Voltage Powered LCD Digital Panel Meters
Adjustable Voltage 4½ Digit
EPIC SERIES
DK790V Series
Features:
◊ Low-cost, high-performance replacement for many OEM DPMs
◊ 4½ digits with high-contrast LCD
◊ Optional RED, GREEN or AMBER backlighting
◊ 12V or 24V DC Voltage powered
◊ Snap-in bezel mount eliminates mounting hardware
◊ User selectable, displayed engineering units
◊ Resistant to RF and EMI
Ordering Information:
Specifications:
Display:
Digits:
Type:
Backlighting:
Polarity:
Annuciators:
Decimal Points:
Overrange:
Inputs:
Ranges:
Configuration:
Impedance:
Performance: Accuracy:
Conversion Rate:
Normal Mode Rejection:
Adjustments:
Warmup:
Temperature Coefficient:
Offset Range:
Gain Range:
Environment: Operating Range:
Storage Range:
Power Supply:
Optional Backlight:
Mounting:
Connection:
4 ½ digits (±19999 counts)
0.45" (11.4 mm) 7 segment LCD
Optional Red Negative (red numbers/black background)
Optional Green Negative (green numbers/black background)
Optional Amber Negative (amber numbers/black background)
Optional Green Postive (black numbers/green background)
automatic, “-” displayed
°F, °C, PSI, %, user selectable, V, A KW, PF
4 position, user selectable
four lower order digits blank for inputs >19999 & 30 dB @ 60 Hz
span (gain) (2) (10V and 5V) and zero (offset)
10 minutes typical
±100 ppm per °C typical
-19999 to +19999
1-20000 counts above adjusted zero
0 to 50 °C
-10 to 60 °C
12 VDC or 24 VDC regulated (selectable)
24 VDC at 35 mA typical
snap-in bezel mount
4 screw terminal (6 with backlight)
PART NUMBER
BACKLIGHT COLOR
BACKLIGHT POWER
DK796*......................................... NEG AMBER.................................................24 VDC
DK797*......................................... NEG GREEN.................................................24 VDC
DK798*......................................... NEG RED......................................................24 VDC
DK799*......................................... NO BACKLIGHT.............................................. NONE
DK800*......................................... POS GREEN.................................................. 24VDC
*Add (P) for Power Engineering Units V, A, KW, PF
PW2-12.................................................... Regulated 120V AC to 12V DC Power Supply
PW2-24.................................................... Regulated 120V AC to 24V DC Power Supply
PW1.0............................................................................24V AC to adjustable DC output
CPW1.5.........................................................................24V AC to adjustable DC output
CVC...................................................................................................................Calibrator
C-TON Industries • PO Box 172 • Sunapee, NH, 03782 • USA • Phone (603)456-2655 •
email: info@ctonindustries.com
DK790V Series
EPIC SERIES
Dimensions
Wiring
Decimal Point Selection
1. Locate jumpers J4 through J6 in the middle of the
circuit board unit.
2. Jumper the appropriate decimal location as follows:
J4 - 000.0
J5 - 00.00
J6 - 0.000
None - 0000
很抱歉,暂时无法提供与“DK800P”相匹配的价格&库存,您可以联系我们找货
