VL-MPEU-K1E32
VL-MPEU-K1E32
    VERSALOGIC
    ENCRYPTED SSD 32GB MINIPCIE IT
VL-MPEU-K1E32 数据手册
Encrypted Memory Mini PCIe Module ƒƒ Extremely small Mini PCIe module format ƒƒ Encrypted flash memory ƒƒ 256-bit AES Encryption ƒƒ Password attack protection ƒƒ 8 to 32 GB on-board capacity ƒƒ Industrial temp. (-40º to +85ºC) operation ƒƒ MIL-STD-202G shock/vibe Highlights Overview Mini PCIe Module Format The VL-MPEu-K1 is an extremely small and rugged encrypted memory module based on the industry-standard Mini PCIe module format. Unlike typical I/O expansion boards, Mini PCIe allows additional I/O functions to be added to a system with almost no increase in overall system/ package size. Mini PCIe modules provide a simple, economical, and standardized way to add I/O functions to embedded computer products. Small and flexible. AES Encryption Hardware 256-bit AES encryption/decryption. Strong Data Protection 7 to 48 character password with attack protection. On-board Memory Up to 32 GB Flash memory. Industrial Temperature Operation -40° to +85°C operation for harsh environments. MIL-STD-202G Qualified for high shock / vibration environments. Class 3 Manufacturing (optional) IPC-A-610 Class 3 for applications requiring extreme reliability. Details In a very small package, this encrypted memory board enables embedded systems to utilize hardware AES encryption/decryption to secure data. The integrated cryptographical engine offers 256-bit key AES encryption with a 7 to 48 character password size. This encrypted memory module utilizes a high performance AES hardware engine to encrypt and decrypt data as it is transferred to and from the private flash drive. Because the encryption keys are only used within the AES hardware engine, they are never accessible to host software. Additionally, keys are never transferred off the board, protecting against hardware-based manin-the-middle attacks. The VL-MPEu-K1 utilizes an eMMC flash memory device with a managed interface that addresses error correction code (ECC), wear leveling, and bad block management technology. The on-board management interface takes the burden off the host controller and increases speed for higher system performance. This board includes user-configurable areas of encrypted and non-encrypted memory. The non-encrypted memory block may be used as a system boot device if desired. To defend against password attacks, the VL-MPEu-K1 can optionally limit the number of incorrect password attempts. After 10 incorrect password attempts, the private drive encryption key is destroyed permanently preventing access to the data stored on the private drive. It also meets MIL-STD-202G specifications for shock and vibration, making it at home in harsh environments. This encrypted memory board is compatible with a variety of popular x86 Windows operating systems. The module utilizes USB signaling and can be used in any system that supports USB signaling at the Mini PCIe socket. It is manufactured to IPC-A-610 Class 2 standards. Class 3 versions are available for extremelyhigh-reliability applications. Product customization is available, even in low quantities. Options include conformal coating, application-specific testing, BOM revision locks, special labeling, etc. VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com Encrypted Memory Mini PCIe Module Specifications Ordering Information Model VL-MPEu-K1E8 VL-MPEu-K1E32 VL-MPEu-K1E8C # Function Encrypted memory. 8 GB eMMC flash storage. Encrypted memory. 32 GB eMMC flash storage. Encrypted memory. 8 GB eMMC flash storage. IPC-A-610 Class 3 manufacturing. VL-MPEu-K1E32C # Encrypted memory. 32 GB eMMC flash storage. IPC-A-610 Class 3 manufacturing. Operating Temp. -40° to +85°C -40° to +85°C -40° to +85°C -40° to +85°C General Environmental ## Special Order Product – Contact VersaLogic Sales for minimum order quantities and lead time. Accessories Part Number Hardware VL-HDW-108 VL-HDW-110 Board Size Power Requirements Manufacturing Standards Regulatory Compliance Mini PCIe Signal Type Operating Temperature Storage Temperature Altitude Cooling Airflow Requirements Thermal Shock Humidity Vibration, Sinusoidal Sweep † Vibration, Random † Description Mini PCIe module hold-down screws (10) for use with 2.5 mm standoffs Mini PCIe module hold-down screws (10) for use with 2.0 mm standoffs Mechanical Shock † Memory Software Flash Memory Hardware Encryption Operating Systems Mini PCIe module (full size): 30 mm x 50.95 mm x 2.59 mm 3.3V @ 0.3W (supplied from the Mini PCIe socket) Standard IPC-A-610 Class 2 modified Optional IPC-A-610 Class 3 modified RoHS USB -40° to +85°C -40° to +85°C Operating * To 15,000 ft. (4,570m) Storage To 40,000 ft. (12,000m) None (fanless) None (free air) 5°C/min. over operating temperature Less than 95%, noncondensing MIL-STD-202G, Method 204, Modified Condition A: 2g constant acceleration from 5 to 500 Hz, 20 min. per axis MIL-STD-202G, Method 214A, Condition A: 5.35g rms, 5 min. per axis MIL-STD-202G, Method 213B, Condition G: 20g halfsine, 11 msec. duration per axis Up to 32 GB. eMMC 4.4x compliant. AES 256-bit Compatible with Windows XP and XPe, Windows 7 and Windows Embedded 7. * For extended altitude information contact VersaLogic Sales Dept. † MIL-STD-202G shock and vibe levels are used to illustrate the ruggedness of this product in general. Testing to higher levels and/or different types of shock or vibration methods can be accommodated per the specific requirements of the application. Contact a VersaLogic Sales Engineer for further information. Specifications are subject to change without notification. PCI Express is a registered trademark of the PCI-SIG. All other trademarks are the property of their respective owners. • Falcon EPU • VL-MPEe-U2 Module Other VersaLogic Mini PCIe Modules Model VL-MPEe-A1E VL-MPEe-A2E VL-MPEe-E3E VL-MPEe-U2E VL-MPEe-W2E VL-MPEs-F1Exx VL-MPEs-S3E VL-MPEu-G2E Function Analog input (12-bit resolution) Analog input (16-bit resolution) Gigabit Ethernet adapter Quad serial plus twelve GPIOs Wi-Fi 802.11 a/b/g/n mSATA drive (4/16/32 GB) SATA adapter GPS receiver Signaling PCIe PCIe PCIe PCIe PCIe SATA SATA USB VersaLogic Corporation  •  12100 SW Tualatin Rd., Tualatin, OR  97062  •  (503) 747-2261  •  Info@VersaLogic.com  •  www.VersaLogic.com 01/29/14
VL-MPEU-K1E32 价格&库存
很抱歉,暂时无法提供与“VL-MPEU-K1E32”相匹配的价格&库存,您可以联系我们找货
