Product Specifications
PART NO.:
VL47B5263A-F8SD-I
REV: 1.0
General Information
4GB 512Mx64 DDR3 SDRAM NON-ECC UNBUFFERED SODIMM 204-PIN
Description
The VL47B5263A is a 512Mx64 DDR3 SDRAM high density SODIMM. This dual rank memory module consists of
sixteen CMOS 256Mx8 bits with 8 banks DDR3 Synchronous DRAMs in BGA packages and a 2K EEPROM with
thermal sensor in an 8-pin MLF package. This module is a 204-pin small-outline dual in-line memory module and is
intended for mounting into an edge connector socket. Decoupling capacitors are mounted on the printed circuit board
for each DDR3 SDRAM.
Features
Pin Description
204-pin, small-outline dual in-line memory module (SODIMM)
Fast data transfer rate: PC3-8500
VDD = VDDQ = 1.5V +/-0.075V
JEDEC standard 1.5V +/-0.075V I/O (SSTL_15 compatible)
VDDSPD = 3.0V to 3.6V
Eight internal component banks for concurrent operation
8-bit pre-fetch architecture
Bi-directional differential data-strobe
Nominal and dynamic on-die termination (ODT)
ZQ calibration support
Programmable CAS# latency: 7 (DDR3-1066)
Programmable burst; length (8)
Average refresh period 7.8 us
Asynchronous reset
Fly-by topology
On board terminated command, address, and control bus
Serial presence detect (SPD) EEPROM with thermal sensor
Thermal sensor range: -40oC to +125oC (Max +/-3oC accuracy)
JEDEC pinout
Gold edge contacts
Lead-free, RoHS compliant
PCB: Height 30.00mm (1.181”), double sided component
Operating temperature (TOPER): -40 to +95oC (module screening using
commercial DRAM)
o
o
Notes: Double refresh rate is required when 85 C < TOPER
很抱歉,暂时无法提供与“VL-MM7-4EBN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+754.175381+93.56171
