2800
    ADAFRUIT
    MICRO NFC/RFID TRANSPONDER - NTA
2800 数据手册
Micro NFC/RFID Transponder - NTAG203 13.56MHz PRODUCT ID: 2800 DESCRIPTION - This tiny micro NFC/RFID tag is super small, and contains an NTAG203 chip plus antenna. It's super tiny, flexible and a great way to DIY an RFID or NFC device if you're interested in designing your own ring, wearable or whatever other tiny device with near field communication incorporated. Contains 144 bytes of readwrite accessible memory You can use this with our PN532-based RFID reader breakouts & shields, and will work with all the latest cellphones or tablets that have NFC built in. Note that since the antenna is so small you'll need to put the tag right up against the device that's reading it. Can be used to control a cellphone with commands, URLs, unlocking, etc. https://www.adafruit.com/products/2800 2/19/2016 Technical Details Dimensions: 15.6mm x 6mm Android NFC developer info Some handy Android NFC Apps that you can use NTAG203 Product page
很抱歉,暂时无法提供与“2800”相匹配的价格&库存,您可以联系我们找货
    • 1+34.30224
    库存:8
