Skywire® 2G 1xRTT
Embedded Cellular Modem
Datasheet
NimbeLink Corp
Updated: October 2017
PN 30003 rev 8
© NimbeLink Corp. 2017. All rights reserved.
1
Table of Contents
Table of Contents
2
Introduction
Orderable Part Numbers
Additional Resources
Product Overview
Block Diagram
3
3
3
3
4
Technical Specifications
Electrical Specifications
Absolute Maximum Ratings
Recommended Ratings & Module Pin out
Connectors J1 and J2
Mechanical Specifications
Mechanical Characteristics
Mating Connectors
Device Placement
Environmental Specifications
5
5
5
5
5
7
7
7
7
7
Important Design Considerations
ON_OFF Signal
Power Supply Requirements
Network Connection Status LED
8
8
8
8
Mounting Guidelines
Board to Board connectors approach
Solder to Board connection approach
9
9
10
Antenna Considerations
Antenna Requirements
Recommended Antennas
11
11
11
Certifications
Carrier Specific
Geography Specific
11
11
12
Federal Regulatory Licensing
12
End Product Labeling Requirements
12
PN 30003 rev 8
2
1. Introduction
1.1 Orderable Part Numbers
Orderable Device
NL-SW-1xRTT-V
NL-SW-1xRTT-S
NL-SW-1xRTT-A
Operating Temperature
-40 to +85˚C
-40 to +85˚C
-40 to +85˚C
Carrier
Verizon
Sprint
AERIS
Network Type
CDMA 1xRTT
CDMA 1xRTT
CDMA 1xRTT
1.2 Additional Resources
The following documents or documentation resources are referenced within this document.
● Telit’s CE910 Hardware User Guide
1.3 Product Overview
Add robust cellular connectivity to your M2M devices without the cost, delay, and hassle of
federal and carrier certifications. Extensive experience in designing and building embedded
product solutions makes the NimbeLink Skywire® embedded cellular modem the smallest on the
market. It uses the popular Skywire interface and supports 1xRTT communication, minimizing
costs of hardware and network access. The module is designed for volume production and is
intended for OEMs to embedded into end equipment designs.
PN 30003 rev 8
3
1.4 Block Diagram
PN 30003 rev 8
4
2. Technical Specifications
2.1 Electrical Specifications
2.1.1 Absolute Maximum Ratings
Parameter
Signal
Main Power Supply
I/O Voltage Reference
Maximum Rating
VCC
VREF
4.3V
5.5V
2.1.2 Recommended Ratings & Module Pin out
2.1.2.1
Pin
Name
Direction
1
VCC
Input
Description
Min
Typical
Main Power supply
3.5V
3.9V
UART data out, I/O level tied to VREF
VOL:
GND to
0.55V
Input
UART data in, I/O level tied to VREF
VIL:
GND to
0.15V
Input
Ground Pin
2
DOUT
Output
3
DIN
4
GND
5
RESET_nIN
Input
Controls HW_SHUTDOWN input on
Telit CE910-DUAL, tie low for 800mS
to activate. Internally pulled up to
VCC with 57k resistor. Drive with
open collector output. Assert only in
an emergency as the module will not
gracefully exit the cellular network
when asserted.
6
VUSB
Input
Supply for USB interface
7
USB_D+
I/O
USB differential Data + signal
8
USB_D-
I/O
USB differential Data - signal
4.4V
VIL:
GND to
0.15V
Modem Data Terminal Ready input
10
GND
Input
Ground Pin
GND
Input
Ground Pin
PN 30003 rev 8
Modem Clear to Send hardware flow
control output
Must be implemented
Must be implemented
if USB not used,
No connection
Must be implemented
if USB not used,
No connection
Must be implemented
No connection
5V
No connection
No connection
Input
Output
4.3V
VOH:
VREF x
0.67 to
VREF
VIH:
VREF-0.4
V
to VREF
5V
DTR
CTS
If not used
VREF
9
12
Max
VOL:
GND to
0.55V
VIH:
VREF-0.4
V
to VREF
VOH:
VREF x
0.67 to
VREF
No connection
Tie to GND
Must be implemented
Must be implemented
No connection
5
13
ON/nSLEEP
Output
Signal drives the onboard LED
indicating network status. OFF =
Device OFF, Fast blink = Searching for
Network & Not Registered, Slow Blink
= Regsitered with full service,
Permanently on = call is active. See
Telit CE910-DUAL manual for
additional information.
14
VREF
Input
Voltage reference for offboard I/O
signals. This signal drives the input
voltage side of an onboard buffer
which converts all external I/O
voltage from VREF range to 1.8V
range to drive the onboard Telit
CE910-DUAL modem module.
15
GND
Input
Ground Pin
16
RTS
Input
17
DIO3
I/O
18
DIO2
I/O
19
ADC1
Input
ON_OFF
Input
PN 30003 rev 8
Modem Request to Send hardware
flow control input
Programmable GPIO_03 on Telit
CE910-DUAL module
Programmable GPIO_02 on Telit
CE910-DUAL module
ADC_IN1 input on Telit CE910-DUAL
module (12bit resolution, 24.5dBm
VSWR recommended
很抱歉,暂时无法提供与“NL-SW-1XRTT-A”相匹配的价格&库存,您可以联系我们找货
