MB-1
MB-1
    TWIN
    RF EVAL FOR SOT-89 AMPLIFIERS
MB-1 数据手册
MicroAmp MB-1 Circuit Board For SOT-89 Amplifiers FEATURES • Fits SOT-89 amplifier packages • Input/Output blocking capacitors • RF bypass and bias capacitors • Dual bias resistors • RF bias inductor • RO-4350 board material • Fits MicroAmp MH-series housings The MicroAmp MB-1 circuit board is designed for rapid prototyping of many different RF MMIC amplifiers in the SOT-89 package available from manufacturers such as Analog Devices, Avago, Hittite, Mini-Circuits, RFMD, Triquint, and others. This board will fit the MicroAmp MH series of connectorized housings that allow it to be used as a single amplifier stage or cascaded with other MicroAmp boards for added versatility. Boards are fabricated from a high-performance 13 mil thick RO-4350 laminate with RoHS compatble ENIG plating (electroless nickel/immersion gold) on both the component side and the solid bottom ground plane. The board measures 0.490" x 0.590" and mounts into the housing with four #1-72 screws. Amplifiers can be easily designed and assembled with standard surface-mount passive components. It includes provisions for input and output DC blocking capacitors (0603), RF and bias bypass capacitors (0603/0805), dual bias resistors for flexible thermal management (0805), and a RF bias inductor (0805 or 0603). Pads for the RF connectors allow the SMA center pins to be easily soldered to the board after it is installed into the housing, as well as a large pad to connect the completed board assembly to the bias feed-through. AMPLIFIER SCHEMATIC ASSEMBLY REF SIZE FUNCTION C1 C2 C3 C4 C5 R1 R2 L1 U1 J1 J2 J3 0603 0603 0603 0603 0805 0805 0805 0805/0603 SOT-89 DC block DC block Bypass Bypass Bypass DC bias DC bias RF bias Amplifier Input Output Bias For additional product information, please visit www.twinind.com Contact information: 925-866-8946 (phone) 925-866-8937 (fax) Sales@twinind.com
很抱歉,暂时无法提供与“MB-1”相匹配的价格&库存,您可以联系我们找货
