P0185
P0185
    TERASIC(友晶科技)
    HMI TOUCHSCREEN 2.4" COLOR
P0185 数据手册
CONTENTS CHAPTER 1 INTRODUCTION ........................................................................................................... 3 1.1 The Package Contents ................................................................................................................................ 3 1.2 Assemble LT24 with DE0-Nano ................................................................................................................. 4 1.3 Connectivity ............................................................................................................................................... 5 1.4 Getting Help ............................................................................................................................................... 7 CHAPTER 2 ARCHITECTURE OF LT24 ............................................................................................ 8 2.1 Features....................................................................................................................................................... 8 2.2 Layout and Block Diagram......................................................................................................................... 8 CHAPTER 3 USING THE LT24 ........................................................................................................ 10 3.1 Pin Definition of 2x20 GPIO Connector .................................................................................................. 10 3.2 Using LCD................................................................................................................................................ 12 3.3 Using Touch.............................................................................................................................................. 13 CHAPTER 4 PAINTER DEMONSTRATION ....................................................................................... 15 4.1 Description ............................................................................................................................................... 15 4.2 System Description ................................................................................................................................... 16 4.3 LT24 LCD Controller ............................................................................................................................... 17 4.4 Setup Painter Demo on Terasic DE2-115 FPGA Board ........................................................................... 17 4.5 Painter Demo for Other Terasic FPGA Mainboards ................................................................................. 18 CHAPTER 5 LT24 DISPLAY ............................................................................................................ 19 5.1 Description ............................................................................................................................................... 19 5.2 System Description ................................................................................................................................... 20 5.3 LT24 LCD Initialization ........................................................................................................................... 20 5.4 Setup Demo on Terasic DE0-Nano FPGA Board ..................................................................................... 21 5.5 LT24_Display Demo for Other Terasic FPGA Mainboards ..................................................................... 22 CHAPTER 6 APPENDIX .................................................................................................................. 23 LT24 User Manual 1 www.terasic.com June 1, 2015 6.1 Revision History ....................................................................................................................................... 23 6.2 Copyright Statement ................................................................................................................................. 23 LT24 User Manual 2 www.terasic.com June 1, 2015 Chapter 1 Introduction The Terasic LT24 is a 2.4” LCD touch module with 240(H) x 320(V) display resolution. It can be bundled with various Terasic FPGA development boards through the 2x20 GPIO interface. The LT24 is powered directly from the FPGA mainboard. It doesn’t require any power adaptor. The kit contains complete reference design and source code for the Painter application. This chapter provides the key information about the kit. 1.1 The Package Contents The LT24 kit comes with the following items:      LT24 touch LCD module Two silicon footstands Two screw nuts Two hexagon copper pillars CD download guide The system CD contains technical documents of LT24 kit, which include component datasheets, demonstrations, schematic and user manual. Users can download the CD from the link below: http://cd-lt24.terasic.com Figure 1-1 shows the contents of LT24 kit. Figure 1-1 Contents of LT24 kit LT24 User Manual 3 www.terasic.com June 1, 2015 1.2 Assemble LT24 with DE0-Nano There are two holes reserved on the LT24 for the screws to stabilize the installation with other mainboards by adding copper pillars onto them. The following steps take DE0-Nano as an example to demonstrate the installation with the copper pillars. 1. Install the screw nuts from top to the bottom of screw holes reserved on the LT24. Install the hexagon copper pillars and make sure then are tightened up, as shown in Figure 1-2. Figure 1-2 Install the hexagon copper pillars 2. Cover the two copper pillars of LT24 with two silicon footstands, as shown in Figure 1-3. This procedure can be skipped if the LT24 is assembled with DE0-Nano. Figure 1-3 Install the footstand 3. Connect the LT24 to the GPIO header of DE0-Nano, as shown in Figure 1-4. LT24 User Manual 4 www.terasic.com June 1, 2015 Figure 1-4 LT24 Assembled with DE0-Nano 1.3 Connectivity Figure 1-5, Figure 1-6, Figure 1-7 and Figure 1-8 below show the connectivity of LT24 to DE0-Nano, DE1-SoC, DE2-115 and C5G(Cyclone V GX Starter Kit), respectively. The LT24 is powered from FPGA mainboard. It is not necessary to connect the LT24 with a power adaptor. Figure 1-5 LT24 with DE0-Nano LT24 User Manual 5 www.terasic.com June 1, 2015 Figure 1-6 LT24 with DE1-SoC Figure 1-7 LT24 with DE2-115 Figure 1-8 LT24 with C5G (Cyclone V GX Starter Kit) LT24 User Manual 6 www.terasic.com June 1, 2015 1.4 Getting Help Here is the information to get help if you encounter any problem:  Office Hours: 9:00 a.m. to 6:00 p.m. (GMT +8)  Telephone: +886-3-575-0880  Email: support@terasic.com LT24 User Manual 7 www.terasic.com June 1, 2015 Chapter 2 Architecture of LT24 This chapter lists the features and describes the architecture of 2.4” LCD touch module (LT24). 2.1 Features The key features of this module are listed below:    240(H) x 320 (V) pixel resolution LCD with 65K RGB color Single resistive touch 2x20 GPIO interface 2.2 Layout and Block Diagram Component and Layout The top view of LT24 is shown in Figure 2-1. Figure 2-1 Top view of LT24 The bottom view of LT24 is shown in Figure 2-2. It depicts the layout and indicates the locations of connectors and key components. LT24 User Manual 8 www.terasic.com June 1, 2015 Figure 2-2 Bottom view of LT24 module Block Diagram Figure 2-3 shows the block diagram of LT24. An ADC chip is used to handle the 4-wire touchscreen. Figure 2-3 Block diagram of LT24 LT24 User Manual 9 www.terasic.com June 1, 2015 Chapter 3 Using the LT24 This chapter provides information on how to control the hardware of 2.4” LCD touch module (LT24), including the definition of 2x20 GPIO interface, LCD control, and touch control signals. 3.1 Pin Definition of 2x20 GPIO Connector The 2x20 GPIO female connector on LT24 connects directly to the 2x20 GPIO male connector on Terasic FPGA development boards. Figure 3-1 illustrates the signal names of 2x20 GPIO Header. Figure 3-1 Signal names of 2x20 GPIO connector LT24 User Manual 10 www.terasic.com June 1, 2015 Table 3-1 shows the LT24 pin assignments for the 2x20 GPIO pins in Quartus II. Table 3-1 LT24 Pin Assignments of 2x20 GPIO in Quartus II Pin Numbers Pin Name Direction IO Standard 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 ADC_PENIRQ_N ADC_DOUNT ADC_BUSY ADC_DIN ADC_DCLK D[3] D[2] D[1] D[0] RD_N WR_N RS D[4] D[5] D[6] D[7] D[8] D[9] D[10] D[11] D[12] D[13] D[14] D[15] CS_N - Input Input Input Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output Output - 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL - LT24 User Manual 11 www.terasic.com June 1, 2015 38 39 40 RESET_N ADC_CS_N LCD_ON Output Output Output 3.3-V LVTTL 3.3-V LVTTL 3.3-V LVTTL 3.2 Using LCD The LCD features 240(H) x 320(V) pixel resolution. The ILI9341 LCD driver is used to drive the LCD display. The 65K-Color, RGB 5-6-5 bits input data based on 8080-system 16-bit parallel bus interface of ILI9341 is used on the LT24. For further information, please refer to the section 7.6.5 “16-bit Parallel MCU Interface” of ILI9341 datasheet in the LT24 System CD. Figure 3-2 shows the signals connected between the ILI9341 and the FPGA. Figure 3-2 Signals of LCD driver connected to FPGA CSX is a low-active chip select pin. D/CX is Data or Command selection pin. When D/CX = 1, data selected. When D/CX = 0, command is selected. WRX is a write signal and writes data at the rising edge. RDX is a read signal and MCU read data at the rising edge. D[15:0] is data bus. Figure 3-3 shows pixel data transfer format. The D0~D7 are used to translate command to ILI9341 in the command mode (D/CX=0). The D0~D15 are used to translate the RGB data to ILI9341 in data mode (D/CX=1). LT24 User Manual 12 www.terasic.com June 1, 2015 Figure 3-3 65K-Color, 5-6-5 bits pixel data format 3.3 Using Touch The AD7843 from Analog Device is a 12-bit analog-to-digital converter (ADC) used to digitize the touch points from the touch panel of LT24 into the corresponding X/Y coordinates on LT24. To obtain the coordinates from the ADC, users need to monitor the interrupt signal ADC_PENIRQ_n coming out of the ADC first. The ADC_PENIRQ_n output remains high in normal condition by connecting a pull high resistor to it. When the touch screen connected to the ADC is trigger via a pen or finger, the ADC_PENIRQ_n output goes low and it initiates an interrupt to FPGA, which instructs a control word to be written to the ADC via the serial port interface. The control word provided to the ADC via the DIN pin is shown in Table 3-2. It controls the conversion start, channel addressing, ADC conversion resolution, configuration, and power-down of the ADC. The detailed information about the order and description of these control bits can be found in the datasheet from the DATASHEET folder in the LT24 System CD. Table 3-2 Control Register Bit Function Description MSB LSB S A2 A1 A0 MODE SER / DEF PD1 PD0 Bit 7 Mnemonic Comment Start Bit. The control word starts with the first high bit on DIN. A new control word can start every 15th S DCLK cycle when in the 12-bit conversion mode, or every 11th DCLK cycle when in 8-bit conversion mode. LT24 User Manual 13 www.terasic.com June 1, 2015 Channel Select Bits. These three address bits, along 6-4 3 A2-A0 MODE 2 SER / DEF 1,0 PD1,PD0 with the SER / DEF bit, control the setting of the multiplexer input, switches, and reference inputs. 12-Bit/8-Bit Conversion Select Bit. This bit controls the resolution of the following conversion. With 0 in this bit, the conversion has a 12-bit resolution, or with 1 in this bit, the conversion has a 8-bit resolution. Single-Ended/Differential Reference Select Bit. Along with Bits A2–A0, this bit controls the setting of the multiplexer input, switches, and reference inputs. Power Management Bits. These two bits decode the power-down mode of the AD7843. Figure 3-4 shows the typical operation of serial interface of AD7843 ADC. The serial clock provides the conversion clock and controls the information transfer to and from the ADC. A complete conversion can be achieved after 24 ADC_DCLK cycles. The detailed behavior of serial port interface can be found in the datasheet of AD7843 ADC. Figure 3-4 Conversion timing of serial port interface LT24 User Manual 14 www.terasic.com June 1, 2015 Chapter 4 Painter Demonstration This chapter shows how to implement the painter demonstration on LT24. The demo is designed in Qsys and running by Nios II processor. Altera SPI IP in Qsys is used to retrieve the touch information from the touch screen. Terasic custom display component in Qsys is used to display image on the 2.4” LCD. This demo requires the following hardware:   Terasic FPGA board LT24 LCD touch module 4.1 Description Figure 4-1 shows the Graphical User Interface (GUI) of Painter demo. The GUI is composed by three sections: Painting Area, Clear Button, and Color Palette. Users can select a color from the color palette and start drawing in the paint area. Click the “Clear” button to clear the painting area. Figure 4-1 GUI of Painter demo Figure 4-2 displays the painting on the canvas area. LT24 User Manual 15 www.terasic.com June 1, 2015 Figure 4-2 Painting demo running on LT24 with DE2-115 4.2 System Description Figure 4-3 shows the system block diagram of Painter demonstration. Terasic custom Qsys component - LT24 LCD controller is used to display 240(H) x 320(V) image. Its source code is located in the “/ip/LT24_Controller” folder of Painter demo project. Qsys built-in SPI controller is used to communicate with the AD7843 ADC via SPI interface to retrieve data from the touch screen. The Nios II program handles touch event and image display. It is stored in either on-chip memory or external memory. The LCD module should be initialized before sending image data to the LCD for image display. Figure 4-3 System block diagram of Painter demonstration LT24 User Manual 16 www.terasic.com June 1, 2015 4.3 LT24 LCD Controller The LT24 LCD controller is a custom Qsys component developed by Teraisc. Its source code is located in the “/ip/LT24_Controller” folder of Painter demo project. Table 4-1 shows the register definition of LT24 LCD controller. The controller base address is defined as LT24_BASE in the Nios II program. The function of writing a control command to the LCD driver is IOWR(LT24_ BASE, 0x00, CommandValue). The function of writing data to the LCD driver is IOWR(LT24_BASE, 0x01, DataValue). Table 4-1 Register Definition and Offset for the Painter Demonstration Byte Offset Register Name Description 0 Control Port 4 Data Port Write control command to the LCD driver Write data to the LCD driver 4.4 Setup Painter Demo on Terasic DE2-115 FPGA Board This section shows how to setup the Painter demo on the Terasic DE2-115 FPGA board.  Hardware Setup Figure 4-4 shows the demo setup of LT24 with DE2-115 FPGA mainboard. The LT24 should be installed on the GPIO expansion header of DE2-115. Figure 4-4 Hardware setup of LT24 with DE2-115  Execute Demonstration Please follow the procedures below to setup the demonstration: LT24 User Manual 17 www.terasic.com June 1, 2015 1. Power off the DE2-115. 2. Mount the LT24 onto the 2x20 GPIO 0 expansion header of DE2-115. 3. Connect the USB-Blaster USB port of DE2-115 to the USB port of host PC with a USB cable. 4. Power on the DE2-115 FPGA board. 5. Both Quartus II and USB-Blaster II driver must be installed on the host PC. 6. Copy the folder Demonstrations//DE2_115_LT24_PAINTER/demo_batch from the LT24 System CD to the host PC and execute “DE2_115.bat”. 7. The Painter demo should be up and running on the LCD.  Source Code The source code of Quartus project for the Painter demo with DE2-115 board is available in the “Demonstrations\DE2_115_LT24_PAINTER” folder from the LT24 System CD. The Eclipse Nios II project workspace is located in the “software” sub-folder under the Quartus project folder. 4.5 Painter Demo for Other Terasic FPGA Mainboards The LT24 System CD also contains Quartus projects for other FPGA mainboards. The locations of source code for the Quartus projects with other Tearsic FPGA mainboards are shown in Table 4-2. For DE1-SoC, two Quartus projects are included in the Ssytem CD. The difference between these two projects is the memory where the Nios II program is running on. For Cyclone V GX Starter kit, there are two Quartus projects included in the LT24 System CD. The difference between these projects is also the memory where the Nios II program is running on. To execute the demo on DE0-Nano, please connect the LT24 to the GPIO-1 expansion header of DE0-Nano. To execute the demo on DE1-SoC, please connect the LT24 to the GPIO-1 expansion header of DE1-SoC. DE0_Nano_SoC_OCRM_LT24_Painter is built by Quartus 14.1, and the other Quartus projects are built by Quartus II v13.1. Table 4-2 Locations of Source Code for the Painter Demo with Other FPGA Boards FPGA Board Memory Location DE0-Nano SDRAM Demonstrations\DE0_Nano_SDRAM_LT24_PAINTER DE2-115 On-chip Demonstrations\DE2_115_OnChipMemory_LT24_PAINTER DE1-SoC SDRAM Demonstrations\DE1_SOC_SDRAM_LT24_PAINTER DE1-SoC On-chip Demonstrations\DE1_SOC_OnChipMemory_LT24_PAINTER Cyclone V GX Starter Kit On-chip Demonstrations\C5G_OnChipMemory_LT24_PAINTER Cyclone V GX Starter Kit SRAM Demonstrations\C5G_SRAM_LT24_PAINTER DE0-Nano-Soc On-Chip DE0_Nano_SoC_OCRAM_LT24_Painter DE2 SDRAM DE2_SDRAM_LT24_Painter LT24 User Manual 18 www.terasic.com June 1, 2015 Chapter 5 LT24_Display This chapter shows how to implement the lt24-display demonstration on LT24. This design is only RTL code, There is not CPU, Memory. This demo requires the following hardware:   Terasic FPGA board LT24 LCD touch module 5.1 Description shows the Graphical User Interface (GUI) of LT24-Display demo. LT24-Display this demo is mainly on the LT24 can respectively show the R, G, B three color base map, as well as a simple line drawing functions. Place in the bottom three colors can click to switch between different color base map, there is a hidden feature, click on the top right corner, you can clear the lines depicted. Figure 5-1 Figure 5-1 GUI of LT24-Display demo LT24 User Manual 19 www.terasic.com June 1, 2015 Figure 5-2 Painting demo running on LT24 with DE0-Nano 5.2 System Description shows the system block diagram of LT24-Display demonstration. LT24_Display of RTL (Verilog) code on the demo project of "/ ip / lt24_display" folder. As Figure 5-3 shown, lt24_display the top module - lt24_display.v contains four block. Pat_update.v is used with Touch (AD7843) connection, pat_update module will receive the AD7843 in touch information (x, y coordinates), and then converted into the corresponding action, this action triggers to the LCD display module generates commands, and command again through cmd2lcd module to convert LCD panel (ILI9341) can accept signals. The last timer module has only one function - to produce a 33ms signal, which is used to make a long delay of the clock, such as LCD during the initial stage will need ms delay. Figure 5-3 Figure 5-3 System block diagram of LT24-Display demonstration 5.3 LT24 LCD Initialization The LCD of LT24 is needed before the initial use of. Because LT24-Display of pure RTL code design, there is no CPU, so can not be used to initial LCD mode CPU-base system (set registers to LT24 User Manual 20 www.terasic.com June 1, 2015 complete the process), as used herein, FSM (Final State Machine) to set the initial flow, refer to "/ip/lt24_display/display.v" file, in initail LCD wait pat_update event after entering the loop. There CPU systems are more flexible, we have to change the process, C-code in order to change what you can; but the reaction time is slower, received from the AD7843 to output to the LCD touch response time will be longer. Compared to pure RTL code of the design, although the initial process because of the limited FSM relatively less flexible, but because the relationship between the hardware processing, AD7843 to LCD's response time faster. 5.4 Setup Demo on Terasic DE0-Nano FPGA Board This section shows how to setup the LT24-Display demo on the Terasic DE0-Nano FPGA board.  Hardware Setup 錯誤! 找不到參照來源。 shows the demo setup of LT24 with DE0-Nano FPGA mainboard. The LT24 should be installed on the GPIO_1 expansion header of DE0-Nano.  Execute Demonstration Please follow the procedures below to setup the demonstration: 1. Power off the DE0-Nano (disconnect USB cable). 2. Mount the LT24 onto the 2x20 GPIO 1 expansion header of DE0-Nano. 3. Connect the USB-Blaster USB port of DE0-Nano to the USB port of host PC with a USB LT24 User Manual 21 www.terasic.com June 1, 2015 cable (Power on). 4. Both Quartus II and USB-Blaster II driver must be installed on the host PC. 5. Copy the folder Demonstrations//DE0_Nano_LT24_Display/demo_batch from the LT24 System CD to the host PC and execute “test.bat”. 6. The RGB-Display demo should be up and running on the LCD.  Source Code The source code of Quartus project for the LT24-display demo with DE0-Nano board is available in the “Demonstrations\DE0_nano_LT24_display” folder from the LT24 System CD. 5.5 Display Demo for Other Terasic FPGA Mainboards The LT24 System CD also contains Quartus projects for other FPGA mainboards. The locations of source code for the Quartus projects with other Tearsic FPGA mainboards are shown in Table 5-1. To execute the demo on DE0-Nano, please connect the LT24 to the GPIO-1 expansion header of DE0-Nano. To execute the demo on DE2-115, please connect the LT24 to the GPIO expansion header of DE2-115. To execute the demo on DE1-SoC, please connect the LT24 to the GPIO-1 expansion header of DE1-SoC. To execute the demo on C5G, please connect the LT24 to the GPIO expansion header of C5G. All the Quartus projects are built in Quartus II v13.1. Table 5-1 Locations of Source Code for the LT24-Display Demo with Other FPGA Boards FPGA Board Location DE0-Nano DE2-115 DE1-SoC Cyclone V GX Starter Kit Demonstrations\DE0_Nano_ LT24_Display Demonstrations\DE2_115_ LT24_ Display Demonstrations\DE1_SOC_ LT24_ Display Demonstrations\C5G_ LT24_ Display LT24 User Manual 22 www.terasic.com June 1, 2015 Chapter 6 Appendix 6.1 Revision Histor y Version Change Log V1.0 V1.0.1 Initial Version (Preliminary) Add painter demo path for de0-nano-soc and DE2. 6.2 Copyright Statement Copyright © 2014 Terasic Technologies. All rights reserved. We will continue to provide examples and lab exercises on our LT24 webpage. Please visit http://lt24.terasic.com for more information. LT24 User Manual 23 www.terasic.com June 1, 2015
P0185 价格&库存
很抱歉,暂时无法提供与“P0185”相匹配的价格&库存,您可以联系我们找货
