TW120 25 dB GPS L1 In-line Amplifier
The TW120 is a rugged waterproof, low cost,
low noise, low power, narrow band 25dB
gain in-line amplifier, specially designed to
tightly filter and boost weak GPS L1 signals,
while maintaining low antenna noise figures.
The TW120 provides for much longer cable
runs from antenna to receiver, for
applications such as mast-mount, roof-top
and large vehicle installations, without any
degradation of system sensitivity.
The TW120 passes DC directly from input to
output to support centre conductor DC
supply to the antenna, and so avoiding the
need for an additional bias source or bias “T”.
TW120 Dimensions (mm)
A clip for mounting is also available.
IMPORTANT: Amplifiers are directional and
must be installed in the orientation indicated on
the product label. (Arrow points away from
antenna)
Applications
GNSS and Telematics Systems
Wireless Telecom & Cellular Base Station Timing Applications
Commercial and Industrial Timing and Synchronization Applications
Features
Very low noise
Wide input voltage range, 3 to 12 VDC
Powered via antenna coax from receiver
50 Ohm port impedance
Cylindrical nickel-plated brass, IP67
compliant housing
Gold-plated connectors
RoHS compliant
Benefits
Improves signal reception
Enables extended cable runs
Avoid installation of costly low-loss cable
Fits in-line with antenna cable
No external voltage supply needed
Maintains low antenna LNA noise figure
Easy to install – mounting clamp included
Specifications
Vcc =3.3V, over full bandwidth, T=25 °C
Electrical
Gain
Noise Figure
-3dB Bandwidth
I/O VSWR 1562 to 1662MHz
Lower Stop band Attenuation
Upper Stop band Attenuation
Input Return Loss Zo=50
Output Return Loss Zo=50
Reverse Isolation
Group Delay (w/o cable)
Output 1dB Compression Level
Output IP3
Maximum Input Level
Supply Voltage Range
Supply Current
25dB min, 26dB typ
9dB (1570 to 1580 MHz)
>35 dB
49.5nS @ 1573.42MHz, 38.7nS @ 1575.42MHz, 52.2nS @ 1577.42MHz
>-10 dBm
>0 dBm
-5 dBm
+3 to 12 VDC Nominal
13 mA typical, 16 mA max.
Mechanicals & Environmental
Mechanical Size (body dimensions only)
Weight
Connectors
Torque Limitations (lbs)
Operating Temp. Range
Enclosure
Environmental
Warranty
59 mm L x 20 mm Dia. (2.32” L x 0.787” Dia.)
很抱歉,暂时无法提供与“32-0120-01”相匹配的价格&库存,您可以联系我们找货
