www.wihatools.com
13
Bent Long Nose Pliers With Cutters
Long Nose Pliers With Return Spring
Angled 40
O
326 Bent Long Nose Pliers With Cutters DIN ISO 5745
Long nose pliers angled 40O. Extra long cutters for flat and round wire.
Partially Serrated Jaws. Cutting edges additionally induction hardened
to approx. 64HRC. Special C70 tool steel forgings. Soft vinyl grips are
oil & solvent resistant.
Item
No.
32623
32625
Cutting Capacity
Copper AWG
mm Inch
160 6.3 #10
200 8.0 #8
Pkg. lbs.
1 .28
1 .96
32617 Long Nose Pliers With Cutters DIN ISO 5745
Long nose pliers. Extra long cutters for flat and round cables. Serrated
Jaws. Cutting edges additionally induction hardened to approx. 64HRC.
Special C70 tool steel forgings. Soft vinyl grips are oil & solvent resistant.
Item
No.
32617
Item
No.
32630
mm
160
Inch Pkg. lbs.
6.3 1 .26
32645 Stripping Pliers DIN ISO 5744
Heavy duty forged with induction hardened cutting edges for even
stripping of insulation. Easy to use adjusting screw allows the stripping
diameter to be set. Opening spring for effortless and sensitive handling
of pliers. C70 special tool steel. 64HRC cutting edges. For Stripping up
to Ø 5mm/#4 AWG conductor cross-section. Soft vinyl grips.
Item
No.
32645
Long Round Nose Pliers
32633 Long Round Nose Pliers DIN ISO 5745
Extra long head. Serrated Jaws are induction hardened. Special C70
tool steel forgings. Use for gripping and uniform round bending of wires
and sheet metal parts. Soft vinyl grips are oil & solvent resistant.
Item
No.
32633
mm
160
Inch
6.3
Pkg.
1
lbs.
.25
Pkg. lbs.
1 .22
Stripping Pliers
Long Flat Nose Pliers
32630 Long Flat Nose Pliers DIN ISO 5745
tool steel forgings. Use for gripping and right-angled bending of wires
Cutting Capacity
Copper AWG
mm Inch
160 6.3
#12
Stripping Capacity
Copper Awg#
mm Inch
160 6.3
#8 - #28
Pkg. lbs.
1
.31
Proturn Stripping Pliers
57872 Proturn Stripping Pliers
Wide long head with ridged gripping surface, shears blade and firm wire
stripping stations. With opening spring and locking mechanism.
Wire stripping stations 0.81 / 1.0 / 1.3 / 1.6 / 2.0 / 2.59mm,
AWG 20 / 18 / 16 / 14 / 12 / 10.
#57872
mm Inch Ø
AWG Pkg. lbs.
180 7.0 0.81-2.59 20-10 1 .124
www.wihatools.com
Diagonal Cutters
15
Flush Cutting Diagonal Cutters
• Flush cutting,
with return spring
Diagonal Cutters DIN ISO 5749
326
Low wear lap joint, riveted and able to withstand high levels of load. Low
force cutting action, clean cutting. Long life edge is achieved through
additional induction hardening to approx. 64HRC. Special C70 tool steel
hardened and tempered. For soft & medium hard wire. Soft vinyl grips.
Item
No.
32638
32642
32639
Cutting Capacity
mm
140
160
180
Inch
Copper AWG
5.5
#6
6.3
#6
7.0
#6
Pkg. lbs.
1
.33
1
.49
1
.54
High Leverage Cutters
High Leverage Cutters DIN ISO 5749
326
Semi-circular. Low wear lap joint, riveted and able to withstand high
levels of load. Low force action, clean cutting. Long life is achieved
through additional induction hardening of cutting edge to 64HRC.
C70 special tool steel hardened and tempered. Soft vinyl grips.
Item
No.
32646
32649
32652
Cutting Capacity
mm
160
180
200
Copper AWG
Inch
6.3
#6
7.0
#5
8.0
#4
Pkg. lbs.
1
.42
1
.50
1
.63
Cable Cutters
326 Flush Cutting Diagonal Cutters With Return Spring For
Cutting Plastic DIN ISO 5749 Low wear lap joint, riveted and able
to withstand high levels of load. Lightweight action, clean cutting. Long
life edge is achieved through additional induction hardening to approx.
64HRC. Special C70 tool steel hardened and tempered. For cutting
plastic tie wraps & injection mold components. Soft vinyl grips.
Item
No.
32607
32614
mm Inch Pkg. lbs.
127 5.0 1
.14
160 6.3 1
.36
Flush Cutting Mechanic’s Diagonal Cutters
• Flush cutting,
with return spring
326 Flush Cutting Mechanic’s Diagonal Cutters With Return
Spring For Cutting Plastic DIN ISO 5749 Low wear lap joint, riveted
and able to withstand high levels of load. Lightweight action, clean
cutting. Long life edge is achieved through additional induction hardening
to approx. 64HRC. Special C70 tool steel hardened and tempered. For
flush cutting soft and semi-hard wires. Soft vinyl grips.
Item
No.
32613
Cutting Capacity
mm
127
Copper AWG
Inch
5.0 #12
Pkg. lbs.
1 .16
Soft Grip BiCut SuperCut
Cutting capacity up to
2mm (.080”) Spring Wire
64HRC
cutting edges
Cable Cutters Light, energy-saving & clean cutting with
326
specially ground precision cutting edges. Long life is achieved through
additional induction hardening of cutting edge to 64HRC. C70 special
tool steel hardened and tempered. Soft vinyl grips. For cutting of copper
& aluminum cables without crushing, also suitable for stripping. Not for
steel cable, wires and copper conductors with hard coatings.
Item
Cutting Capacity
Copper/Aluminum
No.
mm
Inch Pkg.
lbs.
32600 160
6.3 16mm 1 .34
32602 200
7.9 20mm 1 .62
· Double the power at the press of a button
· BiCut does the job of two pairs of pliers
· Up to 50% less hand strength required for cutting
· Cutting force doubled for extremely hard materials
· Easily switch between two strengths in one-handed operation
32636 Soft Grip BiCut SuperCut
For cutting various materials from soft to extremely hard, such as nails,
screws, bolts, wire cables, spring wires, chains, etc.
Item
No.
mm Inch
32636
200 8.0
Pkg. lbs.
1
.72
很抱歉,暂时无法提供与“32613”相匹配的价格&库存,您可以联系我们找货
