P0158
P0158
    TERASIC(友晶科技)
    MODULE 7" LCD TOUCH W/CAMERA
P0158 数据手册
1 CONTENTS CHAPTER 1 INTRODUCTION .......................................................................................................... 1 1.1 About the Package ...................................................................................................................................... 3 1.2 Setup License for Terasic Multi-Touch IP .................................................................................................. 4 1.3 Assembly of MTLC onto Boards with HSMC Connectors ........................................................................ 5 1.4 Connectivity ............................................................................................................................................... 7 1.5 Getting Help ............................................................................................................................................... 9 CHAPTER 2 ARCHITECTURE OF MTLC ...................................................................................... 10 2.1 Features .................................................................................................................................................... 10 2.2 Layout and Components ........................................................................................................................... 10 2.3 Block Diagram of the MTLC ................................................................................................................... 11 CHAPTER 3 USING MTLC.............................................................................................................. 13 3.1 Using the 7” LCD Capacitive Touch Screen ............................................................................................ 13 3.2 Using 5 Megapixel Digital Image Sensor................................................................................................. 16 3.3 Using the Digital Accelerometer .............................................................................................................. 17 3.4 Using the Ambient Light Sensor .............................................................................................................. 17 3.5 Using Terasic Multi-Touch IP .................................................................................................................. 18 CHAPTER 4 MTLC DEMONSTRATIONS ........................................................................................ 20 4.1 System Requirements ............................................................................................................................... 20 4.2 Painter Demonstration .............................................................................................................................. 20 4.3 Picture Viewer .......................................................................................................................................... 24 4.4 Video and Image Processing..................................................................................................................... 26 4.5 Camera Application .................................................................................................................................. 29 4.6 Video and Image Processing for Camera.................................................................................................. 32 4.7 Digital Accelerometer Demonstration ...................................................................................................... 35 CHAPTER 5 APPENDIX ................................................................................................................. 37 5.1 Revision History ....................................................................................................................................... 37 5.2 Copyright Statement ................................................................................................................................. 37 MTLC User Manual 1 www.terasic.com May 22, 2014 Chapter 1 Introduction The Terasic Capacitive Multi-touch LCD and Camera Module (MTLC) is an all-purpose LCD multimedia color touch-screen for FPGA applications and provides multi-touch gesture and single-touch support. A 5-megapixel digital image sensor, ambient light sensor, and 3-axis accelerometer make up the rich feature-set. A HSMC cable is provided to interface with various Terasic FPGA development boards, such as Terasic DE2-115 and TR4 development boards through a HSMC interface on the MTLC. The kit contains complete reference designs and source code for camera, sensing, and painter demonstrations. Once the MTLC is connected and preconfigured with an FPGA hardware reference design including several ready-to-run demonstration applications stored on the provided SD card, software developers can use these reference designs as their platform to quickly architect, develop and build complex embedded systems. Developers can benefit from the use of FPGA-based embedded processing system such as mitigating design risk and obsolescence, design reuse, reducing bill of material (BOM) costs by integrating powerful graphics engines within the FPGA, and lower cost. Figure 1-1 shows a photograph of MTLC. Figure 1-1 MTLC User Manual Video and Embedded Development Kit – Multi-touch 1 www.terasic.com May 22, 2014  Capacitive LCD Touch Screen  Equipped with an 7-inch amorphous-TFT-LCD (Thin Film Transistor Liquid Crystal Display) module  Module composed of LED backlight  Supports 24-bit parallel RGB interface  Converting the X/Y touch coordinates to corresponding digital data via Touch controller. Table 1-1 shows the general physical specifications of the touch screen (Note*). Table 1-1 General Physical Specifications of the LCD Item Specification Unit LCD size 7-inch (Diagonal) - Resolution 800 x3(RGB) x 480 dot Dot pitch 0.1926(H) x0.1790 (V) mm Active area 154.08 (H) x 85.92 (V) mm Module size 164.9(H) x 100.0(V) x 5.7(D) mm Surface treatment Glare - Color arrangement RGB-stripe - Interface Digital -  5-Megapixel Digital Image Sensor            Superior low-light performance High frame rate Low dark current Global reset release, which starts the exposure of all rows simultaneously Bulb exposure mode, for arbitrary exposure times Snapshot-mode to take frames on demand Horizontal and vertical mirror image Column and row skip modes to reduce image size without reducing field-of-view Column and row binning modes to improve image quality when resizing Simple two-wire serial interface Programmable controls: gain, frame rate, frame size, exposure Table 1-2 shows the key parameters of the CMOS sensor (Note*). MTLC User Manual 2 www.terasic.com May 22, 2014 Table 1-2 Key Performance Parameters of the CMOS sensor Parameter Value Active Pixels 2592Hx1944V Pixel size 2.2umx2.2um Color filter array RGB Bayer pattern Shutter type Global reset release(GRR) Maximum data rate/master clock 96Mp/s at 96MHz Frame rate Full resolution Programmable up to 15 fps VGA mode Programmable up to 70 fps ADC resolution 12-bit Responsivity 1.4V/lux-sec(550nm) Pixel dynamic range 70.1dB SNRMAX 38.1dB Supply Voltage Power 3.3V I/O 1.7V~3.1V  Digital Accelerometer  Up to 13-bit resolution at +/- 16g  SPI (3- and 4-wire) digital interface  Flexible interrupts modes  Ambient Light Sensor       Approximates human-eye response Precise luminance measurement under diverse lighting conditions Programmable interrupt function with user-defined upper and lower threshold settings 16-bit digital output with I2C fast-mode at 400 kHz Programmable analog gain and integration time 50/60-Hz lighting ripple rejection Note: for more detailed information of the LCD touch panel and CMOS sensor module, please refer to their datasheets respectively. 1.1 About the Package The kit includes everything users need to run the demonstrations and develop custom designs, as shown in Figure 1-2. MTLC User Manual 3 www.terasic.com May 22, 2014 Figure 1-2 MTLC kit package contents 1.2 Setup License for Terasic Multi-Touch IP To utilize the multi-touch panel in a Quartus II project, the Terasic Multi-Touch IP is required for operation. Error messages will be displayed if the license file for the Multi-Touch IP is not added before compiling projects. The license file is located at: MTLC System CD\License\license_multi_touch.dat There are two ways to install the license. The first one is to add the license file (license_multi_touch.dat) to the “License file” listed in Quartus II, as shown in Figure 1-3. In order to reach this window, please navigate through to Quartus II  Tools  License Setup. Figure 1-3 License Setup The second way is to add license content to the existing license file. The procedures are listed below: Use Notepad or other text editing software to open the file license_multi_touch.dat. 1. The license contains the FEATURE lines required to license the IP Cores as shown in Figure 1-4. MTLC User Manual 4 www.terasic.com May 22, 2014 Figure 1-4 Content of license_multi_touch.dat 2. Open your Quartus II license.dat file in a text editor. 3. Copy everything under license_multi_touch.dat and paste it at the end of your Quartus II license file. (Note: Do not delete any FEATURE lines from the Quartus II license file. Doing so will result in an unusable license file.) . 4. Save the Quartus II license file. 1.3 Assembly of MTLC onto Boards with HSMC Connectors In this section, we would like to introduce how to successfully install the MTLC daughter card to FPGA boards that are equipped with HSMC connectors on top: Figure 1-5 Fixed components in a MTLC kit Inside every MTLC kit package, there should be 2 sets of copper pillars, screws, and nuts as shown in Figure 1-5 These parts are used to install the MTLC on the FPGA board through the mounting holes shown in Figure 1-6. MTLC User Manual 5 www.terasic.com May 22, 2014 Figure 1-6 Mounting holes next to the HSMC connector By doing so, this will ensure a rigid connection between the host board and the HSMC cable. Install the copper pillars and nuts on the mounting holes as shown in Figure 1-7. Figure 1-7 Install copper pillars and nuts on the mounting hole The HSMC cable should be already connected to the MTLC right out of the box. User only needs to connect the HSMC cable to the HSMC connector on the host board as shown in Figure 1-8. MTLC User Manual 6 www.terasic.com May 22, 2014 Figure 1-8 Connect the HSMC cable to the HSMC connector on the host board The final step would be to fasten the screws through the HSMC cable and the copper pillar as shown in Figure 1-9. Figure 1-9 Fasten screws through the HSMC cable to the copper pillars 1.4 Connectivity Here we provide examples of MTLC being connected to different FPGA development boards: Arrow’s SoCKit, TR4, DE2-115, and Altera Cyclone V SoC FPGA development board (C5SoC). MTLC User Manual 7 www.terasic.com May 22, 2014 Figure 1-10 MTLC Connect C5S Figure 1-11 MTLC Connect TR4 Figure 1-12 MTLC Connect DE2-115 MTLC User Manual 8 www.terasic.com May 22, 2014 Figure 1-13 MTLC Connect C5SOC 1.5 Getting Help Here is the contact information if you encounter any problem: Terasic Technologies Tel: +886-3-575-0880 Email: support@terasic.com MTLC User Manual 9 www.terasic.com May 22, 2014 Chapter 2 Architecture of MTLC This chapter provides information regarding features and architecture of the Terasic Capacitive Multi-touch LCD and Camera Module. 2.1 Features The key features of this module are listed as follows:      800x480 pixel resolution LCD with 24-bit color depth Single touch and two-point multi-gesture support 5-Megapixel Digital Image Sensor Digital Accelerometer Ambient Light Sensor 2.2 Layout and Components The picture of the MTLC is shown in Figure 2-1 and Figure 2-2. It depicts the layout of the board and indicates the locations of the connectors and key components. MTLC User Manual 10 www.terasic.com May 22, 2014 Figure 2-1 MTLC PCB and Component Diagram (Top) Figure 2-2 MTLC PCB and Component Diagram (Bottom) 2.3 Block Diagram of the MTLC Figure 2-3 gives the block diagram of the MTLC board. The HSMC connector houses all the MTLC User Manual 11 www.terasic.com May 22, 2014 wires from peripheral interfaces, connecting to the FPGA of a development kit through the HSMC cable. Thus, the user can configure the FPGA to implement any system design. Figure 2-4 illustrates the connection for MTLC to the Terasic FPGA boards. Figure 2-3 Block Diagram of MTLC Figure 2-4 Connection Diagram of MTLC Kit with Terasic FPGA boards MTLC User Manual 12 www.terasic.com May 22, 2014 Chapter 3 Using MTLC This section describes the detailed information of the components, connectors, and pin assignments of the MTLC. 3.1 Using the 7” LCD Capacitive Touch Screen The MTLC features a 7-inch capacitive amorphous TFT-LCD panel. The LCD touch screen offers resolution of (800x480) to provide users the best display quality for developing applications. The LCD panel supports 24-bit parallel RGB data interface. The MTLC is also equipped with a Touch controller, which can read the coordinates of the touch points through a serial port interface. To display images on the LCD panel correctly, the RGB color data along with the data enable and clock signals must act according to the timing specification of the LCD touch panel as shown in Table 3-1. Table 3-2 gives the pin assignment information of the LCD touch panel. Table 3-1 LCD timing specifications ITEM D C L K D E SYMBOL Dot Clock DCLK pulse duty Setup time Hold time Horizontal period Horizontal Valid Horizontal MTLC User Manual M T M I Y A N P X . . . 1/tCLK 4 0 8 8 Tcwh Tesu Tehd tH tHA tHB 3 3 5 0 NOTE MHZ 6 0 % ns ns 1 0 5 6 tCLK 2 tCLK tCLK 800 13 UNIT www.terasic.com May 22, 2014 Blank Vertical Period Vertical Valid Vertical Blank HSYNC setup time HSYNC hold time VSYNC Setup Time VSYNC Hold Time Horizontal Period Horizontal Pulse Width S Y N C D A T A tV tVA ns Thhd 8 ns Tvst 8 ns Tvhd 8 ns 1 0 5 6 3 0 th thpw thfp Horizontal Valid thd MTLC User Manual tH 8 Horizontal Front Porch Hold time 4 5 tH tH Thst thb Vertical Back Porch Vertical Front Porch Vertical Valid Setup time 480 tVB Horizontal Back Porch Vertical Period Vertical Pulse Width 5 6 5 2 5 1 6 2 1 0 8 0 0 5 2 5 1 3 tv tvpw 1 0 2 2 tvb tCLK tCLK tCLK tCLK tCLK th th th tvfp tvd Tdsu 480 8 th th ns Tdsu 8 ns 14 thb+t hpw= 46DC LK is fixed tvpw + tvb = 23th is fixed www.terasic.com May 22, 2014 Table 3-2 Pin assignment of the LCD touch panel FPGA Signal Name Pin Description No. LCD_B0 P28 LCD blue data bus bit 0 LCD_B1 P27 LCD blue data bus bit 1 LCD_B2 J24 LCD blue data bus bit 2 LCD_B3 J23 LCD blue data bus bit 3 LCD_B4 T26 LCD blue data bus bit 4 LCD_B5 T25 LCD blue data bus bit 5 LCD_B6 R26 LCD blue data bus bit 6 LCD_B7 R25 LCD blue data bus bit 7 LCD_DCLK V24 LCD Clock LCD_DE H23 Data Enable signal LCD_DIM P21 LCD backlight enable LCD_DITH L23 Dithering setting LCD_G0 P26 LCD green data bus bit 0 LCD_G1 P25 LCD green data bus bit 1 LCD_G2 N26 LCD green data bus bit 2 LCD_G3 N25 LCD green data bus bit 3 LCD_G4 L22 LCD green data bus bit 4 LCD_G5 L21 LCD green data bus bit 5 LCD_G6 U26 LCD green data bus bit 6 LCD_G7 U25 LCD green data bus bit 7 LCD_HSD U22 Horizontal sync input. LCD_MODE L24 DE/SYNC mode select LCD_POWER_CTL M25 LCD power control LCD_R0 V28 LCD red data bus bit 0 LCD_R1 V27 LCD red data bus bit 1 LCD_R2 U28 LCD red data bus bit 2 LCD_R3 U27 LCD red data bus bit 3 LCD_R4 R28 LCD red data bus bit 4 LCD_R5 R27 LCD red data bus bit 5 LCD_R6 V26 LCD red data bus bit 6 LCD_R7 V25 LCD red data bus bit 7 LCD_RSTB K22 Global reset pin Left or Right Display LCD_SHLR H24 Control Up / Down Display LCD_UPDN K21 Control LCD_VSD V22 Vertical sync input. TOUCH _I2C_SCL T22 touch I2C clock TOUCH _I2C_SDA T21 touch I2C data TOUCH _INT_n R23 touch interrupt MTLC User Manual 15 I/O Standard 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V www.terasic.com May 22, 2014 3.2 Using 5 Megapixel Digital Image Sensor The MTLC is equipped with a 5 megapixel digital image sensor that provides an active imaging array of 2,592H x 1,944V. It features low-noise CMOS imaging technology that achieves CCD image quality. In addition, it incorporates sophisticated camera functions on-chip such as windowing, column and row skip mode, and snapshot mode. The sensor can be operated in its default mode or programmed by the user through a simple two-wire serial interface for frame size, exposure, gain settings, and other parameters. Table 3-3 contains the pin names and descriptions of the image sensor module. Table 3-3 Pin Assignment of the CMOS Sensor FPGA Signal Name Description Pin No. CAMERA_PIXCLK J27 Pixel clock CAMERA_D0 F24 Pixel data bit 0 CAMERA_D1 F25 Pixel data bit 1 CAMERA_D2 D26 Pixel data bit 2 CAMERA_D3 C27 Pixel data bit 3 CAMERA_D4 F26 Pixel data bit 4 CAMERA_D5 E26 Pixel data bit 5 CAMERA_D6 G25 Pixel data bit 6 CAMERA_D7 G26 Pixel data bit 7 CAMERA_D8 H25 Pixel data bit 8 CAMERA_D9 H26 Pixel data bit 9 Pixel data bit CAMERA_D10 K25 10 Pixel data bit CAMERA_D11 K26 11 Snapshot CAMERA_STROBE E27 strobe CAMERA_LVAL D28 Line valid CAMERA_FVAL D27 Frame valid Image sensor CAMERA_RESET_n F27 reset CAMERA_SCLK AE26 Serial clock Snapshot CAMERA_TRIGGER E28 trigger CAMERA_SDATA AE27 Serial data External input CAMERA_XCLKIN G23 clock MTLC User Manual 16 I/O Standard 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V 2.5V www.terasic.com May 22, 2014 3.3 Using the Digital Accelerometer The MTLC is equipped with a digital accelerometer sensor module. The ADXL345 is a small, thin, ultralow power assumption 3-axis accelerometer with high resolution measurement. Digitalized output is formatted as 16-bit twos complement and can be accessed either using SPI interface or I2C interface. This chip uses the 3.3V CMOS signaling standard. Main applications include medical instrumentation, industrial instrumentation, personal electronic aid and hard disk drive protection etc. Some of the key features of this device are listed below. For more detailed information of better using this chip, please refer to its datasheet which is available on manufacturer’s website or under the /datasheet folder of the system CD. Table 3-4 Pin Names and Descriptions of the GSENSOR Module Signal Name GSENSOR_INT1 GSENSOR_INT2 GSENSOR_CS_n GSENSOR_ALT_ADDR GSENSOR_SDA_SDI_SDI O GSENSOR_SCL_SCLK FPGA Pin No. G27 G28 F28 K27 K28 Description Interrupt 1 output Interrupt 2 output Chip Select I2C Address Select Serial Data M27 I/O Standard 2.5V 2.5V 2.5V 2.5V 2.5V Serial Communications Clock 2.5V 3.4 Using the Ambient Light Sensor The APDS-9300 is a low-voltage digital ambient light sensor that converts light intensity to digital signal output capable of direct I2C communication. Each device consists of one broadband photodiode (visible plus infrared) and one infrared photodiode. Two integrating ADCs convert the photodiode currents to a digital output that represents the irradiance measured on each channel. This digital output can be input to a microprocessor where illuminance (ambient light level) in lux is derived using an empirical formula to approximate the human-eye response. For more detailed information of better using this chip, please refer to its datasheet which is available on manufacturer’s website or under the /datasheet folder of the system CD. Table 3-5 Pin names and Descriptions of Ambient Light Sensor Module Signal Name LSENSOR_ADDR_SEL LSENSOR_INT LSENSOR_SCL LSENSOR_SDA FPGA Pin No. J25 L28 J26 L27 MTLC User Manual Description Chip select Interrupt output Serial Communications Clock Serial Data 17 I/O Standard 2.5V 2.5V 2.5V 2.5V www.terasic.com May 22, 2014 3.5 Using Terasic Multi-Touch IP Terasic Multi-Touch IP is provided for developers to retrieve user inputs, including multi-touch gestures and single-touch. The file name of this IP is i2c_touch_config and it is encrypted. To compile projects with the IP, users need to install the IP license first. For license installation, please refer to section 1.2 Setup License for Terasic Multi-Touch IP in this document. The license file is located at: MTLC System CD\License\license_multi_touch.dat The IP decodes I2C information and outputs coordinate and gesture information. The IP interface is shown below: The signal purpose of the IP is described in Table 3-6. The IP requires a 50MHz signal as a reference clock to the iCLK pin and system reset signal to iRSTN. iTRIG, I2C_SCLK, and IC2_SDAT pins should be connected of the TOUCH_INT_n, TOUCH_I2C_SCL, and TOUCH_I2C_SDA signals in the 2x20 GPIO header respectively. When oREADY rises, it means there is touch activity, and associated information is given in the oREG_X1, oREG_Y1, oREG_X2, oREG_Y2, oREG_TOUCH_COUNT, and oREG_GESTURE pins. For the control application, when touch activity occurs, it should check whether the value of oREG_GESTURE matched a pre-defined gesture ID defined in Table 3-7. If it is not a gesture, it means a single-touch has occurred and the relative X/Y coordinates can be derived from oREG_X1 and oREG_Y1. Table 3-6 Interface Definitions of Terasic Multi-touch IP Pin Name iCLK iRSTN iTRIG Direction Input Input Input oREADY Output oREG_X1 Output oREG_Y1 Output MTLC User Manual 18 Description Connect to 50MHz Clock Connect to system reset signal Connect to Interrupt Pin of Touch IC Rising Trigger when following six output data is valid 10-bits X coordinate of first touch point 9-bits Y coordinate of first touch point www.terasic.com May 22, 2014 oREG_X2 Output oREG_Y2 Output oREG_TOUCH_COUNT Output oREG_GESTURE I2C_SCLK Output Output I2C_SDAT Inout 10-bits X coordinate of second touch point 9-bits Y coordinate of second touch point 2-bits touch count. Valid value is 0, 1, or 2. 8-bits gesture ID (See Table 3-7) Connect to I2C Clock Pin of Touch IC Connect to I2C Data Pin of Touch IC The supported gestures and IDs are shown in Table 3-7. Table 3-7 Gestures Gesture One Point Gesture North North-East East South-East South South-West West North-West Rotate Clockwise Rotate Anti-clockwise Click Double Click Two Point Gesture North North-East East South-East South South-West West North-West Click Zoom In Zoom Out ID (hex) 0x10 0x12 0x14 0x16 0x18 0x1A 0x1C 0x1E 0x28 0x29 0x20 0x22 0x30 0x32 0x34 0x36 0x38 0x3A 0x3C 0x3E 0x40 0x48 0x49 Note: The Terasic Multi-Touch IP can also be found under the \IP folder in the system CD as well as the \IP folder in the reference designs. MTLC User Manual 19 www.terasic.com May 22, 2014 Chapter 4 MTLC Demonstrations This chapter gives detailed description of the provided bundles of exclusive demonstrations implemented on the DE2-115 development board with MTLC. These demonstrations are particularly designed (or ported) for MTLC, with the goal of showing the potential capabilities of the kit and showcase the unique benefits of FPGA-based SOPC systems such as reducing BOM costs by integrating powerful graphics and video processing circuits within the FPGA. Please notice that all the demonstrations in this chapter are using the DE2-115 development board with MTLC. For the demonstrations with other FPGA board can be found on MTLC system CD. 4.1 System Requirements To run and recompile the demonstrations, you should:    Install Altera Quartus II 13.1 and NIOS II EDS 13.1 or later edition on the host computer Install the USB-Blaster driver software. You can find instructions in the tutorial “Getting Started with Altera’s DE2-115 Board” (tut_initialDE2-115.pdf) which is available on the DE2-115 system CD Copy the entire \Demonstration\DE2-115 folder from the MTLC system CD to your host computer 4.2 Painter Demonstration This chapter shows how to control LCD and touch controller to establish a paint demo based on SOPC Builder and Altera VIP Suite. The demonstration shows how multi-touch gestures and single-touch coordinates operate. Figure 4-1 shows the hardware system block diagram of this demonstration. For LCD display processing, the reference design is developed based on the Altera Video and Image Processing Suite (VIP). The Frame Reader VIP is used for reading display content from the associated video memory, and VIP Video Out is used to display the display content. The display content is filled by NIOS II processor according to users’ input. For multi-touch processing, a Terasic Memory-Mapped IP is used to retrieve the user input, including multi-touch gesture and single-touch coordinates. Note, the IP is encrypted, so the license should be installed before compiling the Quartus II project. For IP--usage details please refer to the MTLC User Manual 20 www.terasic.com May 22, 2014 section 3.5 Using Terasic Multi-Touch IP in this document. Figure 4-1 Block Diagram of the Painter Demonstration  Demonstration Source Code    Project directory: Painter Bit stream used: Painter.sof Nios II Workspace: Painter \Software  Demonstration Batch File Demo Batch File Folder: Painter \demo_batch The demo batch file includes the following files:    Batch File: test.bat, test_bashrc FPGA Configuration File: Painter.sof Nios II Program: Painter.elf  Demonstration Setup 1. 2. 3. 4. 5.  Make sure Quartus II and Nios II are installed on your PC Power on the DE2-115 board Connect USB-Blaster to the DE2-115 board and install USB-Blaster driver if necessary Execute the demo batch file “test.bat” under the batch file folder, Painter \demo_batch After Nios II program is downloaded and executed successfully, you will see a painter GUI in the LCD. Figure 4-2 shows the GUI of the Painter Demo. The GUI is classified into three areas: Palette, Canvas, and Gesture. Users can select pen color from the color palette and start painting in the Canvas area. If gesture is detected, the associated gesture symbol is shown in the gesture area. To clear canvas content, press the MTLC User Manual 21 www.terasic.com May 22, 2014  “Clear” button. Figure 4-3 shows the photo when users paint in the canvas area. Figure 4-4 shows the phone when counter-clockwise rotation gesture is detected. Figure 4-5 shows the photo when zoom-in gesture is detected. Figure 4-2 GUI of Painter Demo Figure 4-3 Single Touch Painting MTLC User Manual 22 www.terasic.com May 22, 2014 Figure 4-4 Counter-clockwise Rotation Gesture Figure 4-5 Zoom-in Gesture Note: execute the test.bat under Picture_Viewer\demo_batch will automatically download the .sof and .elf file. MTLC User Manual 23 www.terasic.com May 22, 2014 4.3 Picture Viewer This demonstration shows a simple picture viewer implementation using Nios II-based SOPC system. It reads JPEG images stored on the SD card and displays them on the LCD. The Nios II CPU decodes the images and fills the raw result data into frame buffers in SDRAM. The VEEK-MT( DE2-115 + MTLC) will show the image the buffer being displayed points to. When users touch the LCD touch panel, it will proceed to display the next buffered image or last buffered image. Figure 4-6 shows the block diagram of this demonstration. The Nios II CPU here takes a key role in the demonstration. It is responsible of decoding the JPEG images and coordinates the works of all the peripherals. The touch panel handling program uses the timer as a regular interrupter and periodically updates the sampled coordinates. Figure 4-6 Block Diagram of the Picture Viewer Demonstration  Demonstration Source Code    Project directory: Picture_Viewer Bit stream used: Picture_Viewer.sof Nios II Workspace: Picture_Viewer\Software  Demonstration Batch File Demo Batch File Folder: Picture_Viewer\demo_batch The demo batch file includes the following files:    Batch File: Picture_Viewer.bat, Picture_Viewer _bashrc FPGA Configuration File: Picture_Viewer.sof Nios II Program: Picture_Viewer.elf MTLC User Manual 24 www.terasic.com May 22, 2014  Demonstration Setup 1. 2. 3. 4. 5. 6. 7. 8.     Format your SD card into FAT16 format Place the jpg image files to the \jpg subdirectory of the SD card. For best display result, the image should have a resolution of 800x480 or the multiple of that Insert the SD card to the SD card slot on the VEEK-MT Load the bit stream into the FPGA on the VEEK-MT Run the Nios II Software under the workspace Picture_Viewer\Software (Note*) After loading the application you will see a slide show of pictures on the SD card. The next image will be displayed after the delay period. You can control the slide show as follows : Press Forward ( ) to advance, Reverse ( ) to go back to previous image, Play/Stop ( ) to play the slide or stop it. On the top corner you will see the delay-period (seconds). You can increase or decrease the delay period by touching the + ( ) or – ( ) buttons. The max delay is 120 seconds, the min delay is 1 second, and the default delay is 10 seconds. You can hide the control buttons by clicking on the Hide button located at the top left corner of the touch screen. Touch anywhere on the screen to resume and to return to menu. Figure 4-7 Picture Viewer Demonstration Note: execute the Picture_Viewer.bat automatically download the .sof and .elf file. MTLC User Manual 25 under Picture_Viewer\demo_batch will www.terasic.com May 22, 2014 4.4 Video and Image Processing The Video and Image Processing (VIP) Example Design demonstrates dynamic scaling and clipping of a standard definition video stream in either National Television System Committee (NTSC) or Phase Alternation Line (PAL) format and picture-in-picture mixing with a background layer. The video stream is output in high resolution (800×480) LCD touch panel. The example design demonstrates a framework for rapid development of video and image processing systems using the parameterizable MegaCore® functions that are available in the Video and Image Processing Suite. Available functions are listed in Table 4-1. This demonstration needs the Quartus II license file includes the VIP suite feature. Table 4-1 VIP IP Cores Functions IP MegaCore Function Frame Reader Control Synchronizer Switch Color Space Converter Chroma Resampler 2D FIR Filter Alpha Blending Mixer Scaler Deinterlacer Test Pattern Generator Clipper Color Plane Sequencer Frame Buffer 2D Median Filter Gamma Corrector Clocked Video Input/Output Description Reads video from external memory and outputs it as a stream. Synchronizes the changes made to the video stream in real time between two functions. Allows video streams to be switched in real time. Converts image data between a variety of different color spaces such as RGB to YCrCb. Changes the sampling rate of the chroma data for image frames, for example from 4:2:2 to 4:4:4 or 4:2:2 to 4:2:0. Implements a 3 x 3, 5 x 5, or 7 x 7 finite impulse response (FIR) filter on an image data stream to smooth or sharpen images. Mixes and blends multiple image streams—useful for implementing text overlay and picture-in-picture mixing. A sophisticated polyphase scaler that allows custom scaling and real-time updates of both the image sizes and the scaling coefficients. Converts interlaced video formats to progressive video format using a motion adaptive deinterlacing algorithm. Also supports 'bob' and "weave" algorithms Generates a video stream that contains still color bars for use as a test pattern. Provides a way to clip video streams and can be configured at compile time or at run time. Changes how color plane samples are transmitted across the Avalon-ST interface. This function can be used to split and join video streams, giving control over the routing of color plane samples. Buffers video frames into external RAM. This core supports double or triple-buffering with a range of options for frame dropping and repeating. Provides a way to apply 3 x 3, 5 x 5, or 7 x 7 pixel median filters to video images. Allows video streams to be corrected for the physical properties of display devices. These two cores convert the industry-standard clocked video format (BT-656) to Avalon-ST video and vice versa. These functions allow you to fully integrate common video functions with video interfaces, processors, and external memory controllers. The example design uses an Altera Cyclone® IV E EP4CE115F29 featured VEEK-MT ( DE2-115 + MTLC). A video source is input through an analog composite port on VEEK-MT which generates a digital output in ITU BT656 format. A number of common video functions are performed on this input MTLC User Manual 26 www.terasic.com May 22, 2014 stream in the FPGA. These functions include clipping, chroma resampling, motion adaptive deinterlacing, color space conversion, picture-in-picture mixing, and polyphase scaling. The input and output video interfaces on the VEEK-MT are configured and initialized by software running on a Nios® II processor. Nios II software demonstrates how to control the clocked video input, clocked video output, and mixer functions at run-time is also provided. The video system is implemented using the SOPC Builder system level design tool. This abstracted design tool provides an easy path to system integration of the video processing data path with a NTSC or PAL video input, VGA output, Nios II processor for configuration and control. The Video and Image Processing Suite MegaCore functions have common open Avalon-ST data interfaces and Avalon Memory-Mapped (Avalon-MM) control interfaces to facilitate connection of a chain of video functions and video system modeling. In addition, video data is transmitted between the Video and Image Processing Suite functions using the Avalon-ST Video protocol, which facilitates building run-time controllable systems and error recovery. Figure 4-8 shows the Video and Image Processing block diagram. Figure 4-8 VIP Example SOPC Block Diagram (Key Components)  Demonstration Source Code    Project directory: VIP Bit stream used: VIP.sof Nios II Workspace: VIP\Software MTLC User Manual 27 www.terasic.com May 22, 2014  Demonstration Batch File Demo Batch File Folder: VIP\demo_batch The demo batch file includes the following files:    Batch File: VIP.bat, VIP_bashrc FPGA Configuration File: VIP.sof Nios II Program: VIP.elf  Demonstration Setup      Connect a DVD player’s composite video output (yellow plug) to the Video-IN RCA jack (J12) of the VEEK-MT. The DVD player has to be configured to provide NTSC output or PAL output Connect the VGA output of the VEEK-MT to a VGA monitor (both LCD and CRT type of monitors should work) Load the bit stream into FPGA (note*) Run the Nios II IDE and choose VIP\Software as the workspace. Click on the Run button (note *) Press the screen of the VEEK-MT and drag the video frame box will result in scaling the playing window to any size, as shown in Figure 4-9 Note: (1).Executing VIP\demo_batch\ VIP.bat will download .sof and .elf files. (2).You may need additional Altera VIP suite Megacore license features to recompile the project. Figure 4-10 illustrates the setup for this demonstration. MTLC User Manual 28 www.terasic.com May 22, 2014 Figure 4-9 VIP Demonstration Figure 4-10 Setup for the VIP Demonstration 4.5 Camera Application This demonstration shows a digital camera reference design using the 5 megapixel CMOS sensor and 7-inch LCD modules on the VEEK-MT (MTLC+DE2-115). The CMOS sensor module sends the raw image data to FPGA on the DE2-115 board, the FPGA on the board handles image processing part and converts the data to RGB format to display on the LCD module. The I2C Sensor Configuration module is used to configure the CMOS sensor module. Figure 4-11 shows the block diagram of the demonstration. As soon as the configuration code is downloaded into the FPGA, the I2C Sensor Configuration block will initial the CMOS sensor via I2C interface. The CMOS sensor is configured as follow: MTLC User Manual 29 www.terasic.com May 22, 2014      Row and Column Size: 800 * 480 Exposure time: Adjustable Pix clock: MCLK*2 = 25*2 = 50MHz Readout modes: Binning Mirror mode: Line mirrored According to the settings, we can calculate the CMOS sensor output frame rate is about 44.4 fps. After the configuration, The CMOS sensor starts to capture and output image data streams, the CMOS sensor Capture block extracts the valid pix data streams based on the synchronous signals from the CMOS sensor. The data streams are generated in Bayer Color Pattern format. So it’s then converted to RGB data streams by the RAW2RGB block. After that, the Multi-Port SDRAM Controller acquires and writes the RGB data streams to the SDRAM which performs as a frame buffer. The Multi-Port SDRAM Controller has two write ports and read ports also with 16-bit data width each. The writing clock is the same as CMOS sensor pix clock, and the reading clock is provided by the LCD Controller, which is 33MHz. Finally, the LCD controller fetches the RGB data from the buffer and displays it on the LCD panel continuously. Because the resolution and timing of the LCD is compatible with WVGA@800*480, the LCD controller generates the same timing and the frame rate can achieve about 25 fps. For the objective of a better visual effect, the CMOS sensor is configured to enable the left right mirror mode. User could disable this functionality by modifying the related register value being written to CMOS controller chip. Figure 4-11 Block Diagram of the Digital Camera Design  Demonstration Source Code   Project directory: Camera Bit stream used: Camera.sof MTLC User Manual 30 www.terasic.com May 22, 2014  Demonstration Batch File Demo Batch File Folder: Camera\demo_batch The demo batch file includes the following files:   Batch File: test.bat FPGA Configuration File: Camera.sof  Demonstration Setup      Load the bit stream into FPGA by executing the batch file ‘test.bat’ under Camera\demo_batch\ folder The system enters the FREE RUN mode automatically. Press KEY[0] on the DE2-115 board to reset the circuit Press KEY[2] to take a shot of the photo; you can press KEY[3] again to switch back to FREE RUN mode and you should be able to see whatever the camera captures on the LCD display User can use the SW[0] and KEY[1] to set the exposure time for brightness adjustment of the image captured. When SW[0] is set to Off, the brightness of image will be increased as KEY[1] is pressed longer. If SW[0] is set to On, the brightness of image will be decreased as KEY[1] is pressed shorter User can use SW[17] to mirror image of the line. However, remember to press KEY[0] after toggle SW[17] Note: execute the test.bat under Camera\demo_batch will automatically download the .sof file. Table 4-2 summarizes the functional keys of the digital camera. Figure 4-12 gives a run-time photograph of the demonstration. Table 4-2 The functional keys of the digital camera demonstration Component Function Description KEY[0] Reset circuit KEY[1] Set the new exposure time (use with SW[0] ) KEY[2] Trigger the Image Capture (take a shot) KEY[3] Switch to Free Run mode Off: Extend the exposure time SW[0] On: Shorten the exposure time SW[17] Mirror mode HEX[7:0] Frame counter (Display ONLY) MTLC User Manual 31 www.terasic.com May 22, 2014 Figure 4-12 Screen Shot of the Camera Demonstration 4.6 Video and Image Processing for Camera The Video and Image Processing (VIP) for Camera Example Design demonstrates dynamic scaling and clipping of a standard definition video stream in RGB format and picture-in-picture mixing with a background layer. The video stream is output in high resolution (800×480) on LCD touch panel. The example design demonstrates a framework for rapid development of video and image processing systems using the parameterizable MegaCore® functions that are available in the Video and Image Processing Suite. Available functions are listed in Table 4-2. This demonstration needs the Quartus II license file includes the VIP suite feature. These functions allow you to fully integrate common video functions with video interfaces, processors, and external memory controllers. The example design uses an Altera Cyclone® IV E EP4CE115F29 featured on the VEEK-MT (MTLC+DE2-115). A video source is input through the CMOS sensor on VEEK-MT which generates a digital output in RGB format. A number of common video functions are performed on this input stream in the FPGA. These functions include clipping, chroma resampling, motion adaptive deinterlacing, color space conversion, picture-in-picture mixing, and polyphase scaling. The input and output video interfaces on the VEEK-MT are configured and initialized by software running on a Nios® II processor. Nios II software demonstrates how to control the clocked video input, clocked video output, and mixer functions at run-time is also provided. The video system is implemented using the SOPC Builder system level design tool. This abstracted design tool provides an easy path to system integration of the video processing data path with a NTSC or PAL video input, VGA output, Nios II processor for configuration and control. The Video and Image Processing Suite MegaCore functions have common open Avalon-ST data interfaces and Avalon Memory-Mapped (Avalon-MM) control interfaces to facilitate connection of a chain of video functions and video system modeling. In addition, video data is transmitted between the Video and Image Processing Suite functions using the Avalon-ST Video protocol, which facilitates building MTLC User Manual 32 www.terasic.com May 22, 2014 run-time controllable systems and error recovery. For the objective of a better visual effect, the CMOS sensor is configured to enable the left right mirror mode. User could disable this functionality by modifying the related register value being written to CMOS controller chip. Figure 4-13 shows the Video and Image Processing block diagram. Figure 4-13 VIP Camera Example SOPC Block Diagram (Key Components)  Demonstration Source Code    Project directory: VIP_Camera Bit stream used: VIP_Camera.sof Nios II Workspace: VIP_Camera \Software  Demonstration Batch File Demo Batch File Folder: VIP_Camera\demo_batch The demo batch file includes the following files: MTLC User Manual 33 www.terasic.com May 22, 2014    Batch File: VIP_Camera.bat, VIP_Camera _bashrc FPGA Configuration File: VIP_Camera.sof Nios II Program: VIP_Camera.elf  Demonstration Setup        Connect the VGA output of the VEEK-MT to a VGA monitor (both LCD and CRT type of monitors should work) Load the bit stream into FPGA (note*) Run the Nios II and choose VIP_Camera\Software as the workspace. Click on the Run button (note *) The system enters the FREE RUN mode automatically. Press KEY[0] on the DE2-115 board to reset the circuit Press KEY[2] to stop run; you can press KEY[3] again to switch back to FREE RUN mode and you should be able to see whatever the camera captures on the VGA display User can use SW[17] to mirror image of the line. However, remember to press KEY[0] after toggle SW[17] Press and drag the video frame box will result in scaling the playing window to any size, as shown in Figure 4-14 Note: (1).Execute VIP_Camera\demo_batch\VIP_CameraA.bat will download .sof and .elf files. (2).You may need additional Altera VIP suite Megacore license features to recompile the project. Figure 4-14 illustrates the setup for this demonstration. Figure 4-14 Setup for the VIP_Camera demonstration MTLC User Manual 34 www.terasic.com May 22, 2014 4.7 Digital Accelerometer Demonstration This demonstration shows a bubble level implementation based on a digital accelerometer. We use I2C protocol to control the ADXL345 digital accelerometer, and the APDS-9300 Miniature Ambient Light Photo Sensor. The LCD displays the interface. When tilting the VEEK-MT (MTLC+DE2-115), the ADXL345 measures the static acceleration of gravity. In the Nios II software, the change of angle in the x-axis and y-axis is computed, and shown as angle data in the LCD display. The value of light sensor will change as the brightness changes around the light-sensor. Figure 4-15 shows the hardware system block diagram of this demonstration. The system is clocked by an external 50MHz oscillator. Through the internal PLL module, the generated 150MHz clock is used for Nios II processor and other components, and there is also 10MHz for low-speed peripherals. Figure 4-15 Block Diagram of the Digital Accelerometer Demonstration  Demonstration Source Code    Project directory: G_sensor Bit stream used: G_sensor.sof Nios II Workspace: G_sensor\Software  Demonstration Batch File Demo Batch File Folder: G_sensor\demo_batch MTLC User Manual 35 www.terasic.com May 22, 2014 The demo batch file includes the following files:    Batch File: G_sensor.bat, test_bashrc FPGA Configuration File: G_sensor.sof Nios II Program: G_sensor.elf  Demonstration Setup     Load the bit stream into the FPGA on the VEEK-MT. Run the Nios II software under the workspace G_sensor\Software (Note*). After the Nios II program is downloaded and executed successfully, a prompt message will be displayed in nios2-terminal: “its ADXL345’s ID = e5”. Tilt the VEEK-MT to all directions, and you will find that the angle of the accelerometer and value of light sensor will change. When turning the board from -80º to -10º and from 10º to 80º in Y-axis, or from 10ºto 80º and from -80º to -10º in Y-axis, the image will invert Figure 4-16 shows the demonstration in action. Figure 4-16 Digital Accelerometer Demonstration Note: Execute G_sensor \demo_batch\test.bat to download .sof and .elf files. MTLC User Manual 36 www.terasic.com May 22, 2014 Chapter 5 Appendix 5.1 Revision Histor y Version V1.0 Change Log Initial Version (Preliminary) 5.2 Copyright Statement Copyright © 2014 Terasic Technologies. All rights reserved. We will continue to provide interesting examples and labs on our MTLC webpage. Please visit mtlc.terasic.com for more information. MTLC User Manual 37 www.terasic.com May 22, 2014
P0158 价格&库存
很抱歉,暂时无法提供与“P0158”相匹配的价格&库存,您可以联系我们找货
