SF0930-6200-3.5
SF0930-6200-3.5
    AMPHENOLSVMICROWAVE(安费诺MAO)
    SMA单排模块
    ATTENUATOR18GHZ3.5DB50OHMSMA
SF0930-6200-3.5 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION DATE APPROVED E DCN 41727 10/15 DAL F DCN 43286 04/17 STW REV PRODUCT DATA DRAWING 1.210 30.73 MAX 2X .250 ACROSS FLATS MATERIAL: .370 9.40 BODY & COUPLING NUT: LOCK RING & CONTACTS STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1, OR ASTM A582, TYPE 303 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 SLEEVE: BRASS PER ASTM B16, ALLOY UNS No. C36000 BELLOWS SPRING: ELECTRO DEPOSITED NICKEL: GOLD PLATED INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 60/70 RESISTOR ELEMENT: .312 HEX. 1/4-36 UNS-2A ELECTRICAL CHARACTERISTICS VSWR ALUMINUM NITRIDE SUBSTRATE WITH TANTALUM NITRIDE RESISTOR: GOLD PLATED TERMINATIONS ATTENUATOR ATTENUATION INCREMENT ACCURACY DC TO 4 GHz 4 TO 12.4 GHz (dB) (dB) NOTES: FINISH: BODY & COUPLING NUT: CONTACTS & SLEEVE: 0 TO .5 1. REPLACE "XX" IN PART NUMBER WITH DESIRED dB VALUE. PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 1 TO 6 7 TO 15 16 TO 20 30 TO 40 50 OHMS DC TO 18.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION +0.00 -0.30 +/-.3 +/-.5 +/-.7 +/-1.00 1.15 1.25 12.4 TO 18.0 GHz 1.35 UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GPF 10/02/15 CHECKED: APPROVED: DAL 10/02/15 JM 03/18/96 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA JACK TO PLUG DC-18.0 GHz ATTENUATOR SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF0930-6200-XX SHEET 1 OF 1
SF0930-6200-3.5 价格&库存
很抱歉,暂时无法提供与“SF0930-6200-3.5”相匹配的价格&库存,您可以联系我们找货
