ZPRGF-20
ZPRGF-20
    MMBNETWORKS
    USB PROGRAMMING FIXTURE Z357PA2X
ZPRGF-20 数据手册
RapidConnect Programming Fixture ZPRGF-20 The RapidConnect Programming Fixture provides developers with a selection of convenient interfaces for programming and debugging a RapidConnect ZigBee module. Compatibility The following table shows the module versions that each programming fixture can be used to program. Power J13 is used to select between USB or user-provided DC power sources. To use the USB connection as a power source, the shorting jumper on J13 should be on pins 1-2 (this is the default position). To use an external DC power source, the shorting jumper must be moved to pins 2-3. The on-board LDO will convert either USB-provided 5V or user-provided external power to 3.3V. USB Connection 5V up to 325mA Alternate Power Connectors (J15 or J7 - see I/O section) Recommended DC Power Source 4-5VDC 325 mA (Note: If supplying power on J15, do not supply power on J7) Absolute Max Input Voltage 16VDC (Note: Higher voltage levels will result in damage to the unit). LEDs Four LED indicators are provided: TX – Flashes when the module transmits serial data RX – Flashes when the module receives serial data MAIN PWR – Lights when there is 3.3V power present on the board MODULE PWR – Lights when there is 3.3V power present on the ZigBee module Connectivity J10 jumper installed on pins 1-2 and pins 3-4 (the default positions for those jumpers) Normal USB operation - connects module TX/RX pins to USB interface. ( Note: COM port will only be present when the module is powered) 25 Prince Arthur Ave. Toronto, Ontario, Canada M5R1B2 416.636.3145 info@mmbnetworks.com www.mmbnetworks.com Fixture SKU Compatible Module SKU ZPRGF-20 Z357PA20, Z357PA21 ZPRGF-10 Z357PA10 I/O Refer to the Ember EM357 data sheet for complete GPIO usage details and specs. J12 – Ember Debug and Programming InSight Port Pin 1 = +3.3v Pin 6 = JCLK/SWCLK Pin 2 = JTDO/SWO Pin 7 = JTMS/SWDIO Pin 3 = nJRST Pin 8 = nReset Pin 4 = JTDI Pin 9 = PTE Pin 5 = GND Pin 10 = PTD J14 – mini-B USB Connector J2 – Bootloader Mode Installed = Bootloader mode enabled J7 – Alternate Power Connection Pin 1 = Vin Pin 2 = GND (Note: When supplying power on J7, install a jumper on J8 pins 1-2 and J13 pin 2-3, and do not connect a DC plug to J15. See Power section) J1 – EM357 GPIO J1 pin 1 = +3.3v J1 pin 2 = PB3 J1 pin 3 = PB4 J1 pin 4 = NRESET J1 pin 5 = PA4 J1 pin 6 = PA5 J1 pin 7 = PB2 J1 pin 8 = PA6 J1 pin 9 = PB1 J1 pin 10 = GND All other connections are reserved. Ordering Information The RapidConnect Programming Fixture is included in RapidSE or RapidHA Development Kits, but the fixture can also be purchased separately from MMB Networks or its distributors, using the SKU ZPRGF-20. Rev 1.1 | March 2014
ZPRGF-20 价格&库存
很抱歉,暂时无法提供与“ZPRGF-20”相匹配的价格&库存,您可以联系我们找货
