USB-5EC
USB-5EC
    THINGMAGIC
    模块
    MOD USB RFID READER
USB-5EC 数据手册
A DIVISION OF TRIMBLE USB Plus+ RFID Reader World-class UHF RFID Desktop Reader The ThingMagic USB Plus+ RFID Reader is ideal for applications that require reading and writing of EPC Global Gen2 tags on a desk or workstation and in areas where space is limited. The USB Plus+ is controlled and powered by a host PC or laptop through a USB interface and is compatible with ThingMagic’s application development tools, permitting rapid creation of RFID solutions. With a software adjustable read distance up to 3 ft (0.91 m), the USB Plus+ supports a variety of applications, including RFID tag commissioning, manufacturing WIP, document tracking, library book check in/out, retail point of sale, event and hospitality services, hospital patient workflows, and more. The high-performance internal antenna of the USB Plus+ is also ideal for commissioning high memory tags and reading small form factor RFID tags more effectively. Ordering Information Regulatory & Safety Reader USB-5EC Regulatory Development Kit USB-5EC-DEVKIT FCC 47 CFR Ch.1 Part 15 Industrie Canada RSS-21 0 ETSI EN 302 208 v1.4.1 Safety IEC 60950-1 (ed.2) US-17650-UL Tag / Transponder Protocols RFID Protocol Support EPCglobal Gen 2 (ISO 18000-6C) with Anti-Collision and DRM RF Interface Antenna Internal linear polarized antenna with peak Gain 1 dBi from 860–960 MHz RF Power Output Separate read and write levels (into the antenna) are command-adjustable from 10 dBm to 23 dBm (200mW), +/- 1.0 dBm accuracy Frequency Pre-configured for the following regions: FCC 902-928 MHz (Americas) ETSI 865.6-867.6 MHz, 869.85 MHz (EU) KCC 917-920.8 MHz (Korea) TRAI 865-867 MHz (India) ACMA 920-926 MHz (Australia) SRRC-MII 920-925 MHz (P. R. China) ‘Open’ (Customizable) 860-960 MHz Power DC Power Required DC Voltage: 5 VDC (Powered by USB interface) DC Power: 2.7 W (540 mA ) max Supplied interface cable terminates in two type-A plugs: one for power and signal, the second for additional power if needed Idle Power Consumption 1.7 W max at idle (Power management modes can be used to reduce this to as little as 0.1 W) Environment Operating Temp. -20C to +60C Storage Temp. -40C to +85C Architecture Data/Control Interface Physical USB mini-B connector, with 2 foot (61 cm) cable terminated in A-type plug Signaling Asynchronous serial interface with 3.3/5V logic levels; baud rates from 9600 to 921,600 bps I/O Two I/O command controlled LEDs and two I/O command queried switches Protocol Command-response protocol protected by length field and 16-bit CRC Physical Dimensions (not including stand) 97 mm L x 61 mm W x 25 mm H (3.8 in L x 2.4 in W x 1.0 in H) User-accessible Flash Memory 16 kB Tag Buffer 200 tags Performance Tag Read Rate Up to 200 tags/second Max Read Distance Up to 3 ft (0.91 m) depending on tag sensitivity and orientation Specifications subject to change without notice. A DIVISION OF TRIMBLE MAKING RFID EASY TO USE ThingMagic is dedicated to driving the barriers to deploying RFID technology as low as possible. We design our products to be easy to use out-of-the box and to deliver predictable, reliable, and repeatable performance. Our development tools require little RFID expertise, enabling you to rapidly design, test, and deploy your RFID solutions. Developers Kit Mercury API Universal Reader Assistant Everything needed to read and write RFID tags and begin developing RFID-enabled applications: A common development platform, supporting an extensive variety of hardware to connect, configure, and control ThingMagic readers. A utility for advanced demo, testing, and tuning of all ThingMagic readers. Reduces complexity for novice users while permitting low-level control for advanced developers. - Test chassis - Cables - Antenna - Sample Tags - Full schematics to help you design your own complementary components A DIVISION OF TRIMBLE For more information, visit www.thingmagic.com To purchase ThingMagic products, please email sales@thingmagic.com or call 1-866-833-4069 (International callers dial +1 617-499-4090) ThingMagic, A Division of Trimble 1 Merrill Street Woburn, MA 01801 ©2013 ThingMagic – a division of Trimble Navigation Limited. ThingMagic and The Engine in RFID are registered trademarks of Trimble Navigation Limited. Other marks may be protected by their respective owners. All Rights Reserved. 7.9.13
USB-5EC 价格&库存
很抱歉,暂时无法提供与“USB-5EC”相匹配的价格&库存,您可以联系我们找货
