TC0700PIBW6UR1GBNI4GWT 数据手册
TechNexion - Toucan
Page 1 of 3
Toucan-0700
Key Features
Based around Freescale i.MX6 ARM Cortex-A9 multicore technology.
Projective Multi-touch bright (500 nits) high resolution (1024*600) 7 inch panel.
Galvanic isolated CAN Bus and serial ports (RS-232/422/485).
USB host, USB OTG, Micro-SD cardslot, 4 GPIO's and HDMI for secondary display.
Gigabit POE function or 10~36VDC power input.
Available with colorful bezels.
Specifications
Processor
Memory
Storage
Operation System
Freescale i.MX6 Solo/Duallite (i.MX6 Dual/Quad on project base)
512MB (Solo), 1GB (Duallite)
eMMC 4GB
Linux 3.x, Yocto, Ubuntu
Android 4.3 (jellybean), Android 4.4 (Kitkat)
Connectors
Network LAN
External Display
USB
SD cardslot
Serial
CAN Bus
GPIO
Buttons
Power
RJ-45 Gigabit Ethernet with POE function 802.3at
HDMI 1.4
1x USB Host 2.0 Connector
1x USB OTG 3.0 Connector
micro SD cardslot
1x RS-232 (galvanic isolated)
1x RS-232/422/485 (galvanic isolated)
2x Flex CAN version 2.0B Compliant (galvanic isolated)
4x GPIO
1x Reset button
1x Boot select button (force SD card boot)
2 pin DC power terminal block (10~30VDC)
Internal Expansion Interfaces
USB
Audio
Display and Touch
2x Internal pinheader
1x pinheader (if touchpanel is not used)
Audio speaker connectors (Left / Right) (2 Watt pre-amplified)
Page 2 of 3
Internal Screen
Resolution
Maximum Colors
Luminance
Touchscreen
External Display
7 inch widescreen LCD display with LED backlight
1024 x 600 pixels
16.7 million
500 cd/m²
Projective Capacitive multitouch (4 points)
HDMI 1.4 Connector
Graphic Capabilities
GPU 3D
GPU 2D
(Vector Graphics)
GPU 2D
(Composition)
Video Decode
Video Encode
Vivante GC880
35Mtri/s 266Mpxl/s
Open GL ES 2.0
emulated on GPU 3D
Vivante GC320
600Mpxl/s, BLIT
1080p30 + D1
1080p30 H.264
BP / Dual 720p
Network
Network
WiFi
Bluetooth
10/100/1000 Mbps with POE function 802.3at
Broadcom BCM4330 802.11bgn
Broadcom BCM4330 BT 4.0
Power
Input Power Requirements
Power over Ethernet (POE)
Power Consumption
10~30V DC +/- 5%
802.3at POE implementation (36~57VDC)
7 Watt
Environmental and Mechanical
Operation Temperature
Storage Temperature
Humidity
Dimensions
MTBF
Weight
Shock
Vibration
Certification
0° to 60° C
-20° to 70° C
10 - 90%
184 (W) x 122 (H) x 30 (D) mm
50,000 hours
595 grams
50G / 25 ms
20G / 0-600 Hz
Compliant with CE, FCC, RoHS, REACh directives
Mounting Options
Rear Mounting
VESA Mounting
4 mounting clips required (included)
35*75 VESA MIS C. Standard (seperate purchase)
Page 3 of 3
Dimensional Drawing
all sizes in mm
Copyright © 1999 - 2015. All Rights Reserved.
http://www.technexion.com/products/panel-pc/toucan
1/26/2015
TC0700PIBW6UR1GBNI4GWT 价格&库存
很抱歉,暂时无法提供与“TC0700PIBW6UR1GBNI4GWT”相匹配的价格&库存,您可以联系我们找货
