SG923-0004 Kraken Eval Board
Overview
Features
SG923-0004 Kraken Eval Board provides an
easy way for customers to evaluate and develop
applications with Kraken Wi-Fi modules. The
eval board provides power to the module and
brings communications interfaces to standard
connectors.
• Variety of Standard Communications Interfaces
- 10/100Base-T (RJ45)
- 3 UART ports (2 DB9)
- 2 USB ports – Type A host, Mini-B Device
- 1 SPI port (Header)
• GPIO and Peripherals
- I2S Digital Audio interface (Header)
- 8-bit camera interface (Header)
- Timer I/O (Header
• On board regulator accepts 4-12V (5V optimal)
Most signals can also be used as generalpurpose IO, and are available at standard 0.1”
pitch headers.
Ordering Information
Packaging
Eval Kit
1-321-255-0515
WWW.SAGRAD.COM
Order Number
SG923-0004
DOC#: SG914-0013 rev. 0.1
Eval Board Components
J8 UART 0
RS232 Port
Linear Regulator
J10 UART
1 RS232
Port
J7, J9, J6
UART 0, 1, and 2
TTL Ports
5V Input (4-12V acceptable)
2.1/5.5mm plug, center positive
JP1 - I2S, AC97, Timer IO
J3 – RJ45 10/100 Ethernet
JP2 – SPI/GPIO
P2 – Camera/GPIO
J4 – Type A
USB Host Port
1-321-255-0515
WWW.SAGRAD.COM
J5 – Mini-B
USB Device Port
Connector Pinouts and Descriptions
UART Connectors
SIGNAL NAME
PIN NUMBER
DESCRIPTION
NOTES
UART 0 DB9 (J8)
RXD0_232
2
UART0 Receive Data (input)
RS232 Level
TXD0_232
3
UART0 Transmit Data (output)
RS232 Level
5
Signal Ground
GND
UART 0 Header (J7) (Remove resistor R8 to use J7)
3.3V
1
Power to RS232 driver
GND
2
Signal/Power Ground
RXD0
3
3.3V CMOS level – Also GPIO
TXD0
4
5
Handshaking loopback to 6
6
Handshaking loopback to 5
UART 1 DB9 (J10)
RXD1_232
2
UART1 Receive Data (input)
RS232 Level
TXD1_232
3
UART1 Transmit Data (output)
RS232 Level
5
Signal Ground
GND
UART 1 Header (J9) (Remove resistor R9 to use J9)
3.3V
1
GND
2
Signal/Power Ground
RXD1
3
TXD1
4
5
6
UART 2 Header (J6)
3.3V
1
GND
2
Signal/Power Ground
RXD2
3
UART2 Receive Data (input)
TXD2
4
UART2 Transmit Data (output)
5
6
1-321-255-0515
WWW.SAGRAD.COM
P2 Camera/GPIO Connector
SIGNAL NAME
PIN NUMBER
DESCRIPTION
3.3V
1
3.3V Power
CAMCLKOUT
2
Camera master clock output
GND
3
Ground
NOTES
GPIO GPJ11
CAMRESET
4
Camera reset output
GPIO GPJ12
CAMPCLK
5
Camer pixel clock input
GPIO GPJ8
CAMD0
6
Camera data bit 0
GPIO GPJ0
GND
7
Ground
CAMD1
8
Camera data bit 1
GPIO GPJ1
CAMVSYNC
9
Camera vertical sync input
GPIO GPJ9
CAMD2
10
Camera data bit 2
GPIO GPJ2
GND
11
Ground
CAMD3
12
Camera data bit 3
GPIO GPJ3
CAMHREF
13
Camera horizontal sync input
GPIO GPJ10
CAMD4
14
Camera data bit 4
GPIO GPJ4
GND
15
Ground
CAMD5
16
Camera data bit 5
GND
17
Ground
CAMD6
18
Camera data bit 6
GPIO GPJ5
GPIO GPJ6
GND
19
Ground
CAMD7
Camera data bit 7
GPIO GPJ7
DESCRIPTION
NOTES
JP2 SPI/GPIO Connector
SIGNAL NAME
PIN NUMBER
1
3.3V
2
3.3V Power
SPICLK1
3
SPI Clock
GPIO GPG7
SPIMOSI1
4
SPI Master Output Slave Input
GPIO GPG6
SPIMISO1
5
SPI Master Input Slave Output
GPIO GPG5
SS1
6
SPI Slave Select
GPIO GPG3
GND
7
Ground
8
GND
9
Ground
10
TCLK0
11
SPI Interrupt
12
GND
13
Ground
14
GND
15
Ground
GND
16
Ground
1-321-255-0515
WWW.SAGRAD.COM
TCLK0 timer clk – GPIO GPB4
JP1 I2S, AC97, Timer, GPIO
SIGNAL NAME
PIN NUMBER
DESCRIPTION
3.3V
1
3.3V Power
CDCLK
2
I2S master clock output, AC97 RST
GND
3
Ground
I2S_SCLK
4
I2S/AC97 serial clock input/output
GND
5
Ground
I2S_SDI
6
I2S/AC97 serial data input
GND
7
Ground
I2S_SDO
8
I2S/AC97 serial data output
GND
9
Ground
I2S_LRCK
10
I2S frame output, AC97 SYNC,
GND
11
Ground
TOUT3
12
Timer 3 output
GND
13
Ground
TOUT2
14
Timer 2 output
GND
15
Ground
TCLK0
16
Timer 0 clock input
1-321-255-0515
WWW.SAGRAD.COM
NOTES
GPIO GPE2
GPIO GPE1
GPIO GPE3
GPIO GPE4
GPIO GPE0
GPIO GPB3
GPIO GPB2
GPIO GPB4
Schematic
1-321-255-0515
WWW.SAGRAD.COM
很抱歉,暂时无法提供与“SG923-0004”相匹配的价格&库存,您可以联系我们找货
