FAM3
Flexible Absorbant Material
Version 2.240919
FAM3 is a flexible EMI absorber which also has excellent thermal conductivity. This
product can be used to suppress EMI issues over a wide range of frequencies whilst
simultaeously transfering heat away from a hot spot. FAM3 can be supplied in a
number of different formats ranging from standard sheets to custom die cuts for ease
of manufacture.
Features
Provide effective EMI suppression over a wide frequency range (10MHz to 18GHz)
Ultra-thin and extremely flexible, can be easily fitted to a wide range of form-factors
UL approved non-conductive adhesive backing available as an option
Highly effective in preventing resonance and suppressing coupling
High surface resistance (106 ohms)
Manufacturing friendly solution
Can be cut to any shape
Applications
Notebooks, PCs, workstations LNBs for satellite systems
Mobile communications equipment
Base stations for mobile phones and handsets Peripheral devices for computers
Wireless equipment Mobile phones
High speed clocks and timing devices
RFID (Radio Frequency Identification) systems NFC (Near field communication)
systems Wireless chargers
Properties
REACH Compliant
ROHS Compliant
Property
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
VAT #: GB 116 662 714
FAM3
Unit
Test Method
Operating Temperature
-40 to 85
˚C
Applicable Frequency
0.001 to 18.0
GHz
Thickness Range
0.25/0.50/0.75
mm
Max. Dimension
400 X 400
mm
Surface Resistance
10
ohm
ASTM D257
Density
4.8
g/cm³
ASTM D792
RoHS Compliance
2002/95/EC
Yes
Halogen-Free
No
6
FAM3
Standard Weights & Dimensional Tolerance
Size
Weight (gr)
Thickness
(mm)
0.25
0.50
0.75
100x100
10.00
24.00
36.00
200x200
40.00
96.00
144.00
400x400
160.00
384.00
576.00
* All measurements in weights are in gr
** All sizes are in mm
Die-Cut
Thickness
Tolerances
Thickness (mm)
Tolerance (mm)
0.3
±0.03
0.5
±0.05
0.8
±0.08
1.0
±0.1
1.2
±0.12
1.5
±0.15
2.0
±0.2
2.5 - 3.5
±0.25
4.0 - 4.5
±0.3
5.0
±0.35
6.0 - 8.0
±0.4
9.0
±0.45
10.0
±0.5
>10.0
±0.5
Sheet Shape Examples
* Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application.
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our
control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the
suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation,
or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are
assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing or future patents covering any product or material or its use.
Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com
FAM3-400-400-0.5-1A 价格&库存
很抱歉,暂时无法提供与“FAM3-400-400-0.5-1A”相匹配的价格&库存,您可以联系我们找货
