO) buffer and flow control 32 32 32 32 33 34 Configure the XTend vB RF Module Configure the device using XCTU 36 Program the XTend vB RF Module Programming examples Connect the device to a PC Modify a device address Restore device defaults Send binary commands Query binary commands 37 37 37 38 38 39 Commands Command mode options AT (Guard Time After) BT (Guard Time Before) CC (Command Sequence Character) CF (Number Base) CN (Exit Command Mode) CT (Command Mode Timeout) E0 (Echo Off) E1 (Echo On) Diagnostic commands %V (Board Voltage) DB (Received Signal Strength) GD (Receive Good Count) HV (Hardware Version) RC (Ambient Power - Single Channel) RE (Restore Defaults) RM (Ambient Power) RP (RSSI PWM Timer) SH (Serial Number High) XTend vB RF Module User Guide 42 42 43 43 43 44 44 45 45 45 46 46 47 47 47 48 48 49 50 5 SL (Serial Number Low) TP (Board Temperature) TR (Transmit Error Count) VL (Firmware Version - Verbose) VR (Firmware Version - Short) WA (Active Warning Numbers) WN (Warning Data) WS (Sticky Warning Numbers) HS (Hardware Series) MAC/PHY commands AM (Auto-set MY) DT (Destination Address) HP (Preamble ID) ID (Network ID) MK (Address Mask) MT (Multi-transmit) MY (Source Address) RN (Delay Slots) RR (Retries) TT (Streaming Limit) RF interfacing commands BR (RF Data Rate) FS (Forced Synch Time) MD (RF Mode) PB (Polling Begin Address) PD (Minimum Polling Delay) PE (Polling End Address) PK (Maximum RF Packet Size) PL (TX Power Level) TX (Transmit Only) Security commands KY (AES Encryption Key) Serial interfacing commands AP (API Enable) BD (Interface Data Rate) CD (GP02 Configuration) CS (GP01 Configuration) FL (Software Flow Control) FT (Flow Control Threshold) NB (Parity) RB (Packetization Threshold) RO (Packetization Timeout) RT (GPI1 Configuration) SB (Stop Bits) Sleep commands FH (Force Wakeup Initializer) HT (Time before Wake-up Initializer) LH (Wakeup Initializer Timer) PW (Pin Wakeup) SM (Sleep Mode) ST (Time before Sleep) Special commands WR (Write) XTend vB RF Module User Guide 50 51 51 51 52 52 53 54 55 55 55 55 56 56 57 57 58 58 59 59 60 60 60 61 62 62 62 63 63 64 64 65 65 65 66 67 68 68 69 69 69 70 71 71 72 72 72 73 73 74 74 75 75 6 API operation API mode overview API frame specifications Calculate and verify checksums Escaped characters in API frames 77 77 79 79 Frame descriptions Modem Status - 0x8A Description Examples 16-bit Transmit Request - 0x01 Description Format Examples Transmit Status - 0x89 Description Delivery status codes Examples 16-bit Receive Packet - 0x81 Description Format Examples 82 82 83 84 84 84 85 86 86 87 87 88 88 88 89 Regulatory information FCC (United States) OEM labeling requirements FCC notices RF exposure statement XTend vB RF Module antenna options FCC publication 996369 related information ISED (Innovation, Science and Economic Development Canada) Labeling requirements Transmitters for detachable antennas Detachable antennas ACMA (Australia) Power requirements 91 91 91 92 93 98 100 100 100 100 101 101 Network configurations Network topologies Point-to-point networks Point-to-multipoint networks Peer to peer networks Addressing Address recognition Basic communications Streaming mode (default) Multi-transmit mode Repeater mode Polling mode (basic) XTend vB RF Module User Guide 103 103 103 104 105 106 106 106 107 108 112 7 Acknowledged communications: Acknowledged mode Acknowledged mode connection sequence Polling mode (acknowledged) 113 113 114 Development Kit Development Kit contents Interface hardware XTIB-R RS-232/485 Interface Board Configuration switch I/O and Power LEDs Serial port RSSI LEDs Power connector XTIB-R DIP switch Adapters NULL Modem Adapter (male-to-male) NULL Modem Adapter (female-to-female) Serial Loopback Adapter Male DB-9 to RJ-45 Adapter Female DB-9 to RJ-45 Adapter Interface protocols RS-232 operation RS-485 (2-wire) operation RS-485 (4-wire) and RS-422 operation XTend vB RF Module User Guide 117 117 118 118 119 119 119 119 119 121 121 122 122 123 123 123 124 126 128 8 XTend vB RF Module User Guide The XTend vB RF Module was engineered to provide customers with an easy-to-use radio frequency (RF) solution that provides reliable delivery of critical data between remote devices. The module transfers a standard asynchronous serial data stream, operates within the ISM 900 MHz frequency band and offers two RF data rates of 10 kb/s and 125 kb/s for the United States and Canada variant. It offers two RF data rates of 10 kb/s and 105 kb/s for the Australia variant. Applicable firmware and hardware XTend replacement numbers Certification overview Safety instructions XTend vB RF Module User Guide 10 10 10 10 9 XTend vB RF Module User Guide Applicable firmware and hardware Applicable firmware and hardware This manual supports the following firmware: n 2xxx It supports the following hardware: n As the name suggests, the XTend vB RF Module is form factor and over the air compatible with our XTend module. XTend replacement numbers The following table provides the part numbers you can use to replace XTend devices with the XTend vB RF Module. Legacy part number Replacement part number XT09-MI XTP9B-DPM-001 XT09-SI XTP9B-DPS-001 XT09-MI-MESH XTP9B-DMM-001 XT09-SI-MESH XTP9B-DMS-001 Certification overview The XTend vB RF Module contains an FCC/IC approved RF module. A separate variant of the XTend vB RF Module contains an Australian approved RF module. For usage requirements, see Regulatory information. ISM (Industrial, Scientific and Medical) license-free 902-928 MHz frequency band. Manufactured under ISO 9001:2000 registered standards. Safety instructions XBee modules n The XBee radio module cannot be guaranteed operation due to the radio link and so should not be used for interlocks in safety critical devices such as machines or automotive applications. n The XBee radio module have not been approved for use in (this list is not exhaustive): n l medical devices l nuclear applications l explosive or flammable atmospheres There are no user serviceable components inside the XBee radio module. Do not remove the shield or modify the XBee in any way. Modifications may exclude the module from any warranty and can cause the XBee radio to operate outside of regulatory compliance for a given country, leading to the possible illegal operation of the radio. XTend vB RF Module User Guide 10 XTend vB RF Module User Guide Safety instructions n Use industry standard ESD protection when handling the XBee module. n Take care while handling to avoid electrical damage to the PCB and components. n Do not expose XBee radio modules to water or moisture. n Use this product with the antennas specified in the XBee module user guides. n The end user must be told how to remove power from the XBee radio module or to locate the antennas 20 cm from humans or animals. XTend vB RF Module User Guide 11 Technical specifications The following tables provide the device's technical specifications. WARNING! When operating at 1 W power output, observe a minimum separation distance of 6 ft (2 m) between devices. Transmitting in close proximity of other devices can damage the device's front end. General specifications Performance specifications Networking specifications Power requirements Regulatory conformity summary XTend vB RF Module User Guide 13 13 14 14 15 12 Technical specifications General specifications General specifications The following table describes the general specifications for the devices. Specification Value Dimensions (RF/pin connectors not included) 3.70 x 6.10 x 0.48 cm (1.457 x 2.402 x 0.190 in) Weight 16 g RoHS Compliant Manufacturing ISO 9001:2000 registered standards Connector 20 pin 2 mm pitch header Antenna connector options MMCX or RPSMA Antenna impedance 50 Ω unbalanced Operating temperature -40 °C to 85 °C Maximum input RF level at antenna port 6 dBm Digital outputs 2 output lines Performance specifications The following table describes the performance specifications for the devices. Note Range figure estimates are based on free-air terrain with limited sources of interference. Actual range will vary based on transmitting power, orientation of transmitter and receiver, height of transmitting antenna, height of receiving antenna, weather conditions, interference sources in the area, and terrain between receiver and transmitter, including indoor and outdoor structures such as walls, trees, buildings, hills, and mountains. Specification Value Frequency range 902 to 928 MHz US/Canada 915 to 928 MHz Australia RF data rate (software selectable) 10 kb/s to 125 kb/s US/Canada 10 kb/s to 105 kb/s Australia Transmit power (software selectable) Up to 30 dBm (see Power requirements) Channels 10 hopping sequences share 50 frequencies Outdoor line of sight 10 kb/s Up to 40 miles1 125 kb/s Up to 7 miles 1Estimated based on a 9 mile range test with dipole antennas. XTend vB RF Module User Guide 13 Technical specifications Networking specifications Specification Value Indoor range line of sight 10 kb/s Up to 1,000 feet (300 m) 125 kb/s Up to 500 feet (150 m) 10 kb/s -110 dBm 125 kb/s -100 dBm Receiver sensitivity UART data rate 1200-230400 baud Networking specifications The following table provides the networking specifications for the device. Specification Value Modulation Frequency Shift Keying Spread Spectrum Frequency Hopping Spread Spectrum (FHSS) Supported Network Topologies (software selectable) Peer-to-peer (master/slave relationship not required), point-topoint/point-to-multipoint Encryption 256-bit or 128-bit AES CBC encryption depending on region. 256-bit is only available on the North America variant. 128-bit is only available on international variants. Power requirements The following table describes the power requirements for the XTend vB RF Module. Specifications are given at 5 V, 25 °C unless otherwise noted. Requirement Value Supply voltage 2.8 to 5.5 VDC, 5 V typical Receive current @5V Transmit current See the following table Shutdown mode current 1 µA Sleep current < 147 µA 35 mA Cyclic sleep current (mA, average) Sleep mode Cycle time RF data rate Cyclic sleep current (mA, average) SM = 8 16 seconds BR = 0 0.65 XTend vB RF Module User Guide 14 Technical specifications Sleep mode SM = 7 SM = 6 SM = 5 SM = 4 Regulatory conformity summary Cycle time 8 seconds 4 seconds 2 seconds 1 second RF data rate Cyclic sleep current (mA, average) BR = 1 0.23 BR = 0 1.13 BR = 1 0.31 BR = 0 2.06 BR = 1 0.46 BR = 0 3.77 BR = 1 0.77 BR = 0 6.68 BR = 1 1.36 Transmit power level 21.5 dBm 27 dBm 30 dBm Supply voltage range 2.8 to 5.5 V 3.2 to 5.5 V 4.75 to 5.5 V Transmit current (5 V, typical) 260 mA 570 mA 710 mA Transmit current (3.3 V, typical) 435 mA N/A N/A Regulatory conformity summary This table describes the agency approvals for the devices. Nation Approval United States Contains FCC ID: MCQ-XBPSX Canada Contains IC: 1846A-XBPSX Australia RCM XTend vB RF Module User Guide 15 Hardware Connect the hardware Mechanical drawings Pin signals DC characteristics (Vcc=2.8-5.5 VDC) XTend vB RF Module User Guide 17 18 18 21 16 Hardware Connect the hardware Connect the hardware The following figure shows the XTend vB RF Module and accessories you need to get started and how to connect them. The accessories are in the XT09-DK development kit. Item Description 1 Antenna, RPSMA (female) 2 XTend vB module, RPSMA version shown 3 DIP switches 4 9 V power supply 5 DB9 serial cable XTend vB RF Module User Guide 17 Hardware Mechanical drawings Mechanical drawings The following drawings show the dimensions of the device. Pin signals The following drawing shows the location of the pins. When integrating the module with a Host PC board, leave all lines that you do not use disconnected (floating). I/O High impedance during Must shutdown connect Function GND - - yes Ground VCC I - yes Power: 2.8 - 5.5 VDC Pin number Name 1 2 XTend vB RF Module User Guide 18 Hardware Pin signals Pin number Name I/O High impedance during Must shutdown connect 3 GPO2 / RXLED O - yes GPO2: General Purpose Output. Default (CD = 2) drives this pin low. RX LED: Pin is driven high during RF data reception; otherwise, the pin is driven low. To enable this pin, see CD (GP02 Configuration). 4 TX _PWR O yes - Transmit_Power: Pin pulses low during RF transmission; otherwise, the pin is driven high to indicate power is on and the device is not in Sleep or Shutdown Mode. 5 DIN I yes yes Data In: Serial data entering the device (from the UART host). For more information, see . 6 DOUT O yes - Data Out: Serial data exiting the module (to the UART host). For more information, see . 7 SHDN I no yes Shutdown: Drive this pin high to enable normal operation and low during Shutdown. Shutdown enables the lowest power mode available to the module. 8 SLEEP I yes - SLEEP: By default, SLEEP is not used. To configure this pin to enable Sleep modes, refer to Sleep modes, SM (Sleep Mode) and PW (Pin Wakeup). 9 GPO1 / CTS / RS- O 485 TX_EN yes - GPO1: General Purpose Output. Pin can be driven low or high. CTS (Clear-to-Send): CTS is enabled by default. When the pin is driven low, the UART host is permitted to XTend vB RF Module User Guide Function 19 Hardware Pin number Pin signals Name I/O High impedance during Must shutdown connect Function send serial data to the device. For more information, see and CS (GP01 Configuration). RS-485 Transmit Enable: Enables RS-485 half and fullduplex communications. For more information, see and CS (GP01 Configuration). 10 RTS / CMD I yes - RTS (Request-to-Send): Not used by default. This pin can be configured to allow the UART host to regulate the flow of serial data exiting the module. For more information, see and RT (GPI1 Configuration). 11 CONFIG / RSSI I1 no - Configuration: Pin can be used as a backup method for entering Command mode during power-up. O2 no - Receive Signal Strength Indicator: By default, pin is used as an RSSI PWM output after at the conclusion of the power-up sequence. The line is also pulled high when the device goes to sleep. The PWM output is 2.8 Vlevel. For more information, see RP (RSSI PWM Timer). 12 - 20 Reserved / do not connect 1The RF module has a 10 kΩ internal pull-up resistor. 2The RF module has a 10 kΩ internal pull-up resistor. XTend vB RF Module User Guide 20 Hardware DC characteristics (Vcc=2.8-5.5 VDC) DC characteristics (Vcc=2.8-5.5 VDC) Outputs Pin number Pin name VOH minimum (IOH = -6 mA) VOL maximum (IOL = 6 mA) 3 GPO2 / RXLED VCC – 0.7 V 0.55 V 4 TX _PWR VCC – 0.7 V 0.55 V 6 DOUT VCC – 0.7 V 0.55 V 9 GPO1 / CTS / RS-485 TX_ EN VCC – 0.7 V 0.55 V 111, 2 CONFIG / RSSI 2.2 V 0.5 V Inputs Pin number Pin name VIH minimum VIL maximum 5 DIN VCC * 0.75 VCC * 0.25 7 SHDN VCC * 0.75 0.7 V 8 SLEEP VCC * 0.75 VCC * 0.25 10 RTS / CMD VCC * 0.75 VCC * 0.25 113, 4 CONFIG / RSSI VCC * 0.75 VCC * 0.25 1The RF Module has an internal 10 kΩ pull-up resistor to VCC. 2When the line is enabled for use as RSSI PWM output and not CONFIG input. RSSI signal is a 2.8 V level PWM signal. 3The RF Module has an internal 10 kΩ pull-up resistor to VCC. 4When the line is enabled for use as CONFIG input and not RSSI PWM output. XTend vB RF Module User Guide 21 Modes The XTend vB RF Module is in Receive Mode when it is not transmitting data. The device shifts into the other modes of operation under the following conditions: n Transmit mode (Serial data in the serial receive buffer is ready to be packetized) n Sleep mode n Command Mode (Command mode sequence is issued) Transparent and API operating modes Additional modes Sleep modes XTend vB RF Module User Guide 23 23 27 22 Modes Transparent and API operating modes Transparent and API operating modes The firmware operates in several different modes. Two top-level modes establish how the device communicates with other devices through its serial interface: Transparent operating mode and API operating mode. Transparent operating mode Devices operate in this mode by default. The device acts as a serial line replacement when it is in Transparent operating mode. The device queues all UART data it receives through the DIN pin for RF transmission. When a device receives RF data, it sends the data out through the DOUT pin. API operating mode API operating mode is an alternative to Transparent operating mode. API mode is a frame-based protocol that allows you to direct data on a packet basis. The device communicates UART data in packets, also known as API frames. This mode allows for structured communications with computers and microcontrollers. The advantages of API operating mode include: n It is easier to send information to multiple destinations n The host receives the source address for each received data frame n You can change parameters without entering Command mode n You can query or set a configuration parameter while a pending command—for example ND—is in progress. This cannot be done in Command mode. For more information, see API frame specifications. Additional modes In addition to the serial communication modes, several modes apply to how to configure devices and how devices communicate with each other. Command mode Command mode is a state in which the firmware interprets incoming characters as commands. Command mode allows you to modify the device’s firmware using parameters you can set using AT commands. When you want to read or set any setting of the device, you have to send it an AT command. Every AT command starts with the letters "AT" followed by the two characters that identify the command the device sends and then by some optional configuration values. For more details, see Enter Command mode. Binary Command mode Binary Command mode allows you to configure a device at a faster rate than AT commands will allow. Using binary commands to send and receive parameter values is the fastest way to change the operating parameters of the device. Use binary commands to: n Sample signal strength and/or error counts; n Change device addresses and channels for polling systems when a quick response is necessary. For more details, see Enter Binary Command mode and DB (Received Signal Strength). XTend vB RF Module User Guide 23 Modes Additional modes Idle mode When not receiving or transmitting data, the device is in Idle mode. During Idle mode, the device listens for valid data on the serial port. Receive mode If a destination node receives a valid RF packet, the destination node transfers the data to its serial transmit buffer. For the serial interface to report receive data on the RF network, that data must meet the following criteria: n ID match n Channel match n Address match Sleep modes Sleep Modes enable the device to enter states of low-power consumption when not in use. The device supports three software sleep modes: n Pin Sleep: the host controls this n Serial Port Sleep: wakes when it detects serial port activity n Cyclic Sleep: wakes when it detects RF activity For more information, see Sleep modes. Shutdown mode Shutdown mode offers the lowest power mode available to the device. This is helpful for applications that must keep power consumption to a minimum during idle periods. When you drive the SHDN pin (pin 7) low, it forces the device into Shutdown mode. This halts any communication in progress (transmit or receive) and any buffered data is lost. For any other mode of operation, you must drive or pull SHDN high. Immediately after the SHDN pin changes states from low to high, the device resets. After reset, the application must observe a delay time of SM) In the following figure, the length of the wake-up initializer exceeds the time interval of Cyclic Sleep. The receiver is guaranteed to detect the wake-up initializer and receive the accompanying payload data. The LH (Wakeup Initializer Timer) is only enabled if the HT (Time before Wake-up Initializer) is nondefault. The Wakeup Initializer is resent at the beginning of every packet unless the HT is set. Set HT less than or equal to the ST (Time before Sleep) such that once the XTend vB RF Module has received the Wakeup Initializer, another Wakeup Initializer need not be sent again until the expiration of the ST has expired. Incorrect configuration (LH < SM) Length of wake-up initializer is shorter than the time interval of Cyclic Sleep. This configuration is vulnerable to the receiver waking and missing the wake-up initializer (and therefore also the accompanying payload data). XTend vB RF Module User Guide 29 Modes XTend vB RF Module User Guide Sleep modes 30 Operation WARNING! When operating at 1 W power output, observe a minimum separation distance of 6 ft (2 m) between devices. Transmitting in close proximity of other devices can damage the device's front end. Serial interface UART data flow Serial data Flow control XTend vB RF Module User Guide 32 32 32 32 31 Operation Serial interface Serial interface The XTend vB RF Module interfaces to a host device through a TTL-level asynchronous serial port. Through its serial port, the XTend vB RF Module can communicate with any UART voltage compatible device or through a level translator to any serial device, for example: RS-232/485/422 or a USB interface board. UART data flow Devices that have a UART interface connect directly to the pins of the XTend vB RF Module as shown in the following figure. The figure shows system data flow in a UART-interfaced environment. Lowasserted signals have a horizontal line over the signal name. Serial data A device sends data to the XTend vB RF Module's UART through pin 5 DIN as an asynchronous serial signal. When the device is not transmitting data, the signals should idle high. For serial communication to occur, you must configure the UART of both devices (the microcontroller and the XTend vB RF Module) with compatible settings for the baud rate, parity, start bits, stop bits, and data bits. Each data byte consists of a start bit (low), 8 data bits (least significant bit first) and a stop bit (high). The following diagram illustrates the serial bit pattern of data passing through the device. The diagram shows UART data packet 0x1F (decimal number 31) as transmitted through the device. Flow control The RTS and CTS device pins provide RTS and/or CTS flow control. CTS flow control signals the host to stop sending serial data to the device. RTS flow control lets the host signal the device so it will not send the data in the serial transmit buffer out the UART. The following diagram shows the internal data flow, with the five most common pin signals. XTend vB RF Module User Guide 32 Operation Flow control The firmware has Hardware flow control (CTS) configured by default. You must configure CTS flow control on the host side for it to work. You must configure Software flow control (XON) on both the host and device side for it to work. If you change the CS command from 0, then CTS flow control will not work even if you have it configured on the host. Data In (DIN) buffer and flow control When serial data enters the device through the DIN pin (pin 5), it stores the data in the DIN buffer until it can process the data. When the firmware satisfies the RB and RO parameter thresholds, the device attempts to initialize an RF transmission. If the device is already receiving RF data, it stores the serial data in the device's DIN buffer. The device creates and transmits data packets when it meets one of the following conditions: 1. The device does not receive any serial characters for the amount of time set with in the RO command; see RO (Packetization Timeout). 2. The device receives the maximum number of characters that fits in an RF packet. 3. The device receives the Command Mode sequence. If the DIN buffer becomes full, you must implement hardware or software flow control in order to prevent overflow (loss of data between the host and the device). To eliminate the need for flow control: 1. Send messages that are smaller than the DIN buffer size. The size of the DIN buffer varies according to the packet size (PK parameter) and the parity setting (NB parameter) you use. 2. Interface at a lower baud rate (BD parameter) than the RF data rate of the firmware (BR parameter) of the firmware. In the following situations, the DIN buffer may become full and overflow: 1. If you set the serial interface data rate higher than the RF data rate of the device, the device receives data from the host faster than it can transmit the data over-the-air. 2. If the device receives a continuous stream of RF data or if the device monitors data on a network, it places any serial data that arrives on the DIN pin (pin 5) in the DIN buffer. It transmits the data in the DIN buffer over-the-air when the device no longer detects RF data in the network. XTend vB RF Module User Guide 33 Operation Flow control Hardware flow control (CTS) The firmware asserts CTS before the DIN buffer is full so it has time to send the signal and the host has time to stop sending data. When the DIN buffer is full, the firmware de-asserts CTS (high) to signal the host to stop sending data; refer to FT (Flow Control Threshold) and CS (GP01 Configuration). The firmware re-asserts CTS after the DIN buffer has 34 bytes of memory available. Hardware flow control (RTS) If you enable RTS for flow control (RT parameter = 2), the device will not send data out the DOUT buffer as long as the RTS pin (pin 10) is de-asserted. Software flow control (XON/OFF) Use FL to enable XON/XOFF software flow control. This option only works with ASCII data. Data Out (DO) buffer and flow control When a device receives RF data, the data enters the DOUT buffer and the device sends it out the serial port to a host device. Once the DOUT buffer reaches capacity, it loses any additional incoming RF data. The DOUT buffer stores at least 2.1 kB. In the following situations, the DOUT buffer may become full and overflow: 1. If the RF data rate is set higher than the interface data rate of the device, the devices receives data from the transmitting device faster than it can send the data to the host. 2. If the host does not allow the device to transmit data out from the DOUT buffer because of being held off by hardware or software flow control. Hardware flow control (RTS) If you enable RTS for flow control (RT = 2), data will not be sent out the DO Buffer as long as RTS (pin 16) is de-asserted. Software flow control (XOFF) You can enable XON/XOFF software flow control using FL (Software Flow Control). This option only works with ASCII data. XTend vB RF Module User Guide 34 Configure the XTend vB RF Module Configure the device using XCTU XTend vB RF Module User Guide 36 35 Configure the XTend vB RF Module Configure the device using XCTU Configure the device using XCTU XBee Configuration and Test Utility (XCTU) is a multi-platform program that enables users to interact with Digi radio frequency (RF) devices through a graphical interface. The application includes built-in tools that make it easy to set up, configure, and test Digi RF devices. For instructions on downloading and using XCTU, see the XCTU User Guide. Click Discover devices and follow the instructions. XCTU should discover two XTend vB RF Modules. Click Add selected devices. The devices appear in the Radio Modules list. You can click a module to view and configure its individual settings. For more information on these items, see Commands. XTend vB RF Module User Guide 36 Program the XTend vB RF Module Programming examples For steps on sending AT commands to a device, refer to: n Send AT commands n Exit Command mode For more information, refer to the XCTU online help at: docs.digi.com/display/XCTU/XCTU+Overview Connect the device to a PC The programming examples that follow require the installation of XCTU and a serial connection to a PC. Digi stocks connector boards to facilitate interfacing with a PC. 1. Download XCTU from the Digi website: digi.com/products/xbee-rf-solutions/xctu-software/xctu#resources 2. After the .exe file downloads to the PC, double-click the file to launch the XCTU Setup Wizard. Follow the steps in the wizard to completely install XCTU. 3. Mount the device to an interface board, then connect the assembly to a PC. 4. Launch XCTU and click the Add devices tab on the upper left corner of the screen. 5. Verify that the baud rate and parity settings of the Serial/USB port match those of the device. Note Failure to enter Command mode is commonly due to baud rate mismatch. Ensure that the Baud Rate: setting on the Add radio device window matches the interface data rate of the device. By default, the BD parameter = 9600 b/s. Modify a device address The following programming example shows you how to modify the device's destination address. 1. Once you add the device in XCTU, click on it in the Radio Modules pane to display the Configuration working mode. This mode shows most of the device’s parameters that you can edit. 2. Scroll down in the Radio Configuration pane until you find the parameter you want to edit, in this case DT (Destination Address), or use the search box and type DT. XCTU automatically scrolls to the selected parameter. XTend vB RF Module User Guide 37 Program the XTend vB RF Module Programming examples 3. When you locate the parameter, change its value, for example to 1A0D. If you do not save the parameter, the color of the surrounding container is light green. 4. Click the write button to save the value to non-volatile memory; it is the pencil icon to the right of the parameter . If you change other parameters but have not saved them, you can use the Write radio settings button to save them. It is the white and blue pencil icon on the top of the configuration panel . Restore device defaults The following programming example shows you how to restore a device's default parameters. 1. After establishing a connection between the device and a PC click the Configuration working mode tab of XCTU . 2. Click the Load default firmware settings button and agree to restore the default values. The button is the factory icon . 3. The restored parameters have a light green surrounding color, which means that they have been changed but not saved. 4. Click the Write module settings button to save all of the parameters simultaneously. 5. All the parameters surrounding box must change to gray indicating that their values are now saved in the device's non-volatile memory. Send binary commands Example Use XCTU's Serial Console tool to change the device's DT (Destination Address) parameter and save the new address to non-volatile memory. This example requires XCTU and a serial connection to a PC. To send binary commands: 1. Set the RT command to 1 to enable binary command programming; do this in Command mode or configure it through XCTU. 2. Drive pin 10 high to assert CMD by de-asserting the RTS line in XCTU. The device enters Binary Command mode. 3. Send hexadecimal bytes (parameter bytes must be 2 bytes long). The next four lines are examples, not required values: 00 (Send binary command DT) 0D (Least significant byte of parameter bytes) 1A (Most significant byte of parameter bytes) 08 (Send binary command WR) 4. Drive pin 10 low to de-assert CMD. After you send the commands, CTS (pin 9) de-asserts (driven low) temporarily. The device exits Binary Command mode. The default flow control is NONE, so if you are using XCTU, CTS is not an issue. However, you can still observe the behavior of the CTS line by monitoring the CTS indicator in the terminal or console. XTend vB RF Module User Guide 38 Program the XTend vB RF Module Programming examples Query binary commands Example: use XCTU's Serial Console tool to query the device's DT (Destination Address) and DB (Received Signal strength) parameters. In order to query a parameter instead of setting it, you must logically OR the binary command byte with 0x80. 1. Set the RT command to 1 to enable binary command programming. To do this, you must either be in Command mode or use XCTU to configure the device. 2. Assert CMD by driving pin 29 high. To do this de-assert the RTS line in XCTU. 3. Send hexadecimal bytes: 80 (Binary command DT (0x00) OR'ed with 0x80) B6 (Binary command DB (0x36) OR'ed with 0x80) 4. Read the device's output for the parameter values of the two commands. 5. De-assert CMD by driving pin 29 low. The device exits Binary Command mode. When querying commands in binary command mode, the output is the least significant byte followed by the most significant byte and is always represented in hexadecimal values. XTend vB RF Module User Guide 39 Commands The following table lists the AT and binary commands in the XTend vB RF Module firmware and links to the description of the individual command. By default, the device expects numerical values in hexadecimal since the default value of the CF (Number Base) Parameter is 1. Hexadecimal values are designated by the 0x prefix and decimal values by the d suffix. AT command Binary command %V (Board Voltage) 0x3B (59d) AM (Auto-set MY) 0x41 (65d) AP (API Enable) -- AT (Guard Time After) 0x05 (5d) BD (Interface Data Rate) 0x15 (21d) BR (RF Data Rate) 0x39 (57d) BT (Guard Time Before) 0x04 (4d) CC (Command Sequence Character) 0x13 (19d) CD (GP02 Configuration) 0x28 (40d) CF (Number Base) -- CN (Exit Command Mode) 0x09 (9d) CS (GP01 Configuration) 0x1F (31d) CT (Command Mode Timeout) 0x06 (6d) DB (Received Signal Strength) 0x36 (54d) DT (Destination Address) 0x00 (0d) E0 (Echo Off) 0x0A (10d) E1 (Echo On) 0x0B (11d) ER (Receive Count Error) 0x0F (15d) FH (Force Wakeup Initializer) 0x0D (13d) XTend vB RF Module User Guide 40 Commands AT command Binary command FL (Software Flow Control) 0x07 (7d) FS (Forced Synch Time) 0x3F (63d) FT (Flow Control Threshold) 0x24 (36d) GD (Receive Good Count) 0x10 (16d) HP (Preamble ID) 0x11 (17d) HS (Hardware Series) -- HT (Time before Wake-up Initializer) 0x03 (3d) HV (Hardware Version) -- ID (Network ID) 0x27 (39d) KY (AES Encryption Key) 0x43 (67d) LH (Wakeup Initializer Timer) 0x0C (12d) MD (RF Mode) 0x31 (49d) MK (Address Mask) 0x12 (18d) MT (Multi-transmit) 0x3E (62d) MY (Source Address) 0x2A (42d) NB (Parity) 0x23 (35d) PB (Polling Begin Address) 0x45 (69d) PD (Minimum Polling Delay) 0x47 (71d) PE (Polling End Address) 0x46 (70d) PK (Maximum RF Packet Size) 0x29 (41d) PL (TX Power Level) 0x3A (58d) PW (Pin Wakeup) 0x1D (29d) RB (Packetization Threshold) 0x20 (32d) RC (Ambient Power - Single Channel) -- RE (Restore Defaults) 0x0E (14d) RM (Ambient Power) -- RN (Delay Slots) 0x19 (25d) RO (Packetization Timeout) 0x21 (33d) RP (RSSI PWM Timer) 0x22 (34d) RR (Retries) 0x18 (24d) XTend vB RF Module User Guide 41 Commands Command mode options AT command Binary command RT (GPI1 Configuration) 0x16 (22d) SB (Stop Bits) 0x37 (55d) SH (Serial Number High) 0x25 (37d) SL (Serial Number Low) 0x26 (38d) SM (Sleep Mode) 0x01 (1d) ST (Time before Sleep) 0x02 (2d) TP (Board Temperature) 0x38 (56d) TR (Transmit Error Count) 0x1B (27d) TT (Streaming Limit) 0x1A (26d) TX (Transmit Only) 0x40 (64d) VL (Firmware Version - Verbose) -- VR (Firmware Version - Short) 0x14 (20d) WA (Active Warning Numbers) -- WN (Warning Data) -- WR (Write) 0x08 (8d) WS (Sticky Warning Numbers) -- Command mode options The following commands are Command mode option commands. AT (Guard Time After) This command applies to the XTend vB RF Module. Sets or displays the time-of-silence that follows the CC (Command Sequence Character) of the Command mode sequence (BT + CC + AT). By default, one second must elapse before and after the command sequence character. The times-of-silence surrounding the Command Sequence Character prevent the device from inadvertently entering Command mode. Binary command 0x05 (5 decimal) Parameter range 0x2 - 0x1770 [x 100 ms] Default 0xA (1 second) XTend vB RF Module User Guide 42 Commands Command mode options Bytes returned 2 BT (Guard Time Before) This command applies to the XTend vB RF Module. Sets the DI pin silence time that must precede the Command Sequence Character (CC command) of the Command mode sequence. Binary command 0x04 (4 decimal) Parameter range 0 - 0x1770 [x 100ms] Default 0x0A (1 second) Bytes returned 2 CC (Command Sequence Character) This command applies to the XTend vB RF Module. Sets or displays the character the device uses between guard times of the AT Command mode sequence. The AT Command mode sequence causes the device to enter Command Mode (from Idle Mode). Binary command 0x13 (19 decimal) Parameter range 0x20 - 0x7F Default 0x2B (ASCII “+”) Bytes returned 1 CF (Number Base) This command applies to the XTend vB RF Module. Sets or displays the command formatting setting. The firmware always enters and reads the following commands in hex, no matter what the CF setting is: VR (Firmware Version) HV (Hardware Version) KY (AES Encryption Key) XTend vB RF Module User Guide 43 Commands Command mode options Binary command N/A Command type Command mode options Parameter range 0-2 Parameter Configuration 0 Commands use the default number base; decimal commands may output units. 1 All commands are forced to unsigned, unit-less hex. 2 Commands use their default number base; no units are output. Default 1 Bytes returned 1 CN (Exit Command Mode) This command applies to the XTend vB RF Module. Makes the device exit Command mode. Binary command 0x09 (9 decimal) Parameter range N/A Default N/A Bytes returned N/A CT (Command Mode Timeout) This command applies to the XTend vB RF Module. Set or read the Command mode timeout parameter. If a device does not receive any valid commands within this time period, it returns to Idle mode from Command mode. Use the CN (Exit Command mode) command to exit Command mode manually. Binary command 0x06 (6 decimal) XTend vB RF Module User Guide 44 Commands Diagnostic commands Parameter range 0x2 - 0x53E2 [x 100 milliseconds] Default 0xC8 (20 seconds) Bytes returned 2 E0 (Echo Off) This command applies to the XTend vB RF Module. Turns off the character echo in Command mode. By default, echo is off. Binary command 0x0A (10 decimal) Parameter range N/A Default N/A Bytes returned N/A E1 (Echo On) This command applies to the XTend vB RF Module. Enables character echo in Command mode. Each character that you type echoes back to the terminal when E1 is active. E0 (Echo Off) is the default. Binary command 0x0B (11 decimal) Parameter range N/A Default N/A Bytes returned N/A Diagnostic commands The following AT commands are diagnostic commands. Diagnostic commands are typically volatile and will not persist across a power cycle. XTend vB RF Module User Guide 45 Commands Diagnostic commands %V (Board Voltage) Reads the supply voltage to the module's VCC (pin 2). The conversion of the hex value returned by %V to Volts is VAL/65536 = Volts. Example: 2.8 VDC = 2.8 * 65536 = 0x2CCCD 3.3 VDC = 3.3 * 65536 = 0x34CCD Sample output 3.27 V (when CF = 0) 345E3 (when CF = 1) 1 3.27 (when CF = 2) Binary command 0x3B (59 decimal) Parameter range [read-only]: 0x2CCCA - 0x5BFFA (2.80 to 5.75 V) Default N/A Bytes returned 4 DB (Received Signal Strength) This command applies to the XTend vB RF Module. This command reports the received signal strength of the last received RF data packet or APS acknowledgment. The DB command only indicates the signal strength of the last hop. It does not provide an accurate quality measurement for a multihop link. The DB command value is measured in -dBm. For example, if DB returns 0x50, then the RSSI of the last packet received was -80 dBm. Set DB to 0 to clear the current value, and it will be updated with the next valid packet received. Parameter range Observed ranges: XBee-PRO - 0x1A - 0x58 XBee- 0x1A - 0x5C Default 0x80000 1When CF = 1 (default), the firmware shows a hex integer that is equal to (voltage * 65536d). XTend vB RF Module User Guide 46 Commands Diagnostic commands GD (Receive Good Count) This command applies to the XTend vB RF Module. Sets or displays the number of RF packets with valid MAC headers that the device receives successfully on the RF interface. When the value reaches 0xFFFF, it stays there until you manually change the maximum count value or reset the device. Its parameter value is reset to 0 after every device reset and is not non-volatile; the parameter value does not persist in the device's memory after a power-up sequence. Pin, serial port or cyclic sleep modes do not reset the GD parameter. Parameter range 0 - 0xFFFF Default 0 Bytes returned 2 HV (Hardware Version) This command applies to the XTend vB RF Module. Reads the device's hardware version number. Binary command N/A Command type Diagnostics Parameter range [read-only]: 0 - 0xFFFF Default N/A Bytes returned N/A RC (Ambient Power - Single Channel) This command applies to the XTend vB RF Module. Reads and reports the power level on a given channel. Sample output -78 dBm (when CF = 0) 4e (when CF = 1) -78 (when CF = 2) XTend vB RF Module User Guide 47 Commands Diagnostic commands Binary command N/A Parameter range [read-only]: 0 - 0x31 [dBm] Default N/A Bytes returned 1 RE (Restore Defaults) This command applies to the XTend vB RF Module. Restore device parameters to factory defaults. RE does not cause the device to store default values to non-volatile (persistent) memory. You must send the WR command prior to power-down or reset to save the default settings in the device's nonvolatile memory. Binary command 0x0E (14 decimal) Parameter range N/A Default N/A Bytes returned N/A RM (Ambient Power) This command applies to the XTend vB RF Module. Reads and reports power levels on all channels. If you do not provide a parameter, the device scans the channels one time. If you do provide a parameter, the device scans the channels repeatedly for the number of seconds that the parameter calls for. The firmware reports the maximum power level seen for each channel (in other words, peak hold). To implement a graphical spectrum analyzer, repeatedly send RM with no arguments and read the resulting 50 power levels. This is easiest to do when CF = 1 or 2. Sample output when CF = 0: Ch 0: -100 dBm Ch 1: -103 dBm ... Ch 49: -99 dBm XTend vB RF Module User Guide 48 Commands Diagnostic commands Sample output when CF = 1: 64 64 67 ... 63 Sample output when CF = 2: 100 100 -103 ... -99 Binary command N/A Command type Diagnostics Parameter range no parameter - 0x7D0 Default N/A Bytes returned 2 RP (RSSI PWM Timer) This command applies to the XTend vB RF Module. Enables a pulse-width modulated (PWM) output on the CONFIG /RSSI pin (pin 11). We calibrate the pin to show the difference between received signal strength and the sensitivity level of the device. PWM pulses vary from zero to 95 percent. Zero percent means the RF signal the device receives is at or below the device's sensitivity level. The following table shows dB levels above sensitivity and PWM values. The total time period of the PWM output is 8.32 ms. PWM output consists of 40 steps, so the minimum step size is 0.208 ms. dB above sensitivity PWM percentage (high period / total period) 10 30% 20 45% 30 60% A non-zero value defines the time that PWM output is active with the RSSI value of the last RF packet the device receives. After the set time when the device has not received RF packets, it sets the PWM output low (0 percent PWM) until the device receives another RF packet. It also sets PWM output low XTend vB RF Module User Guide 49 Commands Diagnostic commands at power-up. A parameter value of 0xFF permanently enables PWM output and always reflects the value of the last received RF packet. The PWM output and Config input share the CONFIG /RSSI pin. When the device is powered, the Config pin is an input. During the power-up sequence, if RP is a non-zero value, the firmware configures the Config pin as an output and sets it low until the device receives the first RF packet. With a non-zero RP parameter, the CONFIG pin is an input for RP ms after power up. Binary command 0x22 (34 decimal) Parameter range 0 - 0xFF [x 100 ms] Default 0x20 (3.2 seconds) Bytes returned 1 SH (Serial Number High) This command applies to the XTend vB RF Module. Displays the device's serial number high word. Binary command 0x25 (37 decimal) Parameter range 0x0 - 0xFFFF [read-only] Default Varies Bytes returned 2 SL (Serial Number Low) This command applies to the XTend vB RF Module. Displays the serial number low word of the device. Binary command 0x26 (38 decimal) Parameter range 0 - 0xFFFF [read-only] Default Varies XTend vB RF Module User Guide 50 Commands Diagnostic commands Bytes returned 2 TP (Board Temperature) This command applies to the XTend vB RF Module. The current module temperature in degrees Celsius in 8-bit two’s compliment format. For example 0x1A = 26 °C, and 0xF6 = -10 °C. Sample output 26 C when CF = 0 1A when CF = 1 26 when CF = 2 Binary command 0x38 (56 decimal) Parameter range 0 - 0x7F [read-only] Default N/A Bytes returned 1 TR (Transmit Error Count) This command applies to the XTend vB RF Module. Reads the number of RF packets where retries expire without receiving an ACK (when RR > 0). Binary command 0x1B (27 decimal) Parameter range 0 - 0xFFFF Default 0 Bytes returned 2 VL (Firmware Version - Verbose) This command applies to the XTend vB RF Module. Reads the verbose firmware version of the device. XTend vB RF Module User Guide 51 Commands Diagnostic commands Binary command N/A Parameter range Returns a string Default 0 Bytes returned 2 VR (Firmware Version - Short) This command applies to the XTend vB RF Module. Reads the firmware version on a device. Firmware versions contain four significant digits: A.B.C.D. If B = 2, the device is programmed for operation in Australia only. Binary command 0x14 (20 decimal) Parameter range [read-only]: 0 - 0xFFFF Default N/A Bytes returned 2 WA (Active Warning Numbers) This command applies to the XTend vB RF Module. Reports the warning numbers of all active warnings, one warning number per line. It does not show further information and does not reset warning counts. For information on what the warning numbers mean, see WN (Warning Data). Sample output (indicates warnings 1 and 3 are currently active) 1 3 OK Binary command N/A Command type Diagnostics XTend vB RF Module User Guide 52 Commands Diagnostic commands Parameter range Returns a string: one warning number per line. Default N/A Bytes returned N/A WN (Warning Data) This command applies to the XTend vB RF Module. Reports the following data for all active and sticky warnings: n Warning number and description n Number of occurrences since the last WN or WS command n Whether the warning is currently active WN does not display warnings that are not currently active and have not been active since the last issuance of the WN or WS commands. WN resets all non-zero warning counts except for warnings that are presently active, which are set to 1. Sample output Warning 4: Over-temperature 5 occurrences; presently inactive. Warning # Description 1 Under-voltage. This is caused if the supply voltage falls below the minimum threshold for the lowest power level (2.8 V). If/when the voltage rises above the threshold, the warning is deactivated. The device does not transmit below this voltage threshold. 2 Deprecated. 3 Under-temperature. This is caused if the temperature sensed by the device is less than 40° C. The device does not artificially limit operation while this warning is active, but device functionality is not guaranteed. 4 Over-temperature. This is caused if the temperature sensed by the device is greater than 105° C. The device does not allow transmission nor reception while this warning is active. The warning is deactivated when the temperature falls below 100° C. 5 Power reduced. This is caused if the transmit power has to be reduced from the level programmed by PL due to insufficient supply voltage. PL4: 30 dBm (1 Watt) power level requires 4.75 V or higher. PL3: 27 dBm (500 mW) power level requires 3.2 V or higher. PL2 - PL0: 21.5 dBm (100 mW) power levels require 2.8 V or higher. 6 Deprecated. 7 Default configuration parameters in flash. This is caused if user-modifiable parameters XTend vB RF Module User Guide 53 Commands Diagnostic commands Warning # Description (i.e. those stored by WR) in flash are all the compiled-in default values. This is caused if the user configuration is found to be not present or invalid at power-up and there is no custom configuration, or if no user-modifiable parameters have been modified from the compiled-in defaults. Modification of one or more parameters without the subsequent WR to commit the changes to flash will not deactivate this warning, since it reflects the status of the parameters in flash. This warning does not reflect usage of the custom configuration defaults, only usage of the compiled-in defaults. 8 Default factory configuration parameters in flash. This is caused if the factory parameters in flash are all the default values. This is caused if the factory configuration is found to be not present or invalid at power-up, or if no factory parameters have been modified. 9 Watchdog reset occurred. 10 PK was reduced by BR. 11 RB was reduced by PK. 12 One or more parameters overridden due to conflict. Binary command N/A Command type Diagnostics Parameter range Returns a string Default N/A Bytes returned N/A WS (Sticky Warning Numbers) This command applies to the XTend vB RF Module. Reports warning numbers of all warnings active since the last use of WS or WN, including any warnings that are currently active. WS also resets all non-zero warning counts, except for warnings that are presently active, which are set to 1. Binary command N/A Command type Diagnostics XTend vB RF Module User Guide 54 Commands MAC/PHY commands Parameter range [read-only]: 1 - 8 Default N/A Bytes returned 1 The following AT commands are firmware commands. HS (Hardware Series) This command applies to the XTend vB RF Module. Read the device's hardware series number. Parameter range N/A Default 0x2A00 - set in the firmware MAC/PHY commands The following AT commands are MAC/PHY commands. AM (Auto-set MY) This command applies to the XTend vB RF Module. Sets the MY (Source Address) parameter from the factory-set serial number of the device. The address consists of bits 29, 28 and 13-0 of the serial number, in that order. Sending AM displays the address. Binary command 0x41 (65 decimal) Parameter range N/A Default N/A Bytes returned N/A DT (Destination Address) This command applies to the XTend vB RF Module. Sets or displays the networking address of a device. The devices use three filtration layers: XTend vB RF Module User Guide 55 Commands MAC/PHY commands n Vendor ID Number (ID) n Channel (HP) n Destination Address (DT) Binary command 0x00 (0 decimal) Parameter range 0 - 0xFFFF Default 0 Bytes returned 2 HP (Preamble ID) This command applies to the XTend vB RF Module. Set or read the device's hopping channel number. A channel is one of three layers of filtration available to the device. In order for devices to communicate with each other, the devices must have the same channel number since each channel uses a different hopping sequence. Devices can use different channels to prevent devices in one network from listening to transmissions of another. When a device receives a packet it checks HP before the network ID, as it is encoded in the preamble and the network ID is encoded in the MAC header. Binary command 0x11 (17 decimal) Parameter range 0-9 Default 0 Bytes returned 1 ID (Network ID) This command applies to the XTend vB RF Module. Sets or displays the Vendor Identification Number (VID) of the device. Devices must have matching VIDs in order to communicate. If the device uses OEM network IDs, 0xFFFF uses the factory value. Binary command 0x27 (39 decimal) XTend vB RF Module User Guide 56 Commands MAC/PHY commands Parameter range 0x10 - 0x7FFF (user-settable) 0 - 0x9 and 0x8000 - 0xFFFF (factory-set) Default 0x3332 N/A Bytes returned 2 MK (Address Mask) This command applies to the XTend vB RF Module. Sets or read the device's Address Mask. All RF data packets contain the Destination Address of the transmitting (TX) device. When a device receives a packet, the TX device's Destination Address is logically combined bitwise (in other words, joined with AND) with the Address Mask of the receiving (RX) device. The resulting value must match the Destination Address or Address Mask of the RX device for the packet to be received and sent out the RX device's DO (Data Out) pin. If the combined value does not match the Destination Address or Address Mask of the RX device, it discards the packet. The firmware treats all 0 values as irrelevant and ignores them. For more information, see Addressing. Binary command 0x12 (18 decimal) Parameter range 0 - 0xFFFF Default 0xFFFF Bytes returned 2 MT (Multi-transmit) Enables multiple transmissions of RF data packets. When you enable Multi-transmit mode (MT > 0), packets do not request an ACK from the receiving devices. MT takes precedence over RR, so if both MT and RR are non-zero, then a device sends MT+1 packets with no ACK requests. When a receiving device receives a packet with remaining forced retransmissions, it calculates the length of the packet and inhibits transmission for the amount of time required for all retransmissions. From that time on, the device inserts a random number of delay slots between 0 and RN before allowing transmission from the receiving devices. This prevents all listening devices from transmitting at once upon conclusion of a multiple transmission event (when RN > 0). Note The actual number of forced transmissions is the parameter value plus one. For example, if MT = 1, a devices sends two transmissions of each packet. For more information, see Multi-transmit mode. XTend vB RF Module User Guide 57 Commands MAC/PHY commands Binary command 0x3E (62d) Command type MAC/PHY Parameter range 0 - 0xFF Default 0 (no forced retransmissions) Bytes returned 1 MY (Source Address) This command applies to the XTend vB RF Module. Sets or displays the Source Address of a device. For more information, see DT (Destination Address) and Addressing. Binary command 0x2A (42 decimal) Parameter range 0 - 0xFFFF Default 0xFFFF (Disabled - DT (Destination Address) parameter serves as both source and destination address). Bytes returned 2 RN (Delay Slots) This command applies to the XTend vB RF Module. Sets or displays the time delay that the transmitting device inserts before attempting to resend a packet. If the transmitting device fails to receive an acknowledgment after sending a packet, it inserts a random number of delay slots (ranging from 0 to (RN minus 1)) before attempting to resend the packet. Each delay slot is 5 ms when BR = 1 and 54 ms when BR = 0. If two devices attempt to transmit at the same time, the random time delay after packet failure only allows one device to transmit the packet successfully, while the other device waits until the channel is available for RF transmission. RN is only applicable if: n You enable retries using the RR command, or n You insert forced delays into a transmission using the TT command XTend vB RF Module User Guide 58 Commands MAC/PHY commands Binary command 0x19 (25 decimal) Parameter range 0 - 0xFF [38 ms delay slots] Default 0 (no delay slots inserted) Bytes returned 1 RR (Retries) This command applies to the XTend vB RF Module. Sets or displays the maximum number of retries sent for a given RF packet. When you enable RR (RR > 0), it enables RF packet retries and ACKs. After transmitting a packet, the transmitting device waits to receive an ACK from a receiving device. If it does not receive the ACK in the time that RN specifies, it transmits the original packet again. The transmitting device transmits the RF packet repeatedly until it receives an ACK or until it sends the packet RR times. Note You must have retries enabled for all modules in the network for retries to work. Binary command 0x18 (24 decimal) Parameter range 0 - 0xFF Default 0x0A (10 decimal) Bytes returned 1 TT (Streaming Limit) This command applies to the XTend vB RF Module. Sets or displays the limit on the number of bytes that a device can send before issuing a random delay. If a device is sending a continuous stream of RF data, it inserts a delay that stops its transmission and gives other devices time to transmit once it sends TT bytes of data. The random delay it inserts lasts between 1 and RN + 1 delay slots . You can use TT to simulate full-duplex behavior. Binary command 0x1A (26 decimal) XTend vB RF Module User Guide 59 Commands RF interfacing commands Parameter range 0 - 0xFFFF [bytes] Default 0 Bytes returned 2 RF interfacing commands The following AT commands are RF interfacing commands. BR (RF Data Rate) This command applies to the XTend vB RF Module. Sets and reads the device's RF data rate (the rate at which the device transmits and receives RF data over-the-air). Binary command 0x39 (57 decimal) Parameter range 0-1 Parameter RF data rate 0 10 kb/s 1 125 kb/s Default 1 Bytes returned 1 FS (Forced Synch Time) This command applies to the XTend vB RF Module. The FS command only applies to streaming data. Normally, only the first packet of a continuous stream contains the full RF initializer. The RF devices then remain synchronized for subsequent packets of the stream. You can use this parameter to periodically force an RF initializer during such streaming. Any break in UART character reception that is long enough to drain the DI buffer and cause a pause in RF data transmission also causes the firmware to insert an RF initializer on the next transmission. Binary command 0x3F (63 decimal) XTend vB RF Module User Guide 60 Commands RF interfacing commands Command type RF interfacing Parameter range 0 - 0xFFFF [x 10 milliseconds] Default 0 Bytes returned 2 MD (RF Mode) This command applies to the XTend vB RF Module. Sets or displays the settings that enable the Polling and Repeater modes on the device. Polling Mode: a Polling Base is responsible for polling remotes. A Polling Remote requires a poll from a Polling Base in order to transmit. Repeater Mode: a Repeater re-sends RF data unless the transmission is addressed to it or if it has already detected the transmission. A Repeater End Node handles repeated messages, but will not repeat the message over-the-air. For more information, see Basic communications. Binary command 0x31 (49 decimal) Parameter range 0-6 Parameter Configuration 0 Transparent Operation (Repeater Base) 1 Reserved - not used 2 Reserved - not used 3 Polling Base 4 Polling Remote 5 Repeater 6 Repeater End Node Default 0 Bytes returned 1 XTend vB RF Module User Guide 61 Commands RF interfacing commands PB (Polling Begin Address) Sets or displays the device’s Polling Begin Address, which is the first address polled when you enable Polling mode. Binary command 0x45 (69 decimal) Command type RF interface Parameter range 0 - 0xFFFF Default 0 Bytes returned 2 PD (Minimum Polling Delay) Sets or displays the Polling Delay (Base, MD = 3) or Polling Timeout (Remote, MD = 4). Polling Delay (Base) is the time between polling cycles. The Polling Base starts the polling cycle after sending the first poll. After the polling cycle completes, the timer restarts. Polling Timeout (Remote) is the amount of time the remote device holds data from the serial port before discarding it. The device transmits data entered within the PD time of the poll and does not discard it. Binary command 0x47 (71 decimal) Command type RF interface Parameter range 0 - 0xFFFF (Base: [x 1ms], Remote: [x 10ms]) Default 0x64 Bytes returned 2 PE (Polling End Address) Sets or displays the device’s Polling End Address; which is the last address polled when you enable Polling mode. Binary command 0x46 (70 decimal) XTend vB RF Module User Guide 62 Commands RF interfacing commands Command type RF interface Parameter range 0 - 0xFFFF Default 0 Bytes returned 2 PK (Maximum RF Packet Size) This command applies to the XTend vB RF Module. Sets or displays the maximum size of RF packets that a device in Transparent operating mode (AP = 0) transmits. You can use the maximum packet size along with the RB and RO parameters to implicitly set the channel dwell time. Changes to the PK parameter may have a secondary effect on the RB (Packetization Threshold) parameter. RB must always be less than or equal to PK. If you change PK to a value that is less than the current value of RB, the RB value lowers to be equal to PK. Binary command 0x29 (41 decimal) Parameter range 1 - 0x800 [Bytes] Default 0x100 (BR = 0) 0x800 (BR = 1)1 Bytes returned 2 PL (TX Power Level) This command applies to the XTend vB RF Module. Sets or displays the power level at which the device transmits conducted power. Binary command 0x3A (58 decimal) Parameter range 0-4 1When BR = 0 (9600 baud), the maximum PK value is 0x100 (256 bytes). When BR = 1 (115,200 baud), the maximum PK value is 0x800 (2048 bytes). XTend vB RF Module User Guide 63 Commands Security commands Parameter Configuration PL0 21.5 dBm PL1 PL2 PL3 27 dBm PL4 30 dBm (1 Watt) Default 4 Bytes returned 1 TX (Transmit Only) This command applies to the XTend vB RF Module. Sets or displays the transmit or receive behaviors of the device. Setting a device to TX-only (TX = 1) may reduce latency because the you can not limit the transmitting device to receiving data from other devices. Binary command 0x40 (64d) Command type RF Interfacing Parameter range 0-1 Parameter Description 0 TX and RX 1 TX only Default 0 Bytes returned 1 Security commands The following AT commands are security commands. XTend vB RF Module User Guide 64 Commands Serial interfacing commands KY (AES Encryption Key) This command applies to the XTend vB RF Module. Sets the 256-bit Advanced Encryption Standard (AES) key for encrypting or decrypting data. Once set, you cannot read the key out of the device by any means. The firmware encrypts the entire payload of the packet using the key and computes the CRC across the ciphertext. When you enable encryption, each packet carries an additional 16 bytes to convey the random cipher-block chaining (CBC) Initialization Vector (IV) to the receiver(s). Set 256-bit key (64 hex digits) on multiple devices for encrypted RF communication. Set to 0 to disable encryption. Reading the parameter returns a 0 (encryption disabled) or 1 (enabled). The key cannot be read for security reasons. A device with the wrong key (or no key) receives encrypted data, but the data driven out the serial port is meaningless. Likewise, a device with a key receives unencrypted data sent from a device without a key, but the output is meaningless. Because it uses CBC mode, repetitive data appears differently in different transmissions due to the randomly-generated IV. Note For international (non-U.S.) variants of XTC devices, the encryption key is 128-bit AES. The command operates the same except the key length is 16 bytes rather than 32 bytes. This pertains to part numbers ending with 128, no matter which firmware version is loaded. This also pertains to the Australia version of firmware 22xx. Binary command 0x43 (67d) Command type Security Parameter range 0 - (64 hex digits all set to 'F') Default 0 (disabled) Bytes returned 2 Serial interfacing commands The following AT commands are serial interfacing commands. AP (API Enable) This command applies to the XTend vB RF Module. Set or read the API mode setting. The device can format the RF packets it receives into API frames and send them out the serial port. When you enable API, you must format the serial data as API frames because Transparent operating mode is disabled. Enables API Mode. The device ignores this command when using SPI. API mode 1 is always used. Parameter range 0-2 XTend vB RF Module User Guide 65 Commands Serial interfacing commands Parameter Description 0 Transparent mode, API mode is off. All UART input and output is raw data and the device uses the RO and RB parameters to delineate packets. 1 API Mode Without Escapes. The device packetizes all UART input and output data in API format, without escape sequences. 2 API Mode With Escapes. The device is in API mode and inserts escaped sequences to allow for control characters. The device passes XON (0x11), XOFF (0x13), Escape (0x7D), and start delimiter 0x7E as data. Default 0 Bytes returned 1 BD (Interface Data Rate) This command applies to the XTend vB RF Module. Sets and reads the serial interface data rate (baud rate) between the device and the host. The baud rate is the rate that the host sends serial data to the device. When you make an update to the interface data rate, the change does not take effect until the host issues the CN command and the device returns the OK response. The BD parameter does not affect the RF data rate. If you set the interface data rate higher than the RF data rate, you may need to implement a flow control configuration. Non-standard interface data rates The firmware interprets any value within 0x4B0 - 0x2580 and 0x4B00 - 0x1C9468 as an actual baud rate. When the host sends a value above 0x4B0, the firmware stores the closest interface data rate represented by the number in the BD register. For example, to set a rate of 19200 b/s, send the following command line: ATBD4B00. Note When using XCTU, you can only set and read non-standard interface data rates using the XCTU Serial Console tool. You cannot access non-standard rates through the configuration section of XCTU. Note The device does not support nonstandard baud rates between 9601 and 19199 baud. If you attempt to set baud rates in this range, it will return an error. When you send the BD command with a non-standard interface data rate, the UART adjusts to accommodate the interface rate you request. In most cases, the clock resolution causes the stored BD parameter to vary from the sent parameter. Sending ATBD without an associated parameter value returns the value actually stored in the device’s BD register. The following table provides the parameters sent versus the parameters stored. Binary command 0x15 (21 decimal) XTend vB RF Module User Guide 66 Commands Serial interfacing commands Parameter ranges Parameter Configuration (b/s) 0 1200 1 2400 2 4800 3 9600 4 19200 5 38400 6 57600 Default 3 Bytes returned 4 CD (GP02 Configuration) This command applies to the XTend vB RF Module. Selects or reads the behavior of the GPO2 line (pin 3). Binary command 0x28 (40 decimal) Parameter range 0-4 Parameter Configuration 0 RX LED 1 Static high 2 Static low 3 Reserved 4 RX LED (valid address only) Default 2 Bytes returned 1 XTend vB RF Module User Guide 67 Commands Serial interfacing commands CS (GP01 Configuration) This command applies to the XTend vB RF Module. Sets or displays the behavior of the GPO1 line (pin 9). This output can provide RS-232 flow control and controls the TX enable signal for RS-485 or RS-422 operations. By default, GP01 provides RS-232 Clear-to-Send (CTS ) flow control. Binary command 0x1F (31 decimal) Parameter range 0-4 Parameter Configuration 0 RS-232 CTS flow control 1 RS-485 TX enable low 2 Static high 3 RS-485 TX enable high 4 Static low Default 0 Bytes returned 1 FL (Software Flow Control) This command applies to the XTend vB RF Module. The XON character used is 0x11 (17 decimal). The XOFF character used is 0x13 (19 decimal). Binary command 0x07 (7 decimal) Parameter range 0-1 Default 0 Bytes returned 1 XTend vB RF Module User Guide 68 Commands Serial interfacing commands FT (Flow Control Threshold) This command applies to the XTend vB RF Module. Sets or displays the flow control threshold. De-assert CTS when the number of bytes specified by the FT parameter are in the DIN buffer. Reassert CTS when less than FT - 16 bytes are in the UART receive buffer. Binary command 0x24 (36 decimal) Parameter range 0x11 - 0xC00 [bytes] Default 0xBBF (DI buffer size minus 0x11) Bytes returned 2 NB (Parity) This command applies to the XTend vB RF Module. Set or read the parity settings for UART communications. Parameter range Parameter Configuration 0 8-bit (no parity ) 1 8-bit even 2 8-bit odd 3 8-bit mark 4 8-bit space Default 0 Bytes returned 1 RB (Packetization Threshold) This command applies to the XTend vB RF Module. Sets or displays the character threshold value. RF transmission begins after a device receives data in the DIN buffer and meets either of the following criteria: XTend vB RF Module User Guide 69 Commands Serial interfacing commands n The UART receives RB characters n The UART receive lines detect RO character times of silence after receiving at least 1 byte of data If a device lowers PK below the value of RB, RB is automatically lowered to match the PK value. If RO = 0, the device must receive RB bytes before beginning transmission. RB and RO criteria only apply to the first packet of a multi-packet transmission. If data remains in the DIN buffer after the first packet, transmissions continue in a streaming manner until there is no data left in the DIN buffer. Binary command 0x20 (32 decimal) Parameter range 0 - PK parameter value (up to 0x800 bytes) Default 0x800 (2048 bytes) Bytes returned 2 RO (Packetization Timeout) This command applies to the XTend vB RF Module. Set or read the number of character times of inter-character silence required before transmission begins. For information on how RO works with the RB command, see RB (Packetization Threshold). When RO is the transmission-beginning criteria: The actual time between the reception of the last character from the UART and the beginning of RF transmission is at least 800 µsec longer than the actual RO time to allow for transmission setup. It is also subject to 100-200 µsec of additional uncertainty, which could be significant for small values of RO at high UART bit rates. The firmware calculates the correct UART character time (10, 11, or 12 bits) based on the following criteria: n 1 start bit n 8 data bits n 0 or 1 parity bit (as determined by the NB command) n 1 or 2 stop bits (as determined by SB command) Binary command 0x21 (33 decimal) Parameter range 0 - 0x53E2 [x UART character times] Default 3 XTend vB RF Module User Guide 70 Commands Serial interfacing commands Bytes returned 2 RT (GPI1 Configuration) This command applies to the XTend vB RF Module. Sets or displays the behavior of the GPI1 pin (pin 10) of the device. You can configure the pin to enable Binary Command mode or RTS flow control. Binary command 0x16 (22 decimal) Parameter range 0-2 Parameter Configuration 0 Disabled 1 Binary Command enable 2 RTS flow control enable Default 0 (disabled) Bytes returned 1 SB (Stop Bits) This command applies to the XTend vB RF Module. Sets or displays the number of stop bits in the data packet. Binary command 0x37 (55 decimal) 0x36 (54 decimal) Parameter range 0-1 Parameter Configuration 0 One stop bit 1 Two stop bits Default 0 XTend vB RF Module User Guide 71 Commands Sleep commands Bytes returned 1 Sleep commands The following AT commands are sleep commands. FH (Force Wakeup Initializer) This command applies to the XTend vB RF Module. Forces the device to send a wake-up initializer on the next transmission. Only use FH with cyclic sleep modes active on remote devices. You do not need to issue the WR (Write) command with FH. Binary command 0x0D (13 decimal) Parameter range N/A Default N/A Bytes returned N/A HT (Time before Wake-up Initializer) This command applies to the XTend vB RF Module. Sets or displays the time of inactivity (no serial or RF data is sent or received) before a transmitting (TX) RF device sends a wake-up initializer. The main purpose of this command is to prevent devices from sending the Long Header with every data packet. For more information on long headers, see LH (Wakeup Initializer Timer). For RX devices operating in Cyclic Sleep mode (SM = 4-8), set HT to be shorter than the ST command. The TX device sends a wake-up initializer, which instructs all receiving (RX) devices to remain awake to receive RF data. From the perspective of the RX device: after HT time elapses and the inactivity timeout (ST command) is met, the RX device goes into cyclic sleep. In cyclic sleep, the RX device wakes once per sleep interval (SM command) to check for a wake-up initializer. When it detects a wake-up initializer, the device stays awake to receive data. The wake-up initializer must be longer than the cyclic sleep interval to ensure that sleeping devices detect incoming data. When HT time elapses, the TX device knows it needs to send a wake-up initializer for all RX devices to remain awake and receive the next transmission. Binary command 0x03 (3 decimal) Parameter range 0 - 0x53E2, 0xFFFF [x 100 ms] XTend vB RF Module User Guide 72 Commands Sleep commands Default 0xFFFF (wake-up initializer will not be sent) Bytes returned 2 LH (Wakeup Initializer Timer) This command applies to the XTend vB RF Module. Sets or displays the duration of time during which the wake-up initializer is sent. When receiving devices are in Cyclic Sleep Mode, they power-down after a period of inactivity as specified by the ST parameter and will periodically wake and listen for data transmissions. In order for the receiving devices to remain awake, they must detect ~35 ms of the wake-up initializer. You must use LH whenever a receiving device is operating in Cyclic Sleep mode. The wake-up initializer time must be longer than the cyclic sleep time, which is set by the SM (Sleep Mode) parameter. If the wake-up initializer time is less than the Cyclic Sleep interval, the connection is at risk of missing the wake-up initializer transmission. Binary command 0x0C (12 decimal) Parameter range 0 - 0xFF [x100 milliseconds] Default 1 Bytes returned 1 PW (Pin Wakeup) This command applies to the XTend vB RF Module. Enables or disables the sleep pin. Under normal operation, a device in Cyclic Sleep mode cycles from an active state to a low-power state at regular intervals until it is ready to receive data. If you set PW to 1, you can use the SLEEP pin (pin 26) to wake the device from Cyclic Sleep. When you de-assert (low) the SLEEP pin, the device is operational and will not go into Cyclic Sleep. Once you assert the SLEEP pin, the device remains active for the period of time specified by the ST parameter and returns to Cyclic Sleep mode if no data is ready to transmit. PW is only valid if Cyclic Sleep is enabled. Binary command 0x1D (29 decimal) Parameter range 0-1 XTend vB RF Module User Guide 73 Commands Sleep commands Parameter Configuration 0 Disabled 1 Enabled Default 0 Bytes returned 1 SM (Sleep Mode) This command applies to the XTend vB RF Module. Sets or displays the device's sleep mode settings, which configure the device to run in states that require minimal power consumption. Binary command 0x01 Parameter range 0 - 8 (3 is reserved) Parameter Description 0 Disabled 1 Pin Sleep 2 Serial Port Sleep 3 [reserved] 4 Cyclic 1 second sleep (RF module wakes every 1.0 seconds) 5 Cyclic 2 second sleep 6 Cyclic 4 second sleep 7 Cyclic 8 second sleep 8 Cyclic 16 second sleep Default 0 Bytes returned 1 ST (Time before Sleep) This command applies to the XTend vB RF Module. XTend vB RF Module User Guide 74 Commands Special commands You can only use this command if you use SM to select Cyclic Sleep or Serial Port Sleep mode settings; see SM (Sleep Mode). Binary command 0x02 (2 decimal) Parameter range (AT + 3) - 0x53E2 [x 100 ms] Default 0x64 (10 seconds) Bytes returned 2 Special commands The following commands are special commands. WR (Write) This command applies to the XTend vB RF Module. Writes parameter values to non-volatile memory so that parameter modifications persist through subsequent resets. If you make changes without writing them to non-volatile memory, the device reverts to previously saved parameters the next time it is powered on. If the non-volatile user configuration is not correct, WR will re-attempt up to three times. If all three attempts fail, the command returns an ERROR alert. Binary command 0x08 Command type Special Parameter range N/A Default N/A Bytes returned N/A XTend vB RF Module User Guide 75 API operation API mode overview XTend vB RF Module User Guide 77 76 API operation API mode overview API mode overview By default, the XTend vB RF Module acts as a serial line replacement (Transparent operation), it queues all UART data that it receive through the DI pin for RF transmission. When the device receives an RF packet, it sends the data out the DO pin with no additional information. The following behaviors are inherent to Transparent operation: n If device parameter registers are to be set or queried, a special operation is required for transitioning the device into Command Mode; refer to Enter Command mode. n In point-to-multipoint systems, the host application must send XTend vBa if the receiving device(s) need to distinguish between data coming from different remotes. API operating mode is an alternative to transparent mode. API mode is a frame-based protocol that allows you to direct data on a packet basis. It can be particularly useful in large networks where you need to control the destination of individual data packets or when you need to know which node a data packet was sent from. The device communicates UART data in packets, also known as API frames. This mode allows for structured communications with serial devices. It is helpful in managing larger networks and is more appropriate for performing tasks such as collecting data from multiple locations or controlling multiple devices remotely. API frame specifications The firmware supports two API operating modes: without escaped characters and with escaped characters. Use the AP command to enable either mode. To configure a device to one of these modes, set the following AP parameter values: AP command setting Description AP = 0 Transparent operating mode, UART serial line replacement with API modes disabled. This is the default option. AP = 1 API operation. AP = 2 API operation with escaped characters (only possible on UART). The API data frame structure differs depending on what mode you choose. The firmware silently discards any data it receives prior to the start delimiter. If the device does not receive the frame correctly or if the checksum fails, the device discards the frame. API operation (AP parameter = 1) We recommend this API mode for most applications. The following table shows the data frame structure when you enable this mode: Frame fields Byte Description Start delimiter 1 0x7E Length 2-3 Most Significant Byte, Least Significant Byte Frame data 4-n API-specific structure Checksum n+1 1 byte XTend vB RF Module User Guide 77 API operation API mode overview API operation-with escaped characters (AP parameter = 2) Set API to 2 to allow escaped control characters in the API frame. Due to its increased complexity, we only recommend this API mode in specific circumstances. API 2 may help improve reliability if the serial interface to the device is unstable or malformed frames are frequently being generated. When operating in API 2, if an unescaped 0x7E byte is observed, it is treated as the start of a new API frame and all data received prior to this delimiter is silently discarded. For more information on using this API mode, refer to the following knowledge base article: http://knowledge.digi.com/articles/Knowledge_Base_Article/Escaped-Characters-and-API-Mode-2 The following table shows the structure of an API frame with escaped characters: Frame fields Byte Description Start delimiter 1 0x7E Length 2-3 Most Significant Byte, Least Significant Byte Characters escaped if needed Frame data 4-n API-specific structure Checksum n+1 1 byte Escape characters When sending or receiving a UART data frame, you must escape (flag) specific data values so they do not interfere with the data frame sequencing. To escape an interfering data byte, insert 0x7D and follow it with the byte to be escaped XOR’d with 0x20. If not escaped, 0x11 and 0x13 are sent as is. Data bytes that need to be escaped: n 0x7E – Frame delimiter n 0x7D – Escape n 0x11 – XON n 0x13 – XOFF Example - Raw UART data frame (before escaping interfering bytes): 0x7E 0x00 0x02 0x23 0x11 0xCB 0x11 needs to be escaped which results in the following frame: 0x7E 0x00 0x02 0x23 0x7D 0x31 0xCB Note In the previous example, the length of the raw data (excluding the checksum) is 0x0002 and the checksum of the non-escaped data (excluding frame delimiter and length) is calculated as: 0xFF - (0x23 + 0x11) = (0xFF - 0x34) = 0xCB. Start delimiter This field indicates the beginning of a frame. It is always 0x7E. This allows the device to easily detect a new incoming frame. Length Frame data This field contains the information that a device receives or will transmit. The structure of frame data depends on the purpose of the API frame: XTend vB RF Module User Guide 78 API operation API mode overview Frame data Start delimiter Frame type Length 1 2 3 4 0x7E MSB LSB API frame type Checksum Data 5 6 7 8 9 ... n Data n+1 Single byte n Frame type is the API frame type identifier. It determines the type of API frame and indicates how the Data field organizes the information. n Data contains the data itself. This information and its order depend on the what type of frame that the Frame type field defines. Checksum Calculate and verify checksums To calculate the checksum of an API frame: 1. Add all bytes of the packet, except the start delimiter 0x7E and the length (the second and third bytes). 2. Keep only the lowest 8 bits from the result. 3. Subtract this quantity from 0xFF. To verify the checksum of an API frame: 1. Add all bytes including the checksum; do not include the delimiter and length. 2. If the checksum is correct, the last two digits on the far right of the sum equal 0xFF. Example Escaped characters in API frames If operating in API mode with escaped characters (AP parameter = 2), when sending or receiving a serial data frame, specific data values must be escaped (flagged) so they do not interfere with the data frame sequencing. To escape an interfering data byte, insert 0x7D and follow it with the byte to be escaped (XOR'ed with 0x20). The following data bytes need to be escaped: n 0x7E: start delimiter n 0x7D: escape character n 0x11: XON n 0x13: XOFF To escape a character: 1. Insert 0x7D (escape character). 2. Append it with the byte you want to escape, XOR'ed with 0x20. In API mode with escaped characters, the length field does not include any escape characters in the frame and the firmware calculates the checksum with non-escaped data. XTend vB RF Module User Guide 79 API operation API mode overview Example: escape an API frame To express the following API non-escaped frame in API operating mode with escaped characters: Frame Data Start delimiter Length Frame type Checksum Data 7E 00 0F 17 01 00 13 A2 00 40 AD 14 2E FF FE 02 4E 49 6D You must escape the 0x13 byte: 1. Insert a 0x7D. 2. XOR byte 0x13 with 0x20: 13 ⊕20 = 33 The following figure shows the resulting frame. Note that the length and checksum are the same as the non-escaped frame. Frame Data Start delimiter Length Frame type Checksum Data 7E 00 0F 17 01 00 7D 33 A2 00 40 AD 14 2E FF FE 02 4E 49 6D The length field has a two-byte value that specifies the number of bytes in the frame data field. It does not include the checksum field. XTend vB RF Module User Guide 80 Frame descriptions The following sections describe the API frames. Modem Status - 0x8A 16-bit Transmit Request - 0x01 Transmit Status - 0x89 16-bit Receive Packet - 0x81 XTend vB RF Module User Guide 82 84 86 88 81 Modem Status - 0x8A Description This frame type is emitted in response to specific conditions. The status field of this frame indicates the device behavior. Format Frame Field Offset Size 0 8-bit 1 16-bit Length 3 8-bit Frame type Modem Status - 0x8A 4 8-bit Modem status Start Delimiter XTend vB RF Module User Guide Description Indicates the start of an API frame. Number of bytes between the length and checksum. Complete list of modem statuses: 0x00 = Hardware reset or power up 0x01 = Watchdog timer reset 0x02 = Joined network 0x03 = Left network 0x06 = Coordinator started 0x07 = Network security key was updated 0x0B = Network woke up 0x0C = Network went to sleep 0x0D = Voltage supply limit exceeded 0x0E = Digi Remote Manager connected 0x0F = Digi Remote Manager disconnected 0x11 = Modem configuration changed while join in progress 0x12 = Access fault 0x13 = Fatal error 0x3B = Secure session successfully established 0x3C = Secure session ended 0x3D = Secure session authentication failed 0x3E = Coordinator detected a PAN ID conflict but took no action 0x3F = Coordinator changed PAN ID due to a conflict 0x32 = BLE Connect 0x33 = BLE Disconnect 0x34 = Bandmask configuration failed 0x35 = Cellular component update started 0x36 = Cellular component update failed 0x37 = Cellular component update completed 82 Frame descriptions Offset Modem Status - 0x8A Size Frame Field Description 0x38 = XBee firmware update started 0x39 = XBee firmware update failed 0x3A = XBee firmware update applying 0x40 = Router PAN ID was changed by coordinator due to a conflict 0x42 = Network Watchdog timeout expired 0x80 through 0xFF = Stack error Refer to the tables below for a filtered list of status codes that are appropriate for specific devices. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Boot status When a device powers up, it returns the following API frame: 7E 00 02 8A 00 75 Frame type Modem Status 0x8A 0x00 Status Hardware Reset XTend vB RF Module User Guide 83 Frame descriptions 16-bit Transmit Request - 0x01 16-bit Transmit Request - 0x01 Response frame: Transmit Status - 0x89 Description This frame type is used to send serial payload data as an RF packet to a remote device with a corresponding 16-bit network address. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Transmit Request - 0x10 to initiate API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 16-bit Transmit Request - 0x01 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to 0, the device will not emit a response frame. 5 16-bit Destination address Set to the 16-bit network address of the destination device. If set to 0xFFFF, the broadcast address is used. 7 8-bit Options A bit field of options that affect the outgoing transmission: n Bit 0: Disable MAC ACK [0x01] n Bit 1: Reserved (set to 0) n Bit 2: Send packet with Broadcast PAN ID [0x04] l 802.15.4 firmwares only Note Option values may be combined. Set all unused bits to 0. 8-n variable RF data The serial data to be sent to the destination. Use NP to query the maximum payload size that can be supported based on current settings. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). XTend vB RF Module User Guide 84 Frame descriptions 16-bit Transmit Request - 0x01 Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 16-bit unicast Sending a unicast transmission to a device with the 16-bit address of 1234 with the serial data "TxData". The corresponding Transmit Status - 0x89 response with a matching Frame ID will indicate whether the transmission succeeded. 7E 00 0B 01 87 12 34 00 54 78 44 61 74 61 EB Frame type Frame ID 16-bit dest address Tx options RF data 0x01 0x87 0x1234 0x00 0x547844617461  Input Matches response "TxData" 16-bit broadcast Sending a broadcast transmission of the serial data "Broadcast" and suppressing the corresponding response by setting Frame ID to 0. 7E 00 0E 01 00 FF FF 00 42 72 6F 61 64 63 61 73 74 6D Frame type Frame ID 16-bit dest address Tx options RF data 0x01 0x00 0xFFFF 0x00 0x42726F616463617374 Input Suppress response Broadcast address XTend vB RF Module User Guide "Broadcast" 85 Frame descriptions Transmit Status - 0x89 Transmit Status - 0x89 Request frames: n 64-bit Transmit Request - 0x00 n 16-bit Transmit Request - 0x01 Description This frame type is emitted when a transmit request completes. The status field of this frame indicates whether the request succeeded or failed and the reason. This frame is only emitted if the Frame ID in the request is non-zero. Note Broadcast transmissions are not acknowledged and always return a status of 0x00, even if the delivery failed. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Field Offset Size 0 8-bit 1 16-bit Length 3 8-bit Frame type Transmit Status - 0x89 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 8-bit Delivery status Complete list of delivery statuses: 0x00 = Success 0x01 = No ACK received 0x02 = CCA failure 0x03 = Indirect message unrequested 0x04 = Transceiver was unable to complete the transmission 0x21 = Network ACK failure 0x22 = Not joined to network 0x2C = Invalid frame values (check the phone number) 0x31 = Internal error 0x32 = Resource error - lack of free buffers, timers, etc. 0x34 = No Secure Session Connection 0x35 = Encryption Failure 0x74 = Message too long 0x76 = Socket closed unexpectedly 0x78 = Invalid UDP port 0x79 = Invalid TCP port Start Delimiter XTend vB RF Module User Guide Description Indicates the start of an API frame. Number of bytes between the length and checksum. 86 Frame descriptions Offset Transmit Status - 0x89 Size Frame Field Description 0x7A = Invalid host address 0x7B = Invalid data mode 0x7C = Invalid interface. 0x7D = Interface not accepting frames. 0x7E = A modem update is in progress. Try again after the update is complete. 0x80 = Connection refused 0x81 = Socket connection lost 0x82 = No server 0x83 = Socket closed 0x84 = Unknown server 0x85 = Unknown error 0x86 = Invalid TLS configuration (missing file, and so forth) 0x87 = Socket not connected 0x88 = Socket not bound Refer to the tables below for a filtered list of status codes that are appropriate for specific devices. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Delivery status codes Protocol-specific status codes follow Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Successful transmission Host sent a unicast transmission to a remote device using a 64-bit Transmit Request - 0x00 frame. The corresponding 0x89 Transmit Status with a matching Frame ID is emitted as a response to the request: 7E 00 03 89 52 00 24 Frame type Frame ID Delivery status 0x89 0x52 0x00 Response Matches request Success XTend vB RF Module User Guide 87 Frame descriptions 16-bit Receive Packet - 0x81 16-bit Receive Packet - 0x81 Request frames: n Transmit Request - 0x10 n 64-bit Transmit Request - 0x00 n 16-bit Transmit Request - 0x01 Description This frame type is emitted when a device configured with legacy API output— = 2—receives an RF data packet from a device configured to use 16-bit source addressing—MY < 0xFFFE. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Receive Packet frame - 0x90 for reception of API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Field Offset Size Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 16-bit Receive Packet - 0x81 4 16-bit 16-bit source address The sender's 16-bit network address. 6 8-bit RSSI Received Signal Strength Indicator. The Hexadecimal equivalent of (-dBm) value. For example if RX signal strength is -40 dBm, then 0x28 (40 decimal) is returned. 7 8-bit Options Bit field of options that apply to the received message: n Bit 0: Reserved n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: 802.15.4 only - Packet was broadcast across all PANs [0x04] Note Option values may be combined. 8-n variable RF data XTend vB RF Module User Guide The RF payload data that the device receives. 88 Frame descriptions 16-bit Receive Packet - 0x81 Offset Size Frame Field EOF 8-bit Checksum Description 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast A device with the 16-bit address of 1234 sent a unicast transmission to a specific device with the payload of "TxData". The following frame is emitted if the destination is configured with AO = 2. 7E 00 0B 81 12 34 5E 01 54 78 44 61 74 61 93 Frame type 64-bit source RSSI Rx options Received data 0x80 0x1234 0x5E 0x01 0x547844617461  -94 dBm ACK was sent "TxData" Output XTend vB RF Module User Guide 89 Regulatory information FCC (United States) ISED (Innovation, Science and Economic Development Canada) ACMA (Australia) XTend vB RF Module User Guide 91 100 101 90 Regulatory information FCC (United States) FCC (United States) These RF modules comply with Part 15 of the FCC rules and regulations. Compliance with the labeling requirements, FCC notices and antenna usage guidelines is required. In order to operate under Digi’s FCC Certification, integrators must comply with the following regulations: 1. The integrator must ensure that the text provided with this device (in the labeling requirements section that follows) is placed on the outside of the final product and within the final product operation manual. 2. The device may only be used with antennas that have been tested and approved for use with this device; refer to XTend vB RF Module antenna options. OEM labeling requirements The following text is the required FCC label for OEM products containing the XTend vB RF Module: Contains FCC ID: MCQ-XBPSX The enclosed device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (i.) this device may not cause harmful interference and (ii.) this device must accept any interference received, including interference that may cause undesired operation. FCC notices IMPORTANT: These RF modules have been certified by the FCC for use with other products without any further certification (as per FCC section 2.1091). Modifications not expressly approved by Digi could void the user’s authority to operate the equipment. IMPORTANT: Integrators must test final product to comply with unintentional radiators (FCC sections 15.107 & 15.109) before declaring compliance of their final product to Part 15 of the FCC rules. IMPORTANT: These RF modules have been certified for remote and base radio applications. If the module will be used for portable applications, the device must undergo SAR testing. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: Re-orient or relocate the receiving antenna, Increase the separation between the equipment and receiver, Connect equipment and receiver to outlets on different circuits, or Consult the dealer or an experienced radio/TV technician for help. XTend vB RF Module User Guide 91 Regulatory information FCC (United States) RF exposure statement This statement must be included as a CAUTION statement in integrator product manuals. WARNING! This equipment is approved only for mobile and base station transmitting devices. Antenna(s) used for this transmitter must be installed to provide a separation distance of at least 34 cm from all persons and must not be co-located or operating in conjunction with any other antenna or transmitter. XTend vB RF Module User Guide 92 The following tables cover the antennas that are approved for use with the XTend vB RF Module. If applicable, the tables show the required cable loss between the device and the antenna. Digi does not carry all of these antenna variants. Contact Digi Sales for available antennas. Dipole antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Part number Type Connector Gain Application A09-HSM-7 1 Straight half-wave RPSMA 2.1 dBi Fixed / mobile A09-HASM-675 Articulated half-wave RPSMA 2.1 dBi Fixed / mobile A09-HABMM-P5I Swivel half wave with 5" pigtail MMCX 2.1 dBi Fixed / mobile A09-HBMM-P5I Straight half-wave with 6" pigtail MMCX 2.1 dBi Fixed / mobile A09-HASM-7* Articulated half-wave RPSMA 2.1 dBi Fixed A09-HRSM* Right angle half-wave RPSMA 2.1 dBi Fixed A09-HG* Glass mounted half-wave RPSMA 2.1 dBi Fixed A09-HATM* Articulated half-wave RPTNC 2.1 dBi Fixed A09-H* Half-wave dipole RPSMA 2.1 dBi Fixed Regulatory information XTend vB RF Module User Guide XTend vB RF Module antenna options Yagi antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. 93 FCC (United States) 1Installers should apply additional torque to screw on the antenna. Type Gain Connector Required antenna cable loss Application A09-Y6NF* 2 element Yagi 6.1 dBi N 2.0 dB Fixed/mobile A09-Y7NF* 3 element Yagi 7.1 dBi N 3.0 dB Fixed/mobile A09-Y8NF 4 element Yagi 8.1 dBi N 4.0 dB Fixed/mobile A09-Y9NF* 4 element Yagi 9.1 dBi N 5.0 dB Fixed/mobile A09-Y10NF* 5 element Yagi 10.1 dBi N 6.0 dB Fixed/mobile A09-Y11NF 6 element Yagi 11.1 dBi N 7.0 dB Fixed/mobile A09-Y12NF* 7 element Yagi 12.1 dBi N 8.0 dB Fixed/mobile A09-Y13NF* 9 element Yagi 13.1 dBi N 9.0 dB Fixed/mobile A09-Y14NF* 14 element Yagi 14.0 dBi N 9.9 dB Fixed/mobile A09-Y6TM* 2 element Yagi 6.1 dBi RPTNC 2.0 dB Fixed/mobile A09-Y7TM* 3 element Yagi 7.1 dBi RPTNC 3.0 dB Fixed/mobile A09-Y8TM* 4 element Yagi 8.1 dBi RPTNC 4.0 dB Fixed/mobile A09-Y9TM* 4 element Yagi 9.1 dBi RPTNC 5.0 dB Fixed/mobile A09-Y10TM-P10I 5 element Yagi 10.1 dBi RPTNC 6.0 dB Fixed/mobile A09-Y11TM* 6 element Yagi 11.1 dBi RPTNC 7.0 dB Fixed/mobile A09-Y12TM* 7 element Yagi 12.1 dBi RPTNC 8.0 dB Fixed/mobile A09-Y13TM* 9 element Yagi 13.1 dBi RPTNC 9.0 dB Fixed/mobile A09-Y14TM* 14 element Yagi 14.0 dBi RPTNC 9.9 dB Fixed/mobile All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. 94 FCC (United States) Omni-directional base station antennas Regulatory information XTend vB RF Module User Guide Part number Gain Connector Required antenna cable loss Application A09-F0NF* Fiberglass base station 0 dBi N - Fixed A09-F1NF* Fiberglass base station 1.0  dBi N - Fixed A09-F2NF-M Fiberglass base station 2.1 dBi N - Fixed A09-F3NF* Fiberglass base station 3.1 dBi N - Fixed A09-F4NF* Fiberglass base station 4.1 dBi N - Fixed A09-F5NF-M Fiberglass base station 5.1 dBi N - Fixed A09-F6NF* Fiberglass base station 6.1 dBi N 0.9 dB Fixed A09-F7NF* Fiberglass base station 7.1 dBi N 1.9 dB Fixed A09-F8NF-M Fiberglass base station 8.1 dBi N 2.9 dB Fixed A09-F0SM* Fiberglass base station 0 dBi RPSMA - Fixed A09-F1SM* Fiberglass base station 1.0 dBi RPSMA - Fixed A09-F2SM* Fiberglass base station 2.1 dBi RPSMA - Fixed A09-F3SM* Fiberglass base station 3.1 dBi RPSMA - Fixed A09-F4SM* Fiberglass base station 4.1 dBi RPSMA - Fixed A09-F5SM* Fiberglass base station 5.1 dBi RPSMA - Fixed A09-F6SM* Fiberglass base station 6.1 dBi RPSMA 0.9 dB Fixed A09-F7SM* Fiberglass base station 7.1 dBi RPSMA 1.9 dB Fixed A09-F8SM* Fiberglass base station 8.1 dBi RPSMA 2.9 dB Fixed A09-F0TM* Fiberglass base station 0 dBi RPTNC - Fixed A09-F1TM* Fiberglass base station 1.0 dBi RPTNC - Fixed A09-F2TM* Fiberglass base station 2.1 dBi RPTNC - Fixed 95 FCC (United States) Type Regulatory information XTend vB RF Module User Guide Part number Type Gain Connector Required antenna cable loss Application A09-F3TM* Fiberglass base station 3.1 dBi RPTNC - Fixed A09-F4TM* Fiberglass base station 4.1 dBi RPTNC - Fixed A09-F5TM* Fiberglass base station 5.1 dBi RPTNC - Fixed A09-F6TM* Fiberglass base station 6.1 dBi RPTNC 0.9 dB Fixed A09-F7TM* Fiberglass base station 7.1 dBi RPTNC 1.9 dB Fixed A09-F8TM* Fiberglass base station 8.1 dBi RPTNC 2.9 dB Fixed A09-W7* Wire base station 7.1 dBi RPN 1.9 dB Fixed A09-W7SM* Wire base station 7.1 dBi RPSMA 1.9 dB Fixed A09-W7TM* Wire base station 7.1 dBi RPTNC 1.9 dB Fixed Regulatory information XTend vB RF Module User Guide Part number Dome antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Part number Type Gain Connector Required antenna cable loss Application A09-D3PNF* Omnidirectional permanent mount 3.0 dBi N 0.4 dB Fixed/mobile A09-D3NF* Omnidirectional magnetic mount 3.0 dBi N 0.4 dB Fixed/mobile A09-D3PTM* Omnidirectional permanent mount 3.0 dBi RPTNC 0.4 dB Fixed/mobile A09-D3PSM* Omnidirectional permanent mount 3.0 dBi RPSMA 0.4 dB Fixed/mobile Monopole antennas 96 FCC (United States) All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Type Gain Connector Required antenna cable loss Application A09-QRAMM 3" Quarter wave wire 2.1 dBi MMCX - Fixed/mobile A09-QRSM-2.1* Quarter wave 2.1" right angle 3.3 dBi RPSMA 0.4 dB Fixed/mobile A09-QW* Quarter wave wire 1.9 dBi Permanent - Fixed/mobile A09-QSM-3* Quarter wave straight 1.9 dBi RPSMA - Fixed/mobile A09-QSM-3H* Heavy duty quarter wave straight 1.9 dBi RPSMA - Fixed/mobile A09-QBMM-P6I* Quarter wave w/ 6" pigtail 1.9 dBi MMCX - Fixed/mobile A09-QHSM-2* 2" straight 1.9 dBi RPSMA - Fixed/mobile A09-QHRSM-2* 2" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QHRSM-170* 1.7" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QRSM-380* 3.8" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QAPM-520* 5.2" articulated screw mount 1.9 dBi Permanent - Fixed/mobile A09-QSPM-3* 3" straight screw mount 1.9 dBi Permanent - Fixed/mobile A09-QAPM-3* 3" articulated screw mount 1.9 dBi Permanent - Fixed/mobile A09-QAPM-3H* 3" articulated screw mount 1.9 dBi Permanent - Fixed/mobile Regulatory information XTend vB RF Module User Guide Part number FCC (United States) 97 Regulatory information FCC (United States) FCC publication 996369 related information In publication 996369 section D03, the FCC requires information concerning a module to be presented by OEM manufacturers. This section assists in answering or fulfilling these requirements. 2.1 General No requirements are associated with this section. 2.2 List of applicable FCC rules This module conforms to FCC Part 15.247. 2.3 Summarize the specific operational use conditions Certain approved antennas require attenuation for operation. For the XTend vB RF Module, see XTend vB RF Module antenna options. Host product user guides should include the antenna table if end customers are permitted to select antennas. 2.4 Limited module procedures Not applicable. 2.5 Trace antenna designs While it is possible to build a trace antenna into the host PCB, this requires at least a Class II permissive change to the FCC grant which includes significant extra testing and cost. If an embedded trace or chip antenna is desired contact a Digi sales representative for information on how to engage with a lab to get the modified FCC grant. 2.6 RF exposure considerations For RF exposure considerations see RF exposure statement and XTend vB RF Module antenna options. Host product manufacturers need to provide end-users a copy of the “RF Exposure” section of the manual: RF exposure statement. 2.7 Antennas A list of approved antennas is provided for the XTend vB RF Modules. See XTend vB RF Module antenna options. 2.8 Label and compliance information Host product manufacturers need to follow the sticker guidelines outlined in OEM labeling requirements. 2.9 Information on test modes and additional testing requirements Contact a Digi sales representative for information on how to configure test modes for the XTend vB RF Module. 2.10 Additional testing, Part 15 Subpart B disclaimer All final host products must be tested to be compliant to FCC Part 15 Subpart B standards. While the XTend vB module was tested to be complaint to FCC unintentional radiator standards, FCC Part 15 XTend vB RF Module User Guide 98 Regulatory information FCC (United States) Subpart B compliance testing is still required for the final host product. This testing is required for all end products, and XTend vB module Part 15 Subpart B compliance does not affirm the end product’s compliance. See FCC notices for more details. XTend vB RF Module User Guide 99 Regulatory information ISED (Innovation, Science and Economic Development Canada) ISED (Innovation, Science and Economic Development Canada) This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. Le présent appareil est conforme aux CNR d'Industrie Canada applicables aux appareils radio exempts de licence. L'exploitation est autorisée aux deux conditions suivantes : (1) l'appareil ne doit pas produire de brouillage, et (2) l'utilisateur de l'appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d'en compromettre le fonctionnement. Labeling requirements Labeling requirements for Industry Canada are similar to those of the FCC. A clearly visible label on the outside of the final product must display the following text: Contains Model XBPSX Radio, IC: 1846A-XBPSX The integrator is responsible for its product to comply with IC ICES-003 and FCC Part 15, Sub. B Unintentional Radiators. ICES-003 is the same as FCC Part 15 Sub. B and Industry Canada accepts FCC test report or CISPR 22 test report for compliance with ICES-003. Transmitters for detachable antennas This radio transmitter has been approved by Industry Canada to operate with the antenna types listed in the tables in FCC antenna certifications with the maximum permissible gain and required antenna impedance for each antenna type indicated. Antenna types not included in this list, having a gain greater than the maximum gain indicated for that type, are strictly prohibited for use with this device. The required antenna impedance is 50 ohms. Le présent émetteur radio a été approuvé par Industrie Canada pour fonctionner avec les types d'antenne énumérés ci-dessous et ayant un gain admissible maximal et l'impédance requise pour chaque type d'antenne. Les types d'antenne non inclus dans cette liste, ou dont le gain est supérieur au gain maximal indiqué, sont strictement interdits pour l'exploitation de l'émetteur. Detachable antennas Under Industry Canada regulations, this radio transmitter may only operate using an antenna of a type and maximum (or lesser) gain approved for the transmitter by Industry Canada. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (EIRP) is not more than that necessary for successful communication. Conformément à la réglementation d'Industrie Canada, le présent émetteur radio peut fonctionner avec une antenne d'un type et d'un gain maximal (ou inférieur) approuvé pour l'émetteur par Industrie Canada. Dans le but de réduire les risques de brouillage radioélectrique à l'intention des autres utilisateurs, il faut choisir le type d'antenne et son gain de sorte que la puissance isotrope rayonnée équivalente (p.i.r.e.) ne dépasse pas l'intensité nécessaire àl'établissement d'une communication satisfaisante. XTend vB RF Module User Guide 100 Regulatory information ACMA (Australia) ACMA (Australia) Power requirements Regulations in Australia stipulate a maximum of 30 dBm EIRP (Effective Isotropic Radiated Power). The EIRP equals the sum (in dBm) of power output, antenna gain and cable loss and cannot not exceed 30 dBm. The EIRP formula for Australia is: power output + antenna gain - cable loss = 0). The firmware also supports Acknowledged Reliable Delivery. For more information, see Polling mode (acknowledged). Acknowledged communications: Acknowledged mode Use Acknowledged mode for applications that need reliable delivery. If messages are smaller than 256 bytes, use the RB and RO commands to align RF packets to application packets. Characteristics Reliable delivery through positive acknowledgments for each packet. Throughput, latency and jitter vary depending on the quality of the channel and the strength of the signal. Required parameter values (TX device) RR (Retries) >= 1 Related commands Networking (DT, MK, RR), Serial Interfacing (PK, RN, RO, RB, TT) Acknowledged mode connection sequence After sending a packet while in Acknowledged mode, the TX (transmitting) device listens for an acknowledgment (ACK). If it receives the ACK, it either moves on to sending a subsequent packet if more transmit data is pending or waits for exactly RN random delay slots before allowing another transmission if no more data is pending transmit. If the TX device does not receive the ACK within the allotted time, it retransmits the packet with a new RF initializer following the ACK slot. There is no delay between the first ACK slot and the first retransmission. Subsequent retransmissions incur a delay of a random number of delay slots, between 0 and RN. If RN is set to 0 on the TX device, there are never any back-off delays between retransmissions. During back-off delays, the TX device goes into Idle Mode and may receive RF data. This can have the effect of increasing the back-off delay, as the device cannot return to Transmit (or retransmit) mode as long as it is receiving RF data. After receiving and acknowledging a packet, the RX (receiving) device moves to the next frequency and listens for either a retransmission or new data for a specific period of time. Even if the TX device indicates that it has no more pending transmit data, it may not have received the previous ACK, and hence may retransmit the packet, possibly with no delay after the ACK slot. In this case, the RX device XTend vB RF Module User Guide 113 Network configurations Acknowledged communications: Acknowledged mode always detects the immediate retransmission, which holds off the communications channel and reduces collisions. RX devices acknowledge each retransmission they receive, but they only pass the first copy of a packet that they receive out the UART. The device does not apply the RB and RO parameters to subsequent packets, meaning that once transmission begins, it continues uninterrupted until the DIN buffer is empty or it reaches the streaming limit (TT parameter). As with the first packet, the payload of each subsequent packet includes up to the maximum packet size (PK parameter), and the TX device checks for more pending data near the end of each packet. The TT parameter specifies the maximum number of bytes that the TX device sends in one transmission event, which may consist of many packets and retries. If a device reaches the TT parameter limit, the TX device forces a random delay of 1 to RN delay slots (exactly 1 delay slot if RN is zero). Each packet counts only once toward TT, no matter how many times the packet is retransmitted. Subsequent packets in Acknowledged mode are similar to those in Streaming mode, with the addition of an ACK between each packet, and the possibility of retransmissions. The device sends subsequent packets without an RF initializer, as the RX devices are already synchronized to the TX device from the preceding packet(s) and they remain synchronized for the duration of the transmission event. Each packet retransmission includes an RF initializer. Once the TX device sends all pending data or reaches the TT limit, the acknowledged transmission event is complete. The TX device does not transmit again for exactly RN delay slots, if the local RN parameter is set to a non-zero value. The RX device does not transmit for a random number of delay slots between 0 and (RN-1), if the local RN parameter is set to a non-zero value. The intent of these delays is to lessen congestion following long bursts of packets from a single TX device, during which several RX devices may have themselves become ready to transmit. Polling mode (acknowledged) Polling mode (acknowledged) and Polling mode (basic) operate in the same way. The difference between the two modes is in their means of achieving the reliable delivery of data. In Polling mode (acknowledged), the firmware achieves reliable delivery using retries and acknowledgments. Characteristics Uses a high percentage of available network bandwidth. Eliminates collisions. Works with reliable delivery (RR or MT parameters). Supports binary data transfers. Base device requests packets from remote device by polling a sequential range of addresses. Base device is configured to specify the range of addresses being polled. Uses inter-character delay to create RF packet lengths aligned with protocol packet lengths up to 2048 bytes long. Constraints The minimum time interval between polling cycles is configurable. However, if the remote devices cannot all be processed within that time interval, the polling cycle is ineffective (i.e. it will impose no additional delay). In order to ensure a pause between polling cycles, PD must be set to a value which is large enough to accommodate the pause. Recommended use Use for point-to-multipoint applications that require Reliable Delivery of data. Use this mode when it is critical that a base device be able to discern data coming from multiple devices. XTend vB RF Module User Guide 114 Network configurations Acknowledged communications: Acknowledged mode Required parameter values (Base) MD (RF Mode) = 3, PB (Polling Begin Address) PE (Polling End Address) Required parameter values (Remote) MD (RF Mode) = 4 Related commands Networking (RR, PD, DT, MY) For configuration and theory of operation information, see Polling mode theory of operation, Configure a Polling Base and Configure a Polling Remote. XTend vB RF Module User Guide 115 Development Kit Development Kit contents Interface hardware XTIB-R RS-232/485 Interface Board Adapters Interface protocols XTend vB RF Module User Guide 117 117 118 121 123 116 Development Kit Development Kit contents Development Kit contents The XTend vB RF Module Development Kit includes the hardware and software you need to rapidly create long-range wireless links between devices. The following table shows the contents of the kit. Part number Item Qty Description XTend vB RF Module 1 Long range 900 MHz RF Module(with RPSMA connector) XTP9BDPS-001 XTend vB RF Module 1 Long range 900 MHz RF Module (with MMCX antenna) XTP9BDPM-001 Antenna 1 900 MHz RPSMA, 6" half-wave, dipole, articulating, RPSMA A09HASM-675 Antenna 1 900 MHz RPSMA, 7" half-wave, dipole, articulating, w/ pigtail, MMCX A09HABMMP5I 2 RS-232 Interface Board Enables communication to RS-232 devices XTIB-R RS-232 Cable (6') Connects interface board to devices having an RS-232 serial JD2D3port CDS-6F 2 Serial loopback 1 adapter Connects to the female RS-232 (DB-9) serial connector of the Digi Interface Board and can be used to configure the device to function as a repeater (for range testing) JD2D3CDL-A NULL modem adapter (maleto-male) 1 Connects to the female RS-232 (DB-9) serial connector of the Digi Interface Board and can be used to connect the device to another DCE (female DB9) device JD2D2CDN-A NULL modem adapter (female-tofemale) 1 Used to bypass radios to verify serial cabling is functioning properly JD3D3CDN-A Male DB-9 to RJ-45 adapter 1 Facilitates adapting the DB-9 connector of the Digi Interface JE1D2Board to a CAT5 cable (male DB9 to female RJ45) CDA-A Female DB-9 to 1 RJ-45 adapter Facilitates adapting the DB-9 connector of the Digi Interface JE1D3Board to a CAT5 cable (female DB9 to female RJ45) CDA-A Power adapter Allows you to power the Interface Board with a 110 V AC power supply (not included with international (-INT) development kits) 2 JP4P29V10-6F Interface hardware The XTend vB RF Module Development Kit includes a pair of RS-232 interface boards that support the RS-232, RS-485 and RS-422 protocols. When you mount the devices to the interface boards, the boards provide the following development tools: XTend vB RF Module User Guide 117 Development Kit XTIB-R RS-232/485 Interface Board n Fast and direct connection to serial devices (such as PCs) and easy access to the device registries. The parameters stored in the registry allow you to customize the devices to suit the specific needs of your data systems. n External DIP switch to automatically configure common device profiles. n Signal conversion between TTL levels and RS-232 levels. The Digi Interface board can connect the device to any device that has an available RS-232, RS-485 or RS-422 connection. This documentation refers to a XTend vB RF Module mounted to an interface board as a "Module Assembly." XTIB-R RS-232/485 Interface Board The following figure shows a front view of the board. The table explains the numbered callouts in the figure. Number Description 1 Configuration switch 2 I/O and Power LEDs 3 DB-9 Serial port 4 RSSI LEDs 5 Power connector Configuration switch The Configuration switch provides an alternate method for entering Command mode. To enter Command mode at the device's default RF data rate, hold the Configuration switch down for two seconds. XTend vB RF Module User Guide 118 Development Kit XTIB-R RS-232/485 Interface Board I/O and Power LEDs The LEDS visualize status information and indicate device activity as follows: LED color LED location Indication Yellow Top Serial data out (to the host) Green Middle Serial data in (from the host) Red Bottom Power/TX indicator (the red light is on when powered, it pulses on and off briefly during RF transmission) Serial port The serial port is a standard female DB-9 (RS-232) connector. You can also use this connector for RS485 and RS-422 connections. RSSI LEDs The RSSI LEDs indicate the amount of fade margin present in an active wireless link. Fade margin is the difference between the incoming signal strength and the device's receiver sensitivity. The LED indications are as follows: Number of LEDs on Indicates 3 Very strong signal (> 30 dB fade margin) 2 Strong signal (> 20 dB fade margin) 1 Moderate signal (> 10 dB fade margin) 0 Weak signal (< 10 dB fade margin) Power connector 7-28 VDC power connector (center positive, 5.5/2.1 mm). The XTIB-R interface board can accept voltages as low as 5 V. Contact Digi Technical Support to enable this option. XTIB-R DIP switch The DIP switch automatically configures the device to operate in different modes during the power-on sequence. Each time the Module Assembly (interface board with a device) powers-on, intelligence on the board programs the attached device according to the positions of the DIP Switch. The following figure illustrates the DIP switch settings. XTend vB RF Module User Guide 119 Development Kit XTIB-R RS-232/485 Interface Board Automatic DIP switch configurations Each time you power on the Module Assembly, the firmware sends AT commands to the on-board RF module as dictated by the positions of the DIP switches. The following figure shows the DIP switch with the various configurations. The following table shows the commands that the firmware sends to the module as a result of DIP switch settings. DIP switches 3 and 4 are only used for RS-485/422 termination and do not affect the configuration of the device. In the tables, SW means switch. Switch condition Behavior Commands sent during power-up Switches 1 and 2: Restore defaults / serial interfacing SW1: ON (up) Restore defaults RE (restore defaults) SW2: ON (up) WR (write defaults to non-volatile memory) SW1: ON (up) RS-232 SW2: OFF operation (down) CS 0 (RS-232, CTS flow control) SW1: OFF (down) SW2: OFF (down) CS 3 (RS-485 or RS-422 operation) RS-485/422 operation Switches 5 and 6: TX/TX modes SW5: OFF (down) SW6: OFF (down) Multipoint base XTend vB RF Module User Guide MY 0 (Source address = 0) DT FFFF (Destination address = broadcast address) MT 3 (Enable 3 multi-transmit retries) 120 Development Kit Switch condition Adapters Behavior Commands sent during power-up SW5: OFF Multipoint (down) remote SW6: ON (up) AM (Generate unique source address) DT 0 (Destination address = 0) MT 0 (Disable multi-transmit) RR A (Enable 10 unicast retries) SW5: ON (up) Point-to-point SW6: OFF (down) AM (Generate unique source address) DT FFFF (Set destination address to broadcast) MT 3 (Enable 3 multi-transmit retries) SW5: ON (up) User defined SW6: ON (up) No addressing commands are sent to the device, refer to the following table for details. The following table shows the user-defined mode, when switches 5 and 6 are ON (up). The behavior of pin 9 (GPO1) varies depending on the state of the DIP switches and the CS command parameter upon power-up. Switch condition CS condition Command sent during power-up SW1: ON (up) SW2: OFF (down) SW5: ON (up) SW6: ON (up) If CS = 0, 1, 2 or 4 CS parameter remains the same If CS = 3 CS 0 (RS-232 operation with CTS flow control) SW1: OFF (down) SW2: ON (up) SW5: ON (up) SW6: ON (up) If CS = 2 CS parameter remains the same If CS = 0, 1, 3 or 4 CS 3 (RS-485 or RS-422 operation) SW1: OFF (down) SW2: OFF (down) SW5: ON (up) SW6: ON (up) If CS = 2 CS parameter remains the same If CS = 0, 1, 3 or 4 CS 3 (RS-485 or RS-422 operation) Adapters The development kit includes several adapters that facilitate the following functions: n Performing range tests n Testing cables n Connecting to other RS-232 DCE and DTE devices n Connecting to terminal blocks or RJ-45 (for RS-485/422 devices) NULL Modem Adapter (male-to-male) Part Number: JD2D2-CDN-A (Black, DB-9 M-M) The male-to-male NULL modem adapter is used to connect two DCE devices. A DCE device connects with a straight-through cable to the male serial port of a computer (DTE). The following image shows the Male NULL modem adapter and its pinouts. XTend vB RF Module User Guide 121 Development Kit Adapters NULL Modem Adapter (female-to-female) Part Number: JD3D3-CDN-A (Gray, DB-9 F-F) Use the female-to-female NULL modem adapter to verify that serial cabling is functioning properly. To test cables, insert the female-to-female NULL modem adapter in place of a pair of device assemblies (RS-232 interface board and XTend vB RF Module) and test the connection without devices in the connection. The following figure shows the adapter and its pinouts. Serial Loopback Adapter Part Number: JD2D3-CDL-A (Red, DB-9 M-F) Use the serial loopback adapter for range testing. During a range test, the serial loopback adapter causes the device to function as a repeater by looping serial data back into the device for retransmission. The following image shows the adapter and its pinouts. XTend vB RF Module User Guide 122 Development Kit Interface protocols Male DB-9 to RJ-45 Adapter Part Number: JD2D2-CDN-A (Yellow) This adapter facilitates adapting the DB-9 connector of the Interface Board to a CAT5 cable (male DB9 to female RJ45). For connection guidelines, see RS-485 (4-wire) and RS-422 operation. The following image shows the adapter and its pinouts. Female DB-9 to RJ-45 Adapter Part Number: JD3D3-CDN-A (Green) This adapter facilitates adapting the DB-9 Connector of the Interface Board to a CAT5 cable (female DB9 to female RJ45). For connection guidelines, see ‘RS-485 (4-wire) & RS-422 Operation’ sections. The following image shows the adapter and its pinouts. Interface protocols The XTend vB RF Module Module Assembly supports the following interfacing protocols: n RS-232 n RS-485 (2-wire) half-duplex n RS-485 (4-wire) and RS-422 XTend vB RF Module User Guide 123 Development Kit Interface protocols RS-232 operation The following figures show the RS-232 DIP switch settings and the pins used on the female RS-232 (DB-9) serial connector. The Module Assembly reads and applies the DIP switch settings only during power-on. The following table provides the RS-232 signals and their implementations on the Module Assembly. Low-asserted signals have a horizontal line over the pin name. DB-9 pin RS-232 XCTU name name 1 DCD 2 Description Implementation GPO2 Data-CarrierDetect Connected to DSR (pin6 of DB-9) RXD DOUT Received Data Serial data exiting the Module Assembly (to host) 3 TXD DIN Transmitted Data Serial data entering into the Module Assembly (from host) 4 DTR GPI2 DataTerminalReady Can enable power-down on the Module Assembly 5 GND - Ground Signal Ground 6 DSR GPO2 Data-SetReady Connected to DCD (pin1 of DB-9) 7 RTS / CMD GPI1 Request-toSend / Command Mode Provides RTS flow control or enables Command mode 8 CTS GPO1 Clear-to-Send Provides CTS flow control 9 RI - Ring Indicator Optional power input that is connected internally to the positive lead of the front power connector XTend vB RF Module User Guide 124 Development Kit Interface protocols RS-232 wiring diagrams The following diagram shows the DTE device (RS-232, male DB-9 connector) wired to a DCE Module Assembly (female DB-9). The following diagram shows the DCE Module Assembly (female DB-9 connector) wired to a DCE device (RS-232, male DB-9). XTend vB RF Module User Guide 125 Development Kit Interface protocols RS-485 (2-wire) operation When operating within the RS-485 protocols, all communications are half-duplex. The Module Assembly reads and applies the DIP switch settings only during power-on. The following figure shows the RS-485 (2-wire) half-duplex DIP switch settings. The following figure shows the RS-485 (2-wire) with termination (optional) DIP switch settings. Enabling termination activates a 120 Ω resistor between T+ and T-. The following figure shows the pins that the female RS-232 (DB-9) serial connector uses. XTend vB RF Module User Guide 126 Development Kit Interface protocols For the RJ-45 connector pin designations to use in RS-485/422 environments see Male DB-9 to RJ-45 Adapter and Female DB-9 to RJ-45 Adapter. The following table provides the RS-485 (2-wire half-duplex) signals and their implementations on the Module Assembly. DB-9 Pin RS-485 name 2 Description Implementation T/R- (TRA) Negative data line Transmit serial data to and from the Module Assembly 5 GND Ground signal Ground 8 T/R+ (TRB) Positive data line Transmit serial data to and from the Module Assembly 9 PWR Power 1, 3, 4, 6, 7 not used Optional power input that is connected internally to the front power connector RS-485 wiring diagrams The following diagram shows the Module Assembly in an RS-485 (2-wire) half-duplex environment. XTend vB RF Module User Guide 127 Development Kit Interface protocols RS-485 (4-wire) and RS-422 operation The Module Assembly reads and applies the DIP switch settings only during power-on. The following figure shows the RS-485 (4-wire) and RS-422 DIP switch settings. The following figure shows the RS-485 (4-wire) and RS-422 DIP switch settings with termination (optional). Enabling termination activates a 120 Ω resistor between T+ and T-. The following figure shows the pins that the female RS-232 (DB-9) serial connector uses. For the RJ-45 connector pin designations to use in RS-485/422 environments see Male DB-9 to RJ-45 Adapter and Female DB-9 to RJ-45 Adapter. The following table provides the RS-485/422 (4-wire) signals and their implementations on the Module Assembly. DB-9 pin RS-485/422 name 2 Description Implementation T- (TA) Transmit negative data line Serial data sent from the Module Assembly 3 R- (RA) Receive negative data line Serial data received by the Module Assembly 5 GND Signal ground Ground 7 R+ (RB) Receive positive data line XTend vB RF Module User Guide Serial data received by the Module Assembly 128 Development Kit Interface protocols DB-9 pin RS-485/422 name 8 Description Implementation T+ (TB) Transmit positive data line Serial data sent from the Module Assembly 9 PWR Power Optional power input that is connected internally to the front power connector 1, 4, 6 not used RS-422 wiring diagrams The following figure shows the Module Assembly in an RS-485 (4-wire) environment. The following figure shows the Module Assembly in an RS-422 environment. RS-485/422 connection guidelines The RS-485/422 protocol provides a solution for wired communications that can tolerate high noise and push signals over long cable lengths. RS-485/422 signals can communicate as far as 4000 feet XTend vB RF Module User Guide 129 Development Kit Interface protocols (1200 m). RS-232 signals are suitable for cable distances up to 100 feet (30.5 m). RS-485 offers multi-drop capability in which you can connect up to 32 nodes. Use the RS-422 protocol for point-to-point communications. To integrate the XTend vB RF Module with the RS-485/422 protocol, we suggest the following: 1. When using Ethernet twisted pair cabling: connect T+ and T- to each wire in a twisted pair. Likewise, connect R+ and R- to a twisted pair. For example, tie the green and white/green wires to T+ and T-. 2. For straight-through Ethernet cable (not cross-over cable), the following wiring pattern works well: Pin 3 to T+, Pin 4 to R+, Pin 5 to R-, Pin 6 to T-. 3. The connecting cable only requires 4 wires, even though there are 8 wires. 4. When using phone cabling (RJ-11), Pin 2 in the cable maps to Pin 3 on the opposite end of cable and Pin 1 maps to Pin 4 respectively. XTend vB RF Module User Guide 130
XTP9B-DPS-001 价格&库存
很抱歉,暂时无法提供与“XTP9B-DPS-001”相匹配的价格&库存,您可以联系我们找货
