A10340-U1
A10340-U1
    ANTENOVA(安诺亚)
    EVAL BOARD ANT CALVUS
A10340-U1 数据手册
Calvus Penta-band SMD Antenna Part No. A10340 gigaNOVA ® Product Specification 1 Features      GSM/UMTS antenna supporting up to 5 frequency bands High efficiency Easy to integrate Intended for SMD mounting Supplied in tape on reel Calvus supports the following communication standards: GSM/GPRS/EDGE GSM850 (E)GSM900 GSM1800 (DCS) GSM1900 (PCS) CDMA2000 1xRTT/EV-DO/EV-DV UMTS WCDMA/HSPA Band Classes: 1,2,3,4,6,8,9,12,14,15 Bands I – VI Bands VIII – X Other Standards Korean PCS DECT TD-SCDMA AWS 2 Description Calvus uses a ground plane in order to radiate efficiently, but the ground plane must not be present underneath the antenna itself. The antenna uses a matching circuit to achieve optimized results for the specific frequency bands that are required. This product specification shows the performance of the antenna when optimized to cover a typical penta-band reception: GSM850/900/1800/1900 and WCDMA. If the antenna is used for fewer than 5 bands, higher efficiencies are possible. 3 Applications       Femto / Pico base stations Vehicle tracking Machine to machine communication Remote monitoring Remote security Vending machines Antennas for Wireless M2M Applications 1 Product Specification 09MD-0023-6-PS Calvus GSM SMD Antenna Part No. A10340 4 Part numbers A10340 150 5 General data Product name Calvus GSM SMD Part Numbers: A10340 Frequency (typical) 824MHz-960MHz 1710MHz -2170MHz Polarization Linear Operating temperature -40 ºC to +85 ºC Impedance with matching 50  Weight
A10340-U1 价格&库存
很抱歉,暂时无法提供与“A10340-U1”相匹配的价格&库存,您可以联系我们找货
