Part No:
PA.25A
Description:
Anam Hexa-Band Cellular SMT Antenna
800 MHz to 2200 MHz
Features:
Compact High Efficiency Antenna
Surface Mount Device
Dimensions: 35*5*6mm
Manufactured in an IATF16949 Approved Facility
RoHS & REACH Compliant
SPE-11-8-061-L
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Pattern
7
5.
Mechanical Drawing
10
6.
Eval Board Drawing
11
7.
Antenna Integration Guide
12
8.
Recommended Reflow Temperature Profile
Packaging
21
Changelog
22
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-11-8-061-L
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
The PA.25A is ceramic cellular antenna designed for in-device mounting. The PA.25A is mounted through
SMT process and can be used in varying applications based on it’s small form factor of just 35*6*5mm.
Introduction
Typical Applications Include:
- Body Worn Devices
- Hand-held IoT Devices
- Remote Monitoring
Introduction
This ceramic multiband cellular antenna uses high grade ceramics which have been developed in Taoglas
through years of expertise in delivering the right materials for high performance antennas. Taoglas, through
constant research and development have designed a small form factor high efficiency antenna for use across
cellular bands from 800MHz to 2170MHz.
Introduction
The PA.25A is manufactured and tested in our IATF16949 approved facility.
Introduction
The PA.25 is a unique SMT solution which is delivered on tape and reel. For very detailed integration
information additional to this specification please download our comprehensive PA.25 integration
application note from our website. For further information, please contact your regional Taoglas customer
support team.
SPE-11-8-061-L
www.taoglas.com
3
2.
Specifications
Electrical
3.
Antenna Characteristics2.
Band
Frequency (MHz)
4G/3G/NB-IoT/Cat M
Band 5,8,18,19,20,26,27
3.
1710~2200
70
-1.55
2.00
VSWR
Impedance
58
-2.39
50Ω
Polarization
Linear
Radiation
Properties
Omnidirectional
Max
Input
Power
5W
3.51
Antenna Radiation Patterns3.
Antenna
Mechanical
Dimensions (mm)
3.
Peak Gain
(dBi)
很抱歉,暂时无法提供与“PAD.25”相匹配的价格&库存,您可以联系我们找货
