0251-06M
0251-06M
    GREENLEECOMMUNICATIONS(格林利)
    PLIERS DIAGONAL 6" MOLDED
0251-06M 数据手册
PLIERS,DIAGONAL 6" MOLDED Diagonal Cutting Pliers 6 molded grip Cat No: 0251-06M UPC No: 783310547372 Description • • • • • • • • • • • • Forged from chrome vanadium steel for greater durability and strength Precision-machined and laser-hardened blades strengthen cutters and provide consistent performance Effectively cuts most hardened wire, ACSR, bolts, screwsand nails Through-hardened steel for longer life Dual cutting edges for optimum cutting performance Exceeds ASME/ANSI specifications Rugged riveted construction for smooth precise action Lifetime limited warranty Note: This is not an insulated tool Molded Grip Only: Custom grip allows area for user identification Flared handles for added comfort and leverage Wider grip design provides larger load bearing area foruser comfort Specifications • • • • • • • • Application : For Cutting Most Hardened Wire, ACSR, Bolts, Screws And Nails Handle Type : Flared, Molded Grip Material : Chrome Vanadium Steel Overall Length : 6-1/8 IN (15.500 CM) Size : 6.000 IN Standard : ASME/ANSI Type : Diagonal Weight : 0.350 LB (0.160 KG)
0251-06M 价格&库存
很抱歉,暂时无法提供与“0251-06M”相匹配的价格&库存,您可以联系我们找货
