WIRELESS / RFID / NFC
MiFare Classic (13.56 MHz) tag assortment 1KB
PRODUCT ID: 365
DESCRIPTION
One of each of our favorite Mifare Classic 1K tags - 5 in total!
Credit card size
1" diameter 'laundry' clear tag
1" diameter 'laundry' white tag
Key fob
Sticker
These can be read by almost any 13.56MHz RFID/NFC reader but make sure it can
handle MiFare cards as there are a few other encoding standards (like FeLica) They
are tested and work great with both our PN532 NFC/RFID breakout board and
Adafruit NFC/RFID Shield for Arduino!
These chips can be written to & store up to 1 KB of data in writable EEPROM divided
into banks, and can handle over 100,000 re-writes. You can use our PN532
NFC/RFID breakout board or Adafruit NFC/RFID Shield for Arduino to read and
write data to the EEPROM inside the tag. There is also a permanent 4-byte ID
burned into the chip that you can use to identify one tag from another - the ID
number cannot be changed.
These use the S50 chipset, which used to be the 'classic' NFC chipset. In ~2014, the
NFC forum decided not to support this chipset anymore, so newer phones do not
support the MiFare classic. This only matters if you're trying to use this tag with a
phone/tablet.
http://www.adafruit.com/products/365
7/16/2015
很抱歉,暂时无法提供与“365”相匹配的价格&库存,您可以联系我们找货
