8
7
6
5
4
3
2
1
REVISION CHANGES
12.00
1.75
1.55
D
5.50
REV
.30
A
.05
2.00
( 1.19 )
PICKUP
CENTER
.15
1.20
C
BY
APPROVED
2013-09-18
JIM KLINE
GL CHANG
D
.15
1.50
.15
4.00
3.20
2.00
INITIAL DRAWING RELEASE
DATE
.05
( 1.07 )
8.00
DESCRIPTION
( .05 ) ASSUMED
SOLDER PAD
THICKNESS
.15
.05
C
RECOMMENDED
PCB LAYOUT
( 5.09 ) TO
PICKUP
CENTER
SCALE
( .50 )
CLEARANCE
MIN.
5:1
1.60
B
SECTION
( 1.70 )
SOLDER
.10
.40
.05
( .20 )
( 3.00 )
CLEARANCE
ZONE MIN.
( 2.10 )
SOLDER
B
( 4.20 )
CLEARANCE
ZONE MIN.
A-A
PACKAGING NOTES:
1.
2.
3.
4.
5.
6.
A
10 SPROCKET HOLE PITCH CUMULATIVE TOLERANCE
CARRIER CAMBER IS WITHIN 1 MM IN 250 MM.
MATERIAL: TRANSPARENT POLYSTYRENE ALLOY
ALL DIMENSIONS MEET EIA-481-B REQUIREMENTS.
PACKING LENGTH PER 22 INCH REEL: 98.5 METERS
COMPONENT LOAD PER 13 INCH REEL: 4000 PIECES
* CAD MAINTAINED DRAWING *
MANUAL CHANGES UNAUTHORIZED.
PRINTED COPIES OF THIS DOCUMENT
ARE CONSIDERED UNCONTROLLED
7
STATE (SOLDERED
AS SHOWN)
HEIGHT
mm
FORCE
grams
RESISTANCE
m
PEAK STRESS
MPa
ESTIMATED
CYCLE LIFE
COMPRESSED 10%
(1.40)
(51)
(9)
(360)
INFINITE
(1.10)
(145)
(6)
(1063)
(~50K)
UNCOMPRESSED
(1.55)
COMPRESSED 20%
PRODUCTION DRAWING
REVISION CONTROLLED
DOCUMENT
(0)
(1.25)
COMPRESSED 30%
BLOCK TOLERANCES APPLY TO
METRIC UNITS ONLY. DUAL
DIMENSIONS IF SHOWN ARE FOR
REFERENCE ONLY AND ARE
DISPLAYED IN 3 PLACES FOR
CONVERSION PURPOSES ONLY.
THIS DRAWING IS GENERATED
FROM A 3D SOLID MODEL AND
MUST BE ACCOMPANIED BY THE
MODEL FOR COMPLETE
DOCUMENTATION
8
.20
(99)
(7)
ANGULAR:
X.
X.X
6
.4
.20
.10
3
1.0
3RD ANGLE
PROJECTION
THICKNESS:
SIZE:
DESIGNED IN PRO/ENGINEER
SCALE:
15:1
SHEET
5
1
OF
1
B
(~500K)
.080
.004
FINISH:
SMD CONTACT
CUSTOMER:
67BCG2003201508R00
PROGRAM NAME:
.000025 Au OVER .00127 - .00305 Ni
DRAWN BY:
REV:
JIM KLINE
APPROVED BY:
GL CHANG
INFORMATION CONTAINED IN THIS DOCUMENT IS CONFIDENTIAL AND PROPRIETARY TO LAIRD
IT MY NOT BE DISCLOSED TO ANYONE WITHOUT WRITTEN AUTHORIZATION FROM LAIRD
3
A
PART NUMBER:
CUSTOMER PART NUMBER:
4
1. BURRS SHALL NOT EXCEED 10% OF MATERIAL
THICKNESS OR 0.15mm WHICHEVER IS LESS.
2. PART SHALL BE FREE OF OIL OR GREASE.
3. REFERENCE DIMENSIONS ARE SHOWN IN
PARENTHESES (DIM).
PART DESCRIPTION:
COPPER BERYLLIUM (UNS C17200)
ALLOY 25 1/2 HARD TEMPER (TD02)
HEAT TREATED TO DPH 373 MIN (TH02)
TOLERANCES:
(712)
MATERIAL / TEMPER:
UNITS: mm
.X =
.XX =
.XXX =
(0)
GENERAL NOTES:
2
DATE:
2012-12-12
REV:
DATE:
2013-09-18
TECHNOLOGIES.
TECHNOLOGIES.
1
A
很抱歉,暂时无法提供与“67BCG2003201508R00”相匹配的价格&库存,您可以联系我们找货
