DATA SHEET
TCM 300 / TCM 320 (868 MHz),
TCM 300U / TCM 320U (902 MHz) Transceiver Modules
The transceiver modules TCM 300 and
TCM 320 enable the realization of highly
efficient radio actors, repeaters and other
line powered applications for the EnOcean
systems with 868 MHz & 902 MHz.
The module provides several built-in operating
modes. In addition repeater functionality
(1 or 2 level) can be activated. Using the Dolphin
API library it is possible to write custom specific
software for the module. The modules are insystem programmable.
Built-in operating modes
Unidirectional serial communication (ESP2)
Bidirectional serial communication (ESP2)
1-channel relay mode
4-channel relay mode
1-channel dimming mode
Features accessible via API:
Integrated 16 MHz 8051 CPU with
32 kB FLASH and 2kB SRAM
Various power down and sleep modes
down to 0.2 µA current consumption
Up to 14 configurable I/Os
10 bit ADC, 8 bit DAC
Type
TCM
TCM
TCM
TCM
Ordering Code
300
320
300U
320U
S3003-K300 (SMD)
S3003-K320
S3053-K300 (SMD)
S3053-K320
Features overview
Antenna
Pre-installed whip antenna (TCM 320/300U)
External whip or 50 Ω antenna mountable (TCM 300/300U)
868.300 MHz / 125 kbps (TCM 300/320)1)
902.875 MHz / 125 kbps (TCM 300U/320U) 1)
Frequency and data rate
Receiver Sensitivity (at 25°C)
Conducted Output Power @50
Power Supply
Current Consumption
Dimensions of PCB
Operating temperature
Radio Regulations
typ. –96 dBm (868MHz)2)
typ. -98 dBm (902MHz)2)
3 dBm(868MHz)
1 dBm (902MHz)
2.6 – 3.3 V (TCM 320 / TCM 320U)
2.6 – 4.5 V (TCM 300 / TCM 300U)
Receive mode: typ. 33mA
Transmit mode: typ. 24mA
36.5 x 18 x 5.5 mm (TCM 320 / TCM 320U)
22 x 19 x 3 mm (TCM 300 / TCM 300U)
–25 up to +85°C
TCM 300 (max. radiated power +1.4 dBm with whip): RED (EU)
TCM 320 (max. radiated power +3.0 dBm with whip): RED (EU)
TCM 300U/320U : FCC (US) / ISED (CA)
According to ISO/IEC 14543-3-10
2) 0.1% telegram error rate (based on the combination of 3 received sub-telegrams)
© 2019 EnOcean | www.enocean.com
Subject to modifications | May 2019
1)
很抱歉,暂时无法提供与“TCM300U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+151.33819250+18.37173
- 国内价格 香港价格
- 1+151.380801+18.37691
