MB.200.C
MB.200.C
    TAOGLASLIMITED
    BASE MOUNT FOR WIFI ANTENNAS
MB.200.C 数据手册
SPECIFICATION Part No. : Product Name Features MB.200.C : Magneto : 3 Way Base Mount for LTE or WIFI MIMO 2*2 antennas - Magnetic Mount - Wall Mount - Desktop Mount SMA(F) Jacks for Antennas SMA(M)Straight Plug on Cable Standard RG316 1 meter cable length Dimensions 80mm *96mm * 25mm RoHS compliant Desk Top/ Magnetic Mount Wall Mount SPE-15-8-020/A/IC Page 1 of 12 1. Introduction The MB.200 is a sturdy 3 way base mount for LTE or WIFI MIMO 2*2 Antennas. The standard base version comes with high quality 1 meter small diameter Teflon jacket RG316 cable to allow for flexibility of placement. The base has undergone extensive pull force testing. The base SMA connectors where the antenna elements connect are SMA(F), so the mating antenna needs to be SMA(M) straight connector type. The base cable itself has a SMA(M) connector. The cable length and cable connector types are customizable, subject to MOQ. The connector can be customizable on the base itself subject to NRE and MOQ. Options - Magnetic - Desktop - Wall Magnetic Mount With six super-magnets embedded, the base mounts permanently to metal surfaces Wall Mount Mounting holes in the base make it easy to mount on a wall Desktop EVA foam under the base ensures a good grip for desktop use In practice any antenna model with a standard SMA(M) connector can be used with this base. Taoglas has for 2G/3G/4G applications the TG.35, TG.30, TG.09, or TG.08 For Dual-band WiFi we recommend the TG35 or the GW71. Contact your regional Taoglas sales office for support. SPE-15-8-020/A/IC Page 2 of 12 2. RG316 Cable Specification 2.1 Drawing – Cross Section 2.2 Structure and Dimensions SPE-15-8-020/A/IC Page 3 of 12 SPE-15-8-020/A/IC Page 4 of 12 2.3 Cable Insertion Loss SPE-15-8-020/A/IC Page 5 of 12 2.4 Electrical &Physical Specification MB200 Port1 Attenuation 500MHz 1000MHz 2000MHz 3000MHz 4000MHz 5000MHz 6000MHz S12 -0.64 -0.94 -1.39 -1.68 -2.21 -2.54 -2.84 Nom. Impedance 50 Ohm MB200 Port1 Frequency (MHz) 500MHz 1000MHz 2000MHz 3000MHz 4000MHz 5000MHz 6000MHz S12 -0.66 -0.96 -1.36 -1.81 -2.25 -2.58 -2.96 Nom. Impedance 50 Ohm MECHANICAL Casing ABS+PC Coaxial Cable RG316 Cable Length 1 meters Connector SMA(M)ST Connector Max. Torque 0.9 Nm Weight Magnetic mount (unit) 220 g 1.0 kgf ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH SPE-15-8-020/A/IC Page 6 of 12 3. Magnetic Pull Force (Kilogram-Force (kgf) Horizontal Pull Force Breakdown : 1.28Kgf SPE-15-8-020/A/IC Page 7 of 12 4. Mechanical Drawing SPE-15-8-020/A/IC Page 8 of 12 5. Packaging SPE-15-8-020/A/IC Page 9 of 12 SPE-15-8-020/A/IC Page 10 of 12 6. Mounting Type 6.1 Wall Mount installation Reference Antenna: TG.35.0113 6.2 Magnet Mount installation Reference Antenna: TG.35.0113 SPE-15-8-020/A/IC Page 11 of 12 6.3 Desktop Mount installation SPE-15-8-020/A/IC Page 12 of 12
MB.200.C 价格&库存
很抱歉,暂时无法提供与“MB.200.C”相匹配的价格&库存,您可以联系我们找货
