Skywire® HSPA+ HE910
Embedded Cellular Modem
Datasheet
NimbeLink Corp.
Updated: June 2020
PN 30026 rev 14
© NimbeLink Corp. 2020. All rights reserved.
1
Table of Contents
Table of Contents
2
Introduction
Orderable Part Numbers
Additional Resources
Product Overview
Block Diagram
4
4
4
4
5
Technical Specifications
Electrical Specifications
Absolute Maximum Ratings
Recommended Ratings & Module Pin out
Connectors J1 and J2
Connectors J3, X1, X2, X3
Component Parameters
Typical Power Consumption
Mechanical Specifications
Mechanical Characteristics
Mating Connectors
Device Placement
Environmental Specifications
5
5
5
6
6
7
8
8
9
9
9
9
9
Important Design Considerations
ON_OFF Signal
Power Monitoring
Power Supply Requirements
Serial Communications
10
10
10
10
11
Mounting Guidelines
Board to Board connectors approach
Solder to Board connection approach
13
13
14
Antenna Considerations
Primary Antenna Requirements
Diversity Antenna Requirements
GPS Antenna Requirements
Recommended Antennas
15
15
15
15
16
PN 30026 rev 14
2
Certifications
Carrier Specific
Geography Specific
17
17
17
Federal Regulatory Licensing
17
End Product Labeling Requirements
17
PN 30026 rev 14
3
1. Introduction
1.1 Orderable Part Numbers
Orderable
Device
Telit Chipset
Operating
Temperature
Bands
Fallback?
Network
Type
GPS
NL-SW-HSPA
HE910-DG
-40 to +85˚C
B1, B2, B4, B5, B8
Yes
GSM
Yes
NL-SW-HSPA-B
HE910-DG
-40 to +85˚C
B1, B2, B4, B5, B8
Yes
GSM
Yes
1.2 Additional Resources
The following documents or documentation resources are referenced within this
document.
NL-SW-HSPA Product Page
GPS & Assisted GPS App Note
Sending and Receiving data with Socket Dials
Prototyping considerations App Note
1.3 Product Overview
Add robust cellular connectivity to your M2M devices with scalable radio technology with
Skywire line of modems including HE910 based HSPA+ solutions. Extensive experience
in designing and building embedded product solutions makes the NimbeLink Skywire®
embedded cellular modem the smallest on the market. It uses the popular Skywire
interface and supports multiple GSM bands and fallback capability minimizing costs of
hardware and network access. The module is designed for volume production and is
intended for OEMs to embed into end equipment designs.
PN 30026 rev 14
4
1.4 Block Diagram
2. Technical Specifications
2.1 Electrical Specifications
2.1.1 Absolute Maximum Ratings
PN 30026 rev 14
Parameter
Signal
Maximum Rating
Main Power Supply
VCC
4.3V
I/O Voltage Reference
VREF
5.0V
5
2.1.2 Recommended Ratings & Module Pin out
2.1.2.1 Connectors J1 and J2
Pin
Name
Direction
Description
Min
Typical
Max
If not used
1
VCC
Input
Main Power supply
3.5V
3.9V
4.3V
Must be implemented
VOL:
GND to
0.55V
VIL:
GND to
0.15V
2
DOUT
Output
UART data out, I/O level tied to
VREF
3
DIN
Input
UART data in, I/O level tied to
VREF
4
GND
Input
Ground Pin
0V
4.4V
VOH:
VREF x
0.67 to
VREF
VIH:
VREF-0.4
V
to VREF
Must be implemented
if USB not used,
No connection
Must be implemented
if USB not used,
No connection
Must be implemented
5
RESET_nIN
Input
Controls HW_SHUTDOWN input on
Telit HE910, tie low for 200mS and
released to activate. Internally
pulled up to 1.8V. Drive with open
collector output. Assert only in an
emergency as the module will not
gracefully exit the cellular network
when asserted.
6
VUSB
Input
Supply for USB interface
7
USB_D+
I/O
USB differential Data + signal
No connection
8
USB_D-
I/O
USB differential Data - signal
No connection
5V
1.8V
No connection
5V
No connection
VIH:
VREF-0.4
V
to VREF
VIL:
GND to
0.15V
9
DTR
Input
Modem Data Terminal Ready input
10
GND
Input
Ground Pin
Must be implemented
11
GND
Input
Ground Pin
Must be implemented
12
CTS
Output
Modem Clear to Send hardware
flow control output
PN 30026 rev 14
VOL:
GND to
0.55V
VOH:
VREF x
0.67 to
VREF
Tie to GND
No connection
6
Pin
Name
Direction
Description
Min
13
ON/nSLEEP
Output
Signal drives the onboard LED
indicating network status. See
section 3.5 for details.
1.65V
Typical
Max
If not used
1.8V
No connection
5.0V
Must be implemented
14
VREF
Input
Voltage reference for offboard I/O
signals. This signal drives the input
voltage side of an onboard buffer
which converts all external I/O
voltage from VREF range to 1.8V
range to drive the onboard Telit
HE910 modem module.
15
GND
Input
Ground Pin
VIL:
GND to
0.15V
VIH:
VREF-0.4
V
to VREF
Tie to GND
1.8V or
3.3V
Must be implemented
16
RTS
Input
Modem Request to Send hardware
flow control input
17
DIO3
I/O
Programmable GPIO_03 on Telit
HE910 module
1.8V
No connection
18
DIO2
I/O
Programmable GPIO_02 on Telit
HE910 module
1.8V
No connection
19
ADC1
Input
ADC_IN1 input on Telit HE910
module (8bit resolution,
很抱歉,暂时无法提供与“NL-SW-HSPAP”相匹配的价格&库存,您可以联系我们找货
