Electrical Properties:
Both surfaces low-tribocharging at 50% RH
Conductive grid layer 1 x 104 to < 1 x 106 ohms at 50% RH
Adhesive copolymer resistivity 1 x 109 ohms (nominal) acrylic based adhesive
Copolymer layer 8 x 1012 ohms (nominal)
Physical Properties:
• 1.9 mil (0.0019”), (0.049 mm) total thickness
• No silicone (adhesive, film backing, release material)
• Max Temperature 60°C (140°F)
• Non-corrosive
Tape is wound on a paper core.
ANSI/ESD S20.20 requires that all nonessential insulators, such
as those made of plastics and paper, must be removed from the
workstation. Substituting ESD tape for regular tape (a very high
tribocharging insulator) protects your ESD susceptible products.
Property
Test Method
Tensile Strength - Longitudinal
ASTM D 882
Tensile Strength - Transverse
ASTM D 882
Elongation - Longitudinal
ASTM D 882
Elongation - Transverse
ASTM D 882
Static Decay Time
FTMS 101B, M4046
Base Film Thickness
Peeling Force
Cohesion Force
LCTS-T2-4
Adhesion to Steel
LCTS-T3-4
Use and Storage:
Users shall determine the suitability of the product for its intended use.
For best results, tape inventory should be continually replenished. It is
recommended that rolls of tape be stored flat and rotated (flipped over to
the other side) periodically. Tapes should be stored in a dry, well ventilated
room with a reasonably consistent temperature of 68°F (20°C) and be
protected from exposure to direct sunlight. Tape should not be stored in
ultraviolet sunlight, moisture, or heat. Tape over one year old should be
evaluated by the user to determine acceptability for the user’s application.
Desco Industries, Inc. recommends those tracking useful life of product
to use shipping/invoice date as Desco Industries, Inc. expressly warrants
that for a period of one (1) year from the date of purchase, our Wescorp
Brand ESD Tape will be free of defects in material (parts) and workmanship
(labor). See details of Limited Warranty online at Desco.com/Warranty.aspx
If not otherwise noted tolerance +/- 10%.
*Wescorp is a Desco Industries brand.
Note: Tape rolls may vary slightly in color
Value
160 N/mm sq.
270 N/mm sq.
160%
50%
0.5 sec.
30 micron
12 N
12 hrs
0.300 kg/25mm min.
Width - See Metric Note
Tape
Conductive Shielding Grid
Tape widths are nominal
metric ±0.8 mm (±1/32").
1/2"
3/4"
1"
2"
is 12
is 18
is 24
is 48
mm
mm
mm
mm
nominal
nominal
nominal
nominal
or
or
or
or
0.472"
0.709"
0.945"
1.890"
0.5"
.75"
1"
2"
Core
Length
81250
81251
81252
81253
3"
118 ft.
RoHS 3, REACH, and Conflict Minerals Statement
None of the RoHS 3 restricted hazardous substances, REACH
substances of very high concern as of 2020/01/16, or Conflict
Minerals are intentionally added in manufacturing this product.
Ref: European Union Directive (EU) 2015/863 amending Annex
II of the RoHS Directive 2011/65/EU, and Regulation (EC) No.
1907/2006/CE.
Specifications and procedures subject to change without notice.
Made in Malaysia
WESCORP* ESD CONDUCTIVE SHIELDING GRID TAPE, PAPER CORE
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710
PHONE: (909) 627-8178 WEB SITE: Desco.com
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE: (781) 821-8370 WEB SITE: Desco.com
© 2020 DESCO INDUSTRIES INC
Employee Owned
DRAWING
NUMBER:
81250
DATE:
September
2020
很抱歉,暂时无法提供与“81253”相匹配的价格&库存,您可以联系我们找货
