MPAX PERSONALITY MODULE SELECTOR GUIDE FOR LPAX
Our la rge displays have various input options, determined by the installation of a MPAX personality module. These MPAX
modules are based on standard PAX panel meters, and use the same data sheet as the PAX meter for specifications and wiring.
About the MPAX Input Modules
The MPAX Module serves as the input to the LPAX Display. There are several different modules to cover a variety of inputs. The
MPAX module provides input scaling which allows the LPAX to display most any engineering unit. Once the MPAX is inserted into
the LPAX, the unit has the same functions and capabilities of our PAX Series Intelligent Panel Meters. A full set of PAX
programming instructions will be included with the MPAX Module.
Note: The MPAX provides the operating power for the LPAX, therefore you must select either the AC or DC MPAX corre sponding
with your application and available power.
Selecting Your Display Components
To build a complete display unit, you will need an LPAX and an MPAX Input Module. The LPAX is only a display and will not
operate without an MPAX Module. Please use the following chart to identify the appropriate MPAX Module (including supply
power) and LPAX Display that will satisfy your application.
MPAX Modules for LPAX5 (Analog units)
MPAX MODULES
SIGNAL TYPE
INPUT RANGES
LPAX DISPLAYS
85-250 VAC
11 to 36 VDC/ 24 VAC
Universal DC Inpu ts
DC Voltage 200 m V, 2 V, 20 V, 300 V
DC Current 200 µA, 2 mA, 20 mA, 200 mA, 2 Amp
Resi stance 100 ohm, 1000 ohm, 10 K ohm
MPAXD000
MPAXD010
LPAX0500
Process Inputs
0-20 mA or 0-10 V DC
MPAXP000
MPAXP010
LPAX0500
Temperature Inputs
Thermocouples -T, E, J, K, R, S, B, N, C,
or Custom Scaling RTDs - 100 ohm Pt (platinum) 385/392,
120 ohm Nickel 672, or 10 ohm Copper 427
MPAXT000
MPAXT010
LPAX0500
Strain Gage/Load Cell
24 mV or 240 mV
MPAXS000
MPAXS010
LPAX0500
True RMS AC
Voltage/Current
AC Voltage 200 m V, 2 V, 20 V, 300 V
AC Current 200 uA, 2 mA, 20 mA, 200 mA, 5 Amp
MPAXH000
N/A
LPAX0500
*For detailed Module specifications, see corresponding PAX literature.
(i.e. For MPAXD specifications, see the PAXD literature)
MPAX modules for LPAX5 units work with Crimson.
Clicking on any blue text in the above table will download the appropriate PAX panel meter data sheet for that MPAX module.
MPAX Modules for LPAX6 (Digital units)
MPAX MODULES*
SIGNAL TYPE
85-250 VAC
11 to 36 VDC / 24 VAC
OPTIONAL PLUG-IN CARD COMPATIBILITY
LPAX
DISPLAYS
SETPOINT
COMMS
ANALOG
REAL-TIME
CLOCK
Count/Rate/Serial Slave
MPAXI02
MPAXI03LPAX0600
YES
YES
YES
Count
MPAXC020
MPAXC03LPAX0600
YES
Rate
MPAXR020
MPAXR0
LPAX0600
YES
Clock/Timer
MPAXCK0 0††
MPAXCK1 0††
LPAXCK0 0**
YES
YES
YES
Timer
MPAXTM00††
MPAXTM10††
LPAXCK0 0**
YES
YES
*For detailed module and plug-in card specifications, see corresponding PAX literature.
(i.e. For MPAXI specifications, see the PAXI literature)
**The LPAXCK will only operate with the Clock/ Timer MPAX input module.
† MPAXI works with Crimson.
†† MPAXCK00, MPAXCK10, MPAXTM00 and MPAXTM10 work with RLCPro.
MPAX Modules for LPAXDA (Dual Analog Unit)
MPAX MODULES
SIGNAL TYPE
Dual Process Inputs
INPUT RANGES
0-20 mA or 0-10 VDC
85-250 VAC
MPAXDP00
MPAXDP10
LPAX DISPLAY
LPAXDA00
(i.e. For MPAXDP specifications, see the PAXDP literature)
MPAX modules for LPAXDA units work with Crimson.
很抱歉,暂时无法提供与“MPAXDP10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4893.780571+607.11406
