PA1559
PA1559
    GREENLEECOMMUNICATIONS(格林利)
    TOOL HAND CRIMPER COAX SIDE
PA1559 数据手册
CRIMPER MINI COAX PRO UNIVERSAL SealTite® ProM Coax Crimper Cat No: PA1559 UPC No: 769328121933 Description • • • • • • • "Crimps weatherproof linearCATV ?F"", BNC, RCA & right- angle compression-type connectors from all manufacturers Works with RG6, RG6 Quad, RG59 & RG62AU coax cables Versatile tool - accommodates multiple connectors The only tool with a single, reversible head eliminatingneed for adapters No additional parts, attachments or other tools requiredto change from one crimp style to another Quickly & easily adjust crimp height Once properly set, lock with adjustment lock " Specifications • • • • • • • Application : For Use With RG6, RG6 Quad, RG59 And RG62AU Coaxial Cables Cable Type : RG6, RG6 Quad, RG59 And RG62AU Coaxial Dimensions : 3.260 IN (82.800 MM) Length X7.760 IN (187.000 MM) Width X30.500 IN (774.700 MM) Depth Rated Life Cycle : 30000 (Unloaded) Sub Brand : SealTite Type : ProM Coaxial Weight : 17.000 OZ (485.000 GM)
PA1559 价格&库存
很抱歉,暂时无法提供与“PA1559”相匹配的价格&库存,您可以联系我们找货
