TW125B Low Current / Low Voltage 1.1 to 1.7 GHz
27 dB gain In-line Amplifier
The TW125B is a low cost, rugged,
waterproof, low noise, low current/low
voltage, 1.1 to 1.7 GHz band, 27dB gain inline amplifier, specially designed to amplify
all GNSS frequency signals, from GPS L5 to
GLONASS G1. The TW125B provides for
much longer cable runs from antenna to
receiver, for applications such as mastmount, large vehicle and timing systems,
without degradation of system sensitivity.
Its low loading allows for both the antenna
and the TW125B in-line amplifier to be
powered by the GNSS receiver.
The
TW125B passes DC supply to the antenna,
therefore not requiring additional hardware
such as bias-T, power cable and power
supply.
TW125B Dimensions (mm)
IMPORTANT: Amplifiers are directional and
must be installed in the orientation indicated
on the product label. (Arrow points away from
antenna)
Applications
• All GNSS Signals – GPS, GLONASS, Galileo, BeiDou & SBAS
• Commercial, Industrial and Military Telematics Systems
• Wireless and Telecom Timing and Synchronization Applications
Features
Benefits
Low Current / low voltage
Very low noise
Wide input voltage 3 to 16 Volts
Nickel-plated brass, IP67 compliant housing
Powered via antenna coax from receiver
50 Ohm port impedance
Available SMA, TNC, and N-Type jack connectors
RoHS and REACH compliant
Improves signal reception
Enables extended cable runs
Avoid installation of costly low-loss
cable
Fits in line with antenna cable
No external DC power supply required
Easy to install - mounting clamp
included
27dB gain In-line Amplifier
Specifications
Vcc =3.3V, over full bandwidth, T=25 °C
Electrical
Nominal Gain
Pass Band Ripple
Impedance
Noise Figure
Bandwidth
Input VSWR
Output VSWR
Reverse Isolation
Output P1dB
Group Delay (w/o cable)
Output IP3
Supply Range voltage
Supply Current
27 dB +.1/-.2 dB typ.
+/-0.5 dB
50 Ohms
2 dB typ.
1.1 to 1.7 GHz
1.3:1 typ..
1.3:1 typ.
>35 dB
+9dB min
很抱歉,暂时无法提供与“32-0125B-02”相匹配的价格&库存,您可以联系我们找货
