102110017
    SEEED(矽递科技)
    LinkIt Smart 7688 Duo联发科物联网开发板ATmega32U4板载OpenWrt
102110017 数据手册
        LinkIt Smart 7688 Duo SKU 102110017      The Linklt Smart 7688 development platform offers two developments boards:  Linklt Smart 7688: MPU only. Powered by Media Tek MT7688.      Linklt Smart 7688 Duo: MPU and MCU. Powered by Media Tek MT7688 and ATmega 32U4.        What is LinkIt Smart 7688 Duo  LinkIt Smart 7688 Duo is an open development board compatible with Arduino Yún sketches,  based  on  the OpenWrt Linux  distribution,  MT7688  and  ATmega32u4.  The  board  is  designed  especially to enable the prototyping of Rich IoT Application for smart house or office. Since it is  compatible with Arduino, this allows you to use different features from Arduino Yún and LinkIt  Smart  7688  Duo,  which  will  help  you  build  rich  applications  based  on  various,  robust  and  compiled Arduino Yún sketches. The board offers you the memory and packet storage to enable  robust video processing. The platform also offers options to create device applications in Python,  Node.js and C programming language.    LinkIt Smart 7688 duo is a co‐design product by Seeed Studio and MediaTek. It brings together  the parties' knowledge in open hardware and industry leading reference designs for IoT devices  to create this powerful development board.    LinkIt  Smart  7688  duo  is  fully  supported  on  the  MediaTek  Labs  site:  check  out  the LinkIt  sectionand register here to download the SDK, participate in the Forums, and more.      Note (important)  In order to protect the product from improper operation, please pay attention to below notes.  Choose more reliable power adapter with stable output.  Recommended conditions of power input source for 7688:       1. Overshoot voltage of power input should not over 5.5.       2. Voltage wave should be within ±100mV of rated voltage.           Features  580 MHz MIPS CPU      Single input single output(1T1R) Wi‐Fi 802.11 b/g/n (2.4G)      Pin‐out for GPIO, I2C, SPI, SPIS, UART, PWM and Ethernet Port      32MB Flash and 128MB DDR2 RAM      USB host      Micro SD slot      Support for Arduino (ATmega32U4)              Specifications  Category Feature Specification Chipset              MT7688AN              Core              MIPS24KEc              Clock speed              580MHz              Working voltage              3.3V              Chipset              ATmega32U4              Core              Atmel AVR              Clock speed              8MHz              Working voltage              3.3V              Dimensions              60.8 x 26 mm              Flash              32MB              RAM              128MB DDR2              USB Power              5V (USB micro-B)              VCC              3.3V (Pin Breakout)              Pin Count              3 (MT7688AN) 24 (ATmega32U4)              Voltage              3.3v              Pin Count              8 (ATmega32U4)              Voltage              3.3v              MPU              MCU              PCB Size              Memory              Power Source              GPIO              PWM              Max. Resolution              16 bits (customizable)              31.25kHz@8-bit, Timer 0 (4 sets)              Maximum  Frequency@Resolution              2MHz@2‐bit,122Hz@16‐bit,  Timer 1 & 3 (4 sets)              187.5kHz@8-bit, 46.875kHz@10-bit, Timer 4 (6 sets)              Pin Count              12 (ATmega32U4)              Voltage              3.3v              Pin Count              8 (ATmega32U4)              Set count              1 (ATmega32U4)              Pin numbers              S0, S1, S2, S3              Max. Speed              4 MHz              Set count              1              Pin numbers              D2, D3              Speed              400K              ADC              External Interrupts              SPI/SPIS              I2C              1 (ATmega32U4)              Set count              1 (MT7688AN)              UART Lite              P8, P9 (MT7688AN)              Pin numbers              D0, D1 (ATmega32U4)              0.5 Mbps (MT7688AN)              Max. Speed              USB Host              Communication              User Storage              0.5 Mbps (ATmega32U4)              Set count              1 (MT7688AN)              Pin numbers              P6, P7              Connector type              Micro-AB              Wi-Fi              1T1R 802.11 (2.4G)              Ethernet              1-port 10/100 FE PHY              Pin numbers              P2, P3, P4, P5              SD Card              Micro SDXC              b/g/n SD   Schematic Diagram        Technical Details  Dimensions 56mm x 26mm x 18mm  Weight  G.W 14g      Battery  Exclude  Part List  LinkIt Smart 7688 Duo 1  ECCN/HTS  ECCN 5A002.a.1  HSCODE  8543909000  Certification  Certification FCC,CE                                      https://www.seeedstudio.com/LinkIt‐Smart‐7688‐Duo‐p‐2574.html/12‐10‐18
102110017 价格&库存
很抱歉,暂时无法提供与“102110017”相匹配的价格&库存,您可以联系我们找货
