SPB104-AL-1
SPB104-AL-1
    H&DWIRELESSAB
    WIFI SD CARD 802.11B/G
SPB104-AL-1 数据手册
SPB104-WiFi 802.11b+g SDIO Evaluation Kit APPLICAT IO NS H om e A utomati on The SPB104 WiFi solution and Lowest power consumption the AVR32 EVK1104 is a quick solution in the market for embedded applications. start for developers that want to enter the home automation High RF output TX power and market such as AMR, RX sensitivity surveillance, access control or Supports both SDIO and SPI as home appliances. option. Indus try Sens or N etw orks Delivered fully tested and WiFi in combination with AVR32 calibrated can easily be installed and used Support for either external for industry sensors or remote antenna or internal chip control thanks to the pre- antenna by the use of a integration of the EVK and the availability of WiFi infrastructure. awitching antenna connector. Photo: SPB104 – WiFi 802.11b+g SDIO Evaluation kit Card Media A pplic ations In all media applications the problem of how to access and change the media is easily solved with WiFi and with the high speed and security functions of 802.11, media such as mp3, IP-radio or video are transferred fast and secure. The SPB104 is a complete WLAN card for evaluation and development for the 802.11b/g standard compliant WiFi component HDG104 from H&D Wireless AB. Together with platforms like the Atmel EVK1104 for the AVR32 CPU developers can evaluate and develop their own wireless applications based on the HDG104 and the feature rich AVR32 platform from Atmel. The HDG104 enables a cost efficient ultra low power, high performance and feature rich WiFi client solution. It provides up to 54 Mbit/s data rate when operating in the OFDM mode and up to 11 Mbit/s data rate when operating in the DSSS/CCK mode. HDG104 integrates RF IC, baseband/MAC IC, EEPROM and RF filters into a highly integrated and optimized SIP (System In Package) solution with high quality and reliability. This minimizes the need of external components, simplifying assembly and test. This highly integrated solution is optimized for customer applications running on a host CPU. The host interface supports SDIO and SPI. Internal RAM comprises both code and data memory eliminating the need for external RAM, Flash or ROM memory interfaces. Baseband firmware, FW, is stored on the host and downloaded at start up. MAC address, trimming values etc are stored in the on board EEPROM. • Data Rates: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54Mbps • Modulation: QPSK, 16QAM, 64QAM DBPSK, DQPSK, CCK, OFDM with BPSK • WEP and AES hardware encryption accelerator up to 128 bit. • On-chip RF filter for the ISM band 2.4GHz • An internal 32 kHz oscillator maintains real time in power save mode, allows the high frequency clock to be turned off. • Extensive DMA hardware support for data flow to reduce CPU load. • Low cost and low power consumption by use of Ultra Low Power (ULP) technology • On-board 160 kB SRAM and 1 KB EEPROM eliminates need for external memory for firmware • Internal Boot-ROM. This allows firmware to be downloaded into SRAM from the host • Advanced power management for optimum power consumption at varying load. • External interfaces including SDIO and SPI • Supply voltage 2.75-3.6 V • RoHS Compliant . H&D Wireless AB, official Atmel Wi-Fi partner ”What Do You Want To Connect?” © H&D Wireless AB, Sweden 1452-ARO104 Pre-Integrated Development Kits TEC H N IC AL S UPP OR T The SPB104 is fully tested and calibrated and is targeted for a good Support for the SW drivers, “out-of-the-box” experience together with the AVR32 platforms such installation and SW development as the EVK1004, see www.atmel.com/wifi is provided by Atmel application The SPB104 has full driver support integrated into the AVR32 Software Framework and is fully tested for 802.11b/g compliance on support at the EVK1104 platform. www.atmel.com/avr32. Developers can within minutes start to concentrate on the development of their own application for sensor control, IP-radio and Per form ance of WiFi other data and media applications. The pre-integrated solution has The WiFi solution provided with support for IP-stacks, web-server, ftp, sensor clients and more. The user has access to the H&D Wireless API for the WiFi control and is SPB104 and HDG104 are best in class and market leader is terms supplied with well documented reference designs in source code for * Photo of the SPB104 in one of the SD-card slots on of solution size, power the EVK1104. Ready-made downloadable reference consumption in all modes, designs can up and running within minutes and transmit/receive range, data example web-servers. development can start at once. transfer speed and cost. T URNKE Y SO LUT IO NS Performance data The reference designs provided SERV ICES AVAILAB LE are turnkey solutions that will work first time and can be modified and used for customers own products. Technical Support Software and Setup Hardware Support Application Support Customer application - For more information on any of development our products or services please visit us on the Web at: www.atmel.com/wifi or www.hd-wireless.se H& D W i rel es s A B Norgegatan 1 164 32 Kista Sweden Phone +46 (0)8 55 11 84 60 Fax +46 (0)8 750 99 77 www.hd-wireless.se email: sales@hd-wireless.se H&D Wireless AB, official Atmel Wi-Fi partner ”What Do You Want To Connect?” © H&D Wireless AB, Sweden 1452-ARO104
SPB104-AL-1 价格&库存
很抱歉,暂时无法提供与“SPB104-AL-1”相匹配的价格&库存,您可以联系我们找货
