125A High-Current Waterproof Connectors
EV Series
Current [A]
Fig.1
■Features
[Temperature Rise Curve]
1. Screw Cramp
Reliable lock by screw and nut. Superior antivibration performance by mounting to chassis.
2. Waterproof Structure
The EV series is IP67 water resistant in unmated
state (when EV1-62RA-3SB, EV1-62RA-2SB is
used). It is IP68/X9K water resistant in mated.
The use of special rubber component for the
internal seals enhance oil and water resistance.
3. Standard Tool for Contact Assembly
Temperature Rise[ç]
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Ambient Temperature[ç]
[Derating Curve]
Contacts can be crimped using readily available
JIS standard tools (JIS C 9711).
4. Downsizing
Current [A]
Staggered panel flange design saves space.
Fig.2
5. Lightweight
The shell is constructed of an aluminum alloy
material enabling it to be lightweight.
6. Multi-Point Contact Spring
Highly reliable contact structure allows for a high
current capability, guards against vibration to the
contact and decreases contact resistance.
7. Shielded Design
Measurement Condition
The plug has three contacts where 20 mm2 electric wires
are connected and then covered with a corrugated
housing. Measurement was taken by connecting copper
bus bars of 3 mm x 12 mm to the three contacts of the
receptacle and wiring in series.
The metal shell enhances EMI shielding.
8. Finger Protection
Contact and connector design protects against
accidental electrical shock using IEC 60601 test
procedure.
Remarks
Derating curve and temperature rise curve changes
slightly by a given cable that is being used and slight
variations occur under the same conditions. Therefore,
the values indicated above are reference values and not
guaranteed values.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2019.3④
1
EV Series●125A High-Current Waterproof Connectors
■Product Specifications
Current rating
125A (180A max. *1)
(Per cable specification and derating curve)
Operating
Temperature
-40 to +150ç
(Including temperature rise by current flow)
Voltage rating
AC 460V, DC 650V
Storage
Temperature Range
-10 to +60ç
Ratings
Note1 : Under the assumption that it is used at normal temperature (20ç±15ç).
Items
Specifications
Conditions
1. Contact resistance
0.5mø or less
Measured at DC 1A
2. Insulation resistance
1000Mø or greater
Measured at DC 500V
3. Withstanding voltage
No flashover or breakdown
AC 2000V for 1 min.
4. Vibration resistance
No electric outage of 10µs or greater
JIS D 1601, Type 3D -Grade 110
5. Shock
Acceleration 490 m/s2, sustained period 11 ms,
Sine wave tests were conducted a total of 18 times,
three times each in 6 directions.
6. Temperature cycle
1mø or less
Insulation resistance: 100Mø or greater
Left for a total of 5 cycles of the following:
-40ç: 30 mins. ➝ Normal temperature: 2-3 min. ➝
150ç: 30 mins. ➝ Normal temperature: 2-3 mins.
7. Humidity resistance
10Mø or greater (when highly humid)
100Mø or greater (when dry)
Left for 96 hours at temperature 40ç and humidity
95%.
8. Water proof
IP68
IPX9K
___
■Materials / Finish
Part
Plug
Materials
Finish
Remarks
Outer shell
Aluminum alloy
Nickel plated
_
Insulator
Rubber sealant
Gasket
Hexagonal bolt
Hexagonal bolt w/ hole
Insulator
Polyamide(black)
Hydrogenated nitrile rubber
Fluorosilicone rubber
_
UL94V-0
_
_
Copper
Tervalent chromate filming
_
Polyamide (black)
_
UL94V-0
Copper Alloy
Silver plated *2
Female contact
Receptacle
Male Contact
Contact spring
Rubber ring
(O ring)
Hexagonal bolt
Hexagonal nut
(Fluorosilicone rubber)
Copper/Brass
Brass
Contact
Copper alloy
Tervalent chromate filming / Nickel plated
Nickel plated
Silver plated *2
Cap
Polyamide (black)
_
_
_
_
_
_
_
UL94V-0
Note2 : Silver-plated contacts can discolor by reacting to sulfur in the air (formation of silver sulfide coat), however, they
can be used without any problem. Contact resistance may increase in an extremely rare case. If it has increased
significantly, please check contact resistance before use.
2
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Plug
EV 1 − 62 P * − 3 P C (**)
q
w
e
r
t
y
u
i
o
●Receptacle
EV 1 − 62 R * − 3 S B (**)
q
w
e
r
t
y
u
i
o
●Male Contact
EV 1 − P
q
w
C * − 1 1
2 (**)
i
!2
u
t
!0
!1
o
q Model Name : EV Series
w Series Number : 1
e Shell Size : The shell size shows the case width of the plug’s mating area or outer
diameter.
r Type of Shell :
P : Straight plug
R : Straight receptacle
t Symbol for Body Form Type and Applicable Cable Range Type :
A : Single unit waterproof receptacle
1 : Notched
y Number of Contacts : Number of contacts is indicated.
u Contact Polarity :
P : Male Contact
S : Female Contact
i Cable Termination Method :
None : Solder termination
B : Termination by screw tightening
C : Crimp termination
o Other Specifications : Two-digit figures will be added if changes other than the
above are made in the specifications.
!0 Contact Type : 1 : Loose piece contacts
!1 Contact Form, Size : Serial numbers (1,2,3, ・
・) will be changed.
!2 Plating Specification : 2 : Silver plated
3
68
62
92
■Plug
85.1
104.1
40
(Representative example.)
Part No.
No. of contacts
139-0001-0
3
EV1-62P-2PC
139-0007-7
2
Packaging
1
66.5
■Receptacle
92
50.7
40
69
Part No.
HRS No.
EV1-62R-3SB
139-0002-3
EV1-62RA-3SB
139-0003-6
EV1-62RA-2SB
139-0008-0
No. of contacts
3
2
Waterproofing
Packaging
Waterproof in mated state
1
Waterproof as single unit
Ø14.2
BMale Contacts
50
Part No.
HRS No.
Packaging
EV1-PC-112 *3
139-0004-9
3 pcs/pack
EV1-PC-112 (01)*3
139-0004-9 01
2 pcs/pack
Note3 : EV1-PC-112, EV1-PC-112(01) is the recommended contact
when using the electric oil pressure crimping tool.
Ø14.2
HRS No.
EV1-62P-3PC
50
Part No.
HRS No.
Packaging
EV1-PC1-112 4
139-0005-1
3 pcs/pack
EV1-PC1-112(01) *4
139-0005-1 01
2 pcs/pack
Note4 : EV1-PC1-112, EV1-PC1-112(01) is the recommended contact
when using the manual oil pressure crimping tool.
4
BPlug : Recommended Cable Specifications and Manufacturer
Recommended Electric Cable Manufacturer
Product Name (Part No.)
Shielded Cable for Electrical Vehicle
100℃ heat resistance : A-LFF-SB
200℃ heat resistance : A-LFF-F-SB
Hitachi Cable, Ltd.
Items
Unit
Number of wires
1
Nominal cross-section area
mm2
Composition
# of wires/mm
19/13/0.32TA (*5)
Outer diameter
mm
6.5
mm
0.05
Conductor
Separator thickness
Standard thickness
Insulator
Specifications
Outer diameter
Braided shield (*6)
Sheath
1.1
mm
8.55-9.05
Composition
Strands/Wires
mm
8/24/0.18TA (*5)
Braid thickness
mm
0.45
Standard thickness
mm
1.0
mm
11.25-11.75
Outer diameter in finished state
Note5 : TA indicates a tin plated soft copper wire.
Note6 : Braided shield is not waterproof structure.
Sheath
Braided shield
Insulator
Separator
Conductor
BReceptacle : Recommended Sizes of Copper Bus Bar and
Round Bare Crimp Connector
Width [mm]
Copper Bus Bar
Round Bare Crimp Connector (*7) (Size 22 is recommended)
Thickness [mm]
3 to 4
16mm max.
1.8
Note7 : When connecting with a round, bare crimp contact, please use a plain washer (for M6 [outer diameter Ø16≤,
thickness 1.6mm]). Assemble the plain washer between the round bare crimp contact and the hexagonal
bolt, not between the round bare crimp contact and the contact. When using a copper-tube crimp contact
instead of a round bare crimp contact, use the one with the maximum width of 16mm and the thickness of
3.6mm. In this case, no plain washer is required.
BApplicable Tool/Jig
Tool/Jig
Part No.
HRS No.
Contact extraction tool
EV1-PC-TP
150-0251-5
−ーーー
902-1515-2
Equivalent model :
9H-60 manufactured by Izumi Product Co.
902-1516-5
Equivalent model :
REC-150F manufactured by Izumi Product Co.
Manual oil pressure crimping tool *8
HT111 / 9H-60
Electric oil pressure crimping tool *8 HT112/REC-150F
Remarks
Note8 : Applicable tools are JIS C 9711 Compression Tools for Wire Connectors of Interior Wiring (JIS
general tools). As crimping performance varies by tool, please use the recommended tool.
5
BContact Extraction Tool
BManual Oil Pressure Crimping Tool
BElectric Oil Pressure Crimping Tool
BPanel cut out Dimensions for Plug and Receptacle
4×M6×1 Blind Hole 20 mm
+0.15
78±0.03
Finish the edge (3.5 mm or more) of the connector mounting
hole where waterproof sealant will make contact (
area)
with the surface roughness of Rz3.2
+0.15
66.65 0
24±0.03
− 0
0.
2
24.65 0
4×
R7
Remarks : The dimensions of the panel mounting hole are the dimensions when seen from the plug mating side.
BPRECAUTIONS
1. Always make sure to turn the power off before inserting or extracting the connectors.
2. Always check the condition of the connectors and terminals for damage or debris before mating.
3. Use of non-recommended wire can affect the performance. Only use the recommended cables to maintain
waterproof performance, shielding performance and cable crimping strength.
4. Please contact a Hirose sales representative for the harnessing procedure.
5. Braided shield is not waterproof structure.
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 03/2019. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“HT112/REC-150F”相匹配的价格&库存,您可以联系我们找货
