Skywire® 4G LTE Cat 3
Embedded Cellular Modem
Datasheet
NimbeLink Corp
Updated: April 2018
PN 30012 rev 15
© NimbeLink Corp. 2018. All rights reserved.
1
Table of Contents
Table of Contents
2
Introduction
Orderable Part Numbers
Additional Resources
Product Overview
Block Diagram
4
4
4
4
5
Technical Specifications
Electrical Specifications
Absolute Maximum Ratings
Recommended Ratings & Module Pin out
Connectors J1 and J2
Connectors J3, X1, X2, X3
Mechanical Specifications
Mechanical Characteristics
Mating Connectors
Device Placement
Environmental Specifications
6
6
6
6
6
7
8
8
8
8
8
Important Design Considerations
ON_OFF Signal
Power Supply Requirements
Serial Communications
FOTA
9
9
9
9
10
Mounting Guidelines
Board to Board connectors approach
Solder to Board connection approach
11
11
13
Antenna Considerations
Primary Antenna Requirements
Diversity Antenna Requirements
GPS/GLONASS Antenna Requirements
Recommended Antennas
14
14
15
15
16
Certifications
Carrier Specific
16
16
PN 30012 rev 15
2
Geography Specific
17
Federal Regulatory Licensing
17
End Product Labeling Requirements
17
PN 30012 rev 15
3
1. Introduction
1.1 Orderable Part Numbers
Orderable Device
Firmware
Revision
Operating
Temperature
LTE Bands
NL-SW-LTE-TSVG
17.01.571
-40 to +85˚C
B4, B13
No
Verizon
B4, B13
No
Verizon
B3, B7, B20
HSPA: B1, B5, B8
Europe
B2, B5, B4, B17
HSPA: B2, B5
AT&T/T-Mobile
B2, B5, B4, B17
HSPA: B2, B5
AT&T/T-Mobile
NL-SW-LTE-TSVG-B
NL-SW-LTE-TEUG
NL-SW-LTE-TNAG
NL-SW-LTE-TNAG-B
17.01.573
17.00.523
17.00.503
17.01.502
-40 to +85˚C
-40 to +85˚C
-40 to +85˚C
-40 to +85˚C
Fallback?
Network Type
NL-SIM-COM
-35˚C to +85˚C
Verizon
NL-SIM-IND
-40˚C to +105˚C
Verizon
NL-SIM-ATT
-25˚C to +85˚C
AT&T
NL-SIM-TMO
-25˚C to +85˚C
T-Mobile
NL-SIM-VOD
-25˚C to +85˚C
Vodafone
1.2 Additional Resources
The following documents or documentation resources are referenced within this document.
● Telit’s LE910 Hardware User Guide
1.3 Product Overview
Add robust cellular connectivity to your M2M devices with scalable radio technology with
Nimbelink's 4G LTE Cat 3 Skywire® cellular modem family. Nimbelink's extensive experience in
designing and building embedded solutions has made the NimbeLink Skywire embedded cellular
modem family the smallest on the market while allowing for easy integration of cellular
connectivity into new and existing products. Skywire modems end-device certification eliminates
the considerable cost, time and risk of the certification process, driving your products to market
faster. The Skywire's small footprint and standard 20 pin interface simplies migration to other
cellular technologies, ensuring long product life while allowing for easy product integration. The
modem is designed for volume production and is intended for OEMs to embed into end
equipment designs.
PN 30012 rev 15
4
1.4 Block Diagram
PN 30012 rev 15
5
2. Technical Specifications
2.1 Electrical Specifications
2.1.1 Absolute Maximum Ratings
Parameter
Signal
Maximum Rating
Main Power Supply
I/O Voltage Reference
VCC
VREF
4.3V
5.5V
2.1.2 Recommended Ratings & Module Pin out
2.1.2.1
Pin
Name
Direction
1
VCC
Input
2
DOUT
Output
3
DIN
4
GND
Description
Min
Typical
Max
If not used
Main Power supply
3.5V
3.9V
4.3V
Must be implemented
UART data out, I/O level tied to VREF
VOL:
GND to
0.55V
Input
UART data in, I/O level tied to VREF
VIL:
GND to
0.15V
Input
Ground Pin
VOH:
VREF x
0.67 to
VREF
VIH:
VREF-0.4
V
to VREF
Must be implemented
if USB not used,
No connection
Must be implemented
if USB not used,
No connection
Must be implemented
5
RESET_nIN
Input
Controls HW_SHUTDOWN input on
Telit LE910, tie low for 200mS and
released to activate. Internally
pulled up to 1.8V. Drive with open
collector output only. Do not drive
high. Assert only in an emergency as
the module will not gracefully exit
the cellular network when asserted.
6
VUSB
Input
Supply for USB interface
7
USB_D+
I/O
USB differential Data + signal
No connection
8
USB_D-
I/O
USB differential Data - signal
No connection
3.0V
5V
DTR
Input
Modem Data Terminal Ready input
10
GND
Input
Ground Pin
GND
Input
Ground Pin
CTS
Output
PN 30012 rev 15
Modem Clear to Send hardware flow
control output
VOL:
GND to
0.55V
No connection
5.25V
No connection
VIH:
VREF-0.4
V
to VREF
VIL:
GND to
0.15V
9
12
1.8V
Tie to GND
Must be implemented
Must be implemented
VOH:
VREF x
0.67 to
VREF
No connection
6
13
ON/nSLEEP
Output
Signal drives the onboard LED
indicating network status. OFF =
Device OFF, Permanently ON =
Searching for Network & Not
Registered, Slow Blink = Registered
with full service, Permanently on =
call is active. See TelitLE910 manual
for additional information.
1.65V
14
VREF
Input
Voltage reference for offboard I/O
signals. This signal drives the input
voltage side of an onboard buffer
which converts all external I/O
voltage from VREF range to 1.8V
range to drive the onboard
TelitLE910 modem module.
15
GND
Input
Ground Pin
5.5V
Must be implemented
Must be implemented
VIL:
GND to
0.15V
Programmable GPIO_03 on
TelitLE910 module
1.8V
No connection
Programmable GPIO_02 on
TelitLE910 module
1.8V
No connection
Input
ADC_IN1 input on Telit LE910
module (8bit resolution,
很抱歉,暂时无法提供与“NL-SW-LTE-TNAG”相匹配的价格&库存,您可以联系我们找货
