M6E-DEVKIT
M6E-DEVKIT
    THINGMAGIC
    KIT DEV M6E MULTIPROTOCOL
M6E-DEVKIT 数据手册
MERCURYDevKit For ThingMagic UHF RFID Embedded Modules The Mercury DevKit for ThingMagic UHF RFID modules contains all the components necessary to begin reading and writing RFID tags and develop ing RFID-enabled applications. A powerful application programming interface (MercuryAPI) provides code examples, a graphical read-write demo program, and delivers a consistent programmatic interface for development with all ThingMagic readers and embedded module products. Ordering Information Module DevKit Chassis Specifications Development kits are module specific. A single module is included with each DevKit purchase. Antenna Connector DevKit with M6e module M6E-DEVKIT USB Connectors DevKit with Micro module M6E-M-DEVKIT DevKit with Micro-LTE module M6E-MICRO-DEVKIT DevKit with M5eCompact Module M5E-C-DEVKIT Module Dev Kit Power Adapter • • • • • R-TNC connectors supporting one, two, or four monostatic antennas (depending on module type) • 2 USB connections: one attached to the serial port of the module (all modules) and one attached to the USB port (M6e only). GPIO Access • 4 External switches to set GPIO input state • 4 External LEDs to indicate GPIO output states Note: M6e module GPIO lines are soft ware selectable in or out; M5e-Compact GPIO lines are hard-wired for two inputs and 2 outputs In: 90-264 V, 0.4 A, 47-63 Hz Out: +9 V @ 1.4 A Max total output power: 12.6 W US, European, UK, and Australian plugs Module DevKit Contents Application Programming Interface Hardware The ThingMagic MercuryAPI is a powerful programming interface with example applications and sample code in C, Java and C#/.NET. The MercuryAPI provides a consistent programmatic interface across all ThingMagic fixed and embedded reader products to speed development and time to market of highly complementary RFID-enabled offerings. • • • • • • RFID Module mounted in DevKit chassis 9V AC Power adapter Sample RFID tags USB cable Antenna Cable 7.5 inch wideband antenna 865-879 MHz: 7 dBiC min 90-264 V, 0.4 A, 47-63 Hz Supported OS and application types Software and Documents (available online) Software and Documents • • • • Reader firmware Release Notes and Users Guide MercuryAPI MercuryAPI Release Notes and Programmer Guide Code space required • C-API designed to provide support for embedded systems • .NET applications in the .NET Compact Framework v2.0 • Windows applications in the .NET Framework • Windows applications in the Java Framework • Linux (Intel) and MacOSX applications in the Java Framework • Android applications in the Java framework • 32k Basic Gen2 • 64k Advanced Gen2 • 96k Mulitprotocol Specifications subject to change without notice. - MAKING RFID EASY TO USE ThingMagic is dedicated to driving the barriers to deploying RFID technology as low as possible. We design our products to be easy to use out-of-the box and to deliver predictable, reliable, and repeatable performance. Our development tools require little RFID expertise, enabling you to rapidly design, test, and deploy your RFID solutions. Developers Kit Mercury API Universal Reader Assistant Included with every ThingMagic reader Developer Kit, the MercuryAPI supports the entire line of ThingMagic finished readers and embedded RFID modules A common development platform, supporting an extensive variety of hardware to connect, configure, and control ThingMagic readers. A utility for advanced demo, testing, and tuning of all ThingMagic readers. Reduces complexity for novice users while permitting low-level control for advanced developers. - Test chassis - Cables - Antenna - Sample Tags - Full schematics to help you design your own complimentary components M6e Reader DevKit shown ISO 9001 : 2008 REGISTERED FIRM ISO 13485 : 2003 REGISTERED FIRM © 2015 JADAK LLC 02.21.17 USA Office European Office +1 315.701.0678 Phone +1 315.701.0679 Fax email: info@jadaktech.com +31 (0)76.522.5588 Phone +31 (0)76.522.4747 Fax email: info@jadak.eu 7279 William Barry Blvd. North Syracuse, NY 13212-3349 Emmastraat 16 4811 AG Breda The Netherlands Asia Pacific Office Building 8 Gangtian Industrial Square GangTian Road Suzhou Industrial Park JiangSu, China 215024 +86 512.6283.7080 Phone email: info@jadaktech.com www.jadaktech.com
M6E-DEVKIT 价格&库存
很抱歉,暂时无法提供与“M6E-DEVKIT”相匹配的价格&库存,您可以联系我们找货
