MicroAmp MB-4 Circuit Board
For SOT-343 (SC-70) Amplifiers
FEATURES
• Fits SOT-343 (SC-70) amplifier packages
• Input/Output blocking capacitors
• RF bypass and bias capacitors
• Dual bias resistors
• RF bias inductor
• RO-4350 board material
• Fits MicroAmp MH-series housings
The MicroAmp MB-4 circuit board is designed for rapid prototyping of many different RF MMIC amplifiers in SOT-343 (SC-70) 4-pin
packages that use a common RF output and bias pin from manufacturers such as Avago (ADA) and others. This board will fit the
MicroAmp MH series of connectorized housings that allow it to be used as a single amplifier stage or cascaded with other MicroAmp
boards for added versatility. Boards are fabricated from a high-performance 13 mil thick RO-4350 laminate with RoHS compatible
ENIG plating (electroless nickel/immersion gold) on both the component side and the solid bottom ground plane. The board
measures 0.490" x 0.590" and mounts into the housing with four #1-72 screws. Amplifiers can be easily designed and assembled
with standard surface-mount passive components. It includes provisions for input and output DC blocking capacitors (0603), RF and
bias bypass capacitors (0603/0805), dual bias resistors for flexible thermal management (0805), and a RF bias inductor (0805 or
0603). Pads for the RF connectors allow the SMA center pins to be easily soldered to the board after it is installed into the housing,
as well as a large pad to connect the completed board assembly to the bias feed-through.
REF SIZE
AMPLIFIER SCHEMATIC
ASSEMBLY
C1
C2
C3
C4
C5
R1
R2
L1
U1
J1
J2
J3
0603
0603
0603
0603
0805
0805
0805
0805/0603
SOT-343 (SC-70)
FUNCTION
DC block
DC block
Bypass
Bypass
Bypass
DC bias
DC bias
RF bias
Amplifier
Input
Output
Bias
For additional product information, please visit www.twinind.com
Contact information: 925-866-8946 (phone) 925-866-8947 (fax) Sales@twinind.com
很抱歉,暂时无法提供与“MB-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+89.397821+10.83600
- 国内价格 香港价格
- 1+119.648001+14.50270
- 5+117.210705+14.20730
- 10+114.8668010+13.92320
- 25+112.4295025+13.62770
- 50+110.3304050+13.37330
