NRF905-EVKIT-433
NRF905-EVKIT-433
    NORDIC(北欧)
    KIT EVALUATION NRF905 433MHZ
NRF905-EVKIT-433 数据手册
PRODUCT SPECIFICATION Q5)(9.,7 nRF905 Evaluation Kit ,1752'8&7,21 The Evaluation Kit for the Q5) Single Chip 433/868/915 MHz RF Transceiver has been developed to enable customers to get hands-on experience with the functionality of the device in their applications. The Q5) Evaluation Kit is convenient for use in the prototyping phase when developing, testing and debugging PC software, microcontroller code and/or electronic circuitry for interfacing towards a Q5) wireless communication link. In the Q5) Evaluation Kit two Q5)86%&RQILJXUDWLRQ%RDUGV are also included. With the Q5)86%&RQILJXUDWLRQ%RDUG, configuration of Q5) and ShockBurst™ communication are easily managed through the Q'3 1ordic 'evelopment 3latform) PC software. Detailed description of the Q5)(9%2$5', the Q5)86%&RQILJXUDWLRQ %RDUG and suggestions for test benches for evaluation of performance parameters are given in the Q5)(9%2$5' documentation. Q5) Evaluation Kits for operation at 433MHz and 868/915MHz are available, • • Q5)(9.,7 Q5)(9.,7 This document covers both versions. *(77,1*67$57(' The Q5)Evaluation Kit contains the following items: • • • • • • • • • Two evaluation boards with the Q5) transceiver Two Q5)86%&RQILJXUDWLRQ%RDUGV for PC interface Two standard male USB A/B cables Two flexible ¼ wave monopole antennas Q5)(9%2$5' documentation Q5)(9.,7documentation (this document) Q5)product specification Q'3: configuration and control software for PC 1ordic 'evelopment 3latform User Guide Combined with the antenna, the Q5)(9%2$5' is a complete radio module with a digital interface for connection to application circuitry. Nordic VLSI ASA Revision: 1.0 - Vestre Rosten 81, N-7075 Tiller, Norway 3DJHRI - Phone +4772898900 - Fax +4772898989 January 2004 PRODUCT SPECIFICATION Q5)(YDOXDWLRQNLW Figure 1 shows a typical set-up with the Q5)(9%2$5'V connected to application circuitry in order to develop and debug a complete wireless communication link. J2 &XVWRPHUDSSOLFDWLRQFLUFXLWU\ y y y PC Microcontroller Digital signal processing and control circuitry J2 RF in/out 50 Ohm RF in/out 50 Ohm Q5) (9%2$5' Q5) (9%2$5' JP1 JP1 &XVWRPHUDSSOLFDWLRQFLUFXLWU\ y y y PC Microcontroller Digital signal processing and control circuitry Figure 1 Set-up with the Q5)(9%2$5'6 connected to application circuitry The following precautions should be taken when connecting to the Q5) (9%2$5': • A twisted pair flat cable should be used to connect to header JP1 on the Q5) (9%2$5'. The GND-wires in the twisted pair cable must be connected to both the Q5)(9%2$5'and the customer’s application circuitry board. 7KH FDEOHOHQJWKPXVWEHNHSWDVVKRUWDVSRVVLEOH • The power supply wire and the ground wire connected to the power input connector should be twisted together and kept as short as possible. • Ensure that the peak-to-peak voltage level of the data input and control signals never exceed the Q5) device power supply level. Details regarding digital input/output voltage levels, configuration and timing requirements for control of the Q5) device can be found in the Q5) product specification. &20081,&$7,215$1*('(02 The Q'3 PC software has an in-built feature for easy range testing between two Q5)(9%2$5'V. For details please see the &20081,&$7,215$1*( chapter in the Q5)(9%2$5' documentation. Nordic VLSI ASA Revision: 1.0 - Vestre Rosten 81, N-7075 Tiller, Norway 3DJHRI - Phone +4772898900 - Fax +4772898989 January 2004 PRODUCT SPECIFICATION Q5)(YDOXDWLRQNLW '(),1,7,216 3URGXFWVSHFLILFDWLRQ This Evaluation Kit documentation contains final product specifications. Nordic VLSI ASA reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. /LPLWLQJYDOXHV Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Specifications sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. $SSOLFDWLRQLQIRUPDWLRQ Where application information is given, it is advisory and does not form part of the specification. Table 1. Definitions Nordic VLSI ASA reserves the right to make changes without further notice to the product to improve reliability, function or design. Nordic VLSI does not assume any liability arising out of the application or use of any product or circuits described herein. /,)(6833257$33/,&$7,216 These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Nordic VLSI ASA customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nordic VLSI ASA for any damages resulting from such improper use or sale. Product specification. Revision Date : 30.01.2004. nRF905 Evaluation Kit order code : 300104-nRF905-EVKIT-433 300104-nRF905-EVKIT-868/915 All rights reserved ®. Reproduction in whole or in part is prohibited without the prior written permission of the copyright holder. Nordic VLSI ASA Revision: 1.0 - Vestre Rosten 81, N-7075 Tiller, Norway 3DJHRI - Phone +4772898900 - Fax +4772898989 January 2004 PRODUCT SPECIFICATION Q5)(YDOXDWLRQNLW
NRF905-EVKIT-433 价格&库存
很抱歉,暂时无法提供与“NRF905-EVKIT-433”相匹配的价格&库存,您可以联系我们找货
